Old Jun 23, 2002, 03:00 PM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
Jeti 30/3 on 8 cells
Has anyone tried using a Jeti 30/3 on 8 cells? If so what prop did you use? I like to se if I can drop some weight by using fewer cells than the 120 I'm using now.
Dave
dottney is offline Find More Posts by dottney
Old Jun 24, 2002, 12:10 AM
DEATHspiral is offline
Find More Posts by DEATHspiral
San Diego, CA, USA
Joined May 2001
From what I've seen from a friends phasor 30/3, 8 cells will not do for that motor. You'll need a minimum of 10cells to get that 30/3 alive.
DEATHspiral is offline Find More Posts by DEATHspiral
Old Jun 24, 2002, 06:58 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Depends on the model. My Falcon flies just fine on a 30/3, 8xCP1300 and a 12.5x10 prop (short motor runs, 10 second or so). The Zagi also does well - 8xCP1300, 9x5 prop, I can fly full throttle with close to unlimited vertical for about 6 minutes..
8 cells works fine on this motor.
..a
Old Jun 24, 2002, 09:22 AM
San Diego, CA, USA
Joined May 2001
ANDY,
How does the 30/3 compare to the 15/4 on the zagi? How is the vertical and flight duration, and speed?
Thanks in advance.
Old Jun 24, 2002, 10:53 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
OOOOPS!
I had a brain freeze.. sorry - I am running the 15/4 in the Zagi, you're correct.
..a
Old Jun 24, 2002, 11:49 AM
Mark Grant is offline
Find More Posts by Mark Grant
Mark Grant's Avatar
London, England
Joined Dec 1999
I fly a converted glow kit on a Jeti 30/3 and 8 or 10 cells.
The model weighs about 3 1/4 lb with 8 cells and ROG's with ease. I'm using a 10/6 folder because thats what I had to hand after breaking a couple of APC's. I use the same prop for 8 or 10 cells 'cos I'm too lazy to change it. 10 cells does give a bit more grunt, but 8 hauls it round the sky fine.
Mark.
Mark Grant is offline Find More Posts by Mark Grant
Old Jun 24, 2002, 12:30 PM
rrowley is offline
Find More Posts by rrowley
rrowley's Avatar
United States, AR, Conway
Joined Sep 2001
Mark,
What is the name of you converted glow that you have on a 30/3. Are you using 1300, 1700, 2400? What kind of duration do you get?
Rod
rrowley is offline Find More Posts by rrowley
Old Jun 24, 2002, 02:49 PM
Mark Grant's Avatar
London, England
Joined Dec 1999
The model is a JB Aviation MiniSport. It's a 48" span high wing aerobatic model. It was built pretty much stock, I moved the servo's in the fuz back to make way for the cell pack, built a motor mount and changed the heavy wheels for light sponge ones. I use Sanyo 2400's, on 8 cells I get about 7 or 8 minutes of mixed flying.
I think JB's website is www.jbaviation.com
Mark
Old Jun 24, 2002, 10:20 PM
San Diego, CA, USA
Joined May 2001
Mark,
Are you able to get somewhat vertical with 8cells on your 30/3?
Discussion Jeti 30/3 on Eco 8? iflyelectric Electric Heli Talk 8 Jan 04, 2006 07:07 PM
Jeti 30-3 or AXI 2820-10 w/8 cells in Bandit ? Al P Power Systems 2 Sep 28, 2003 11:10 AM
Jeti 30-3 on Corona?? davensocal Electric Heli Talk 3 Apr 14, 2003 11:37 AM
Amps for 22/30/2 on 8 cells? HELP!! L@@K CrazyMike Sport Planes 1 Nov 14, 2002 05:36 PM
Which Pinion on an Eco8 Brushless Jeti 30/3 10-Cell Setup ropuri Electric Heli Talk 3 May 06, 2002 03:45 PM
