Old Feb 20, 2006, 11:40 PM
cam777cam is offline
Find More Posts by cam777cam
Melbourne, Australia
Joined Mar 2005
Telemaster 400 - Great trainer from free plans!
Hi all,
A while ago I contemplated buying or building my first electric trainer – and after some support from people on this forum decided to build one. My main concerns were the following;
1. Value for money – preferably free plans and standard gear.
2. Good flier – after all it is for learning!
3. Strong / easily repairable – for those inevitable crashes.
4. Around 36” size and standard build. (removable wing a bonus!)
5. Three channel (RET) with the possibility of adding ailerons later.
6. Looks good – no point flying something ugly!
After some hunting around I found the plans for the Telemaster 400 (dwg attached). These were downloaded from http://www.willingtons.com/mymac/Plans_Download.htm - although I’ve seen them in other places also. It looks very similar to HobbyLobby’s Mini Telemaster – but that was going to cost a fortune to ship to Oz!
This plane seemed to satisfy all my requirements and after chatting to someone who had previously built one (albeit scaled up to 45”) I decided to go for it.
The final specs were;
Wing span: 36”
Motor: 400sp 7.2v
Gear: 2.5:1
Prop: 9x6
Battery: 3cell LiPo, 1050 MaH
Weight: 380 grams – ready to fly
Covering: Solite
The build was very straightforward – no issues. I was really pleased with the strength of the wing as the leading 1/3 was sheeted with balsa. The horizontal stabiliser was also very strong. The whole thing was completed in a couple of weeks with no rush.
So, last week the whole thing came to a head and I had the maiden flights.
The first flight was in gusty conditions - which I shouldn’t have really been out in – but at 2/3 throttle it powered away from a hand launch easily and flew around happily for a couple of minutes. It was difficult to check the trim in the windy conditions and eventually a gust caught it and I experienced my first crash! The front was smashed around (it was a pretty hard impact) – but after 20 minutes with the CA all was well again.
The next day was a beautiful calm day and out I went again. This time I flew for about 10 minutes with no issue. Nice and steady flier – minimal trim required. Only needed 2/3 throttle for launch and loops (which were clean and easy) and then ½ throttle for the rest of the flight. I ended up bringing her down when at the bottom of a loop it lost power – due to a screw in the gearbox coming loose (must remember to check everything is tight before a flight!). It glided down smoothly for a nice landing – no damage! I was really happy!
I’d only ever flown the Parkzone Decathlon before this and the performance of the two are incomparable. The Telemaster is smoother, has more power and has longer flight times – not to mention the satisfaction of building it yourself!
I’ve attached a picture for your reference and a link to a basic build sequence on my web site if anyone’s interested. http://home.vicnet.net.au/~tarnagul/...lanes/t400.htm
I really just wanted to post this for others who may be contemplating the same thing. It can be done – and using free plans with ‘standard’ gear!
Now I just need to find more time to get out and fly!
Cameron.
cam777cam is offline Find More Posts by cam777cam
Old Feb 20, 2006, 11:49 PM
eliworm is offline
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Looks great. On your website you had two pictures before the maiden. What did it look like after?
Jim
eliworm is offline Find More Posts by eliworm
Old Feb 21, 2006, 04:26 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Two quick things:
  • Use Loc-Tite or some other temporary thread-locking compound on those gearbox screws. They will work loose at the most inopportune times...
  • A 3S LiPo will probably eventually burn out a 7.2 V speed 400 motor, though it sounds like you are sensible with the throttle.
Of COURSE your flight times are longer, you're on LiPos now!
Jeremy Z is offline Find More Posts by Jeremy Z
Old Feb 25, 2006, 09:59 PM
Griffin is offline
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
Nice Looking Telemaster!
Congrats on building and flying your own trainer--not everyone could pull that off!
-Steve
Griffin is offline Find More Posts by Griffin
Old Feb 26, 2006, 05:49 PM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
well done cam777cam - thx 4 sharing
glydr is offline Find More Posts by glydr
Old Jun 19, 2006, 05:57 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Beautiful... And scratch-built to boot!
Man... I hope my hobby-lobby kit comes out that nice. Just gotta get around to building it.
This makes me want to start w/ the plans and scratch build it first like you did though. See what I can turn out... Will have to check the .dwg to get a list of materials together... If I've got most of the stuff in the shed, then I may just start on it... Otherwise, will have to place an order before beginning...
Thanks for the inspiration.
-uproar90
msmith is offline Find More Posts by msmith
Old Apr 27, 2008, 11:52 PM
Hauntedgoat is offline
Find More Posts by Hauntedgoat
Joined Apr 2008
Great run through. Thanks for posting all this. My friend and I are buliding this plane for our senior project and I was hoping you could answer a couple questions for us. What are the shearwebs? I thought they where the supports that run in the wing from front to back but now im confused and think they might be sheets that run right to left in the wings (connecting the hard wood spars).
Hauntedgoat is offline Find More Posts by Hauntedgoat
Old May 04, 2008, 07:04 PM
Joined Mar 2005
Send me an email...
Hi guys,
Just send me an email and I'm happy to answer any questions that you have or take any photo's that may be helpful. I've also sent you a 'private message'.
Good luck - I'm sure you'll be happy with this plane.
Regards,
Cameron.
Old Feb 14, 2016, 02:36 AM
h4ckroot is offline
Find More Posts by h4ckroot
Joined Feb 2016
Hello Guys, I know that this is an old post, but i thought it would be better to post my question here instead of opening a new thread. I have been for a short while in Foam building (build around 5 plans so far from FT designs). I am completely new to balsa building and was planing to build this exact model - Telemaster 400. However I could not understand some details in the plan. I will list it below, and I would really appreciate and answer.
1- What is the thickness of the ribs for both the Wing and the HS.
2- In the wing section, what does it mean 3/4 triangle tip !? and how can i do this part ?.
3- In the HS ribs, there are two parts !, what is the difference between them.
Again, Really appreciate your answers.
Thanks for this awesome community.
h4ckroot is offline Find More Posts by h4ckroot
Old Feb 14, 2016, 08:35 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Sheer webs are the pieces that join the upper spar and lower spar . They greatly increase the strength of the wing as it keeps the spars from buckling under high G loads. Google the term to find out more about sheer webs.
Rodney is offline Find More Posts by Rodney
Old Feb 14, 2016, 09:44 AM
eliworm is offline
eliworm's Avatar
Arizona
Joined Jun 2002
I could not find a call out for the thickness of the ribs but you should not have any trouble if you use 1/16 balsa.
For the triangle tip it is literally a 3/4 inch triangle balsa stock available from most hobby shops. You will cut a strip the length of the tip and glue it with the wider portion of the triangle stock to the upper part of the rib. Once dry you will be able to trim and sand it to shape blending the triangle stock to the rib to give a pleasant look fairing the tip in nicely.
If I understand your question for the HS correctly there are two ribs. One is the normal rib and the other is the center section ribs where the 1/16 sheeting goes top and bottom. A slightly thinner rib profile is needed to allow for the thickness of the sheeting.
Jim
Old Feb 16, 2016, 05:11 AM
h4ckroot is offline
Joined Feb 2016
Thanks a lot. Two more question I have, which is the Elevator part of the HS. As far as i know, I should use like 1/8 inch thick balsa, and sand it to shape it, is this is right ? . Also, what is the size of hings and control horns I should use ?
Old Feb 21, 2016, 08:08 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
Congrats! I'm building a73" one
walter3rd is online now Find More Posts by walter3rd
Old May 16, 2016, 12:29 AM
BalsaBrent is offline
Find More Posts by BalsaBrent
Joined May 2016
plans? printing>
I just copie these plans to a usb rive and took them to office works to print.. when i came back to pick them up it was on an a4 page, tiny little plans. lol.
I said its way to small and they said they printed it to actual size and that i need to either scale it myself or download a pre scaled copy,
sadly to say i have no idea how to do that. any help would be great thanks,
Brent
BalsaBrent is offline Find More Posts by BalsaBrent
Discussion Suggestions wanted. Foamie with airlerons from free plans Tailspin Ken Foamies (Kits) 9 Mar 09, 2006 11:50 AM
Kits from free plans ? steve lewin Electric Plane Talk 18 Nov 25, 2003 07:37 PM
Fast E.R. 400 free plans! pierluigi demontis Sport Planes 38 Sep 20, 2002 03:18 PM
p-51d s-400---free plans? i-fly Scale Kit/Scratch Built 2 Nov 27, 2001 08:37 AM
Arado 232 free plans from RC Model World stealthy Scale Kit/Scratch Built 0 Oct 04, 2001 02:20 AM
