Old Feb 20, 2006, 01:17 AM
hihptsi is offline
Find More Posts by hihptsi
hihptsi's Avatar
Illinois
Joined Apr 2005
RCAP Ver 1.1- Ver 2 Development.
starting another thread regarding the testing and improvement of the RCAP GPS autopilot module.
hihptsi is offline Find More Posts by hihptsi
Old Feb 20, 2006, 09:59 AM
rclinks2002 is offline
Find More Posts by rclinks2002
san diego,ca
Joined Jan 2006
subscribe
rclinks2002 is offline Find More Posts by rclinks2002
Old Feb 20, 2006, 10:16 AM
Hovertime is offline
Find More Posts by Hovertime
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Ordered my RCAP V2 board and parts kit from here : http://www.scalerobotics.com/store/catalog
Hovertime is offline Find More Posts by Hovertime
Old Feb 20, 2006, 01:46 PM
MAGO is offline
Find More Posts by MAGO
CHILE
Joined Feb 2006
Anyone knows how work this RCAP,
it is an automatic pilot?
Only navigation, no altitude hold?
it is an element of a autopilot?
the RCAP that you bought, is ready to use? Do you need another components?
MAGO
MAGO is offline Find More Posts by MAGO
Old Feb 20, 2006, 02:23 PM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
MAGO
The RCAP is a Waypoint navagating device that accepts a nema input from a Handheld GPS via Serial connection.the RCAP reads stores Tracks or Waypoints entered into the Handheld GPS via Manual means or Via Garmin Mapsource software once waypoints are made active in the Handheld and the RCAP autopilot is activated via a extra receiver channel and a switch on your transmitter,the RCAP will then Take full control of the Rudder and steer the aircraft to the next waypoint, during this time you have full control of the elevator servo to hold aititude, or let a copilot take care of that..there are 2 adjustments on the rcap board to adjust the servo travel and the agressiveness of how it holds an activated course.At this time there is no altidude hold function but given a few more people are willing to help an altitude hold will be in the works that will be a easy upgrade to the existing RCAP Version 2 boards.i have a fully functional rcap unit that has been ground tested and dialed in and seems to be working flawlessly i will be putting the RCAP through a series of tests on my UAV to find any flaws and hopefully address them.anyone with programming experience and electronics experience willing to help with a altitude hold please give me a pm we can get the ball rolling on this.
Walter
Old Feb 20, 2006, 02:32 PM
MAGO is offline
CHILE
Joined Feb 2006
Thank you Walter.
It can be used with ailerons or only rudder?
MAGO
Old Feb 20, 2006, 02:40 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
I plan to test mine on RC truck
Old Feb 21, 2006, 12:31 AM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
Thank you Walter.
MAGO
it is recommended you use the RCAP on the Rudder channel,Although i THINK it would work fine set up on aleirons IF you were using 1 servo to control the Aleirons..in theory it will work but i have not tested it this way...
Walter
Old Feb 21, 2006, 01:03 AM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
No i doubt it, it would be out of control ....
Old Feb 21, 2006, 07:22 AM
MAGO is offline
CHILE
Joined Feb 2006
I think that maybe RCAP could be used with ailerons if would have an altitude hold device.
Because when the arplane turns with ailerons it will lose altitud. In that moment the altitude hold device will move the elevator (or speed up the motor) to hold the altitude and perform the turn without problems.
I am wrong?
MAGO
Old Feb 21, 2006, 01:24 PM
Matt Dziubinski is offline
Find More Posts by Matt Dziubinski
Twist n' Shout!
Matt Dziubinski's Avatar
Joined Nov 2004
Let us know
Matt Dziubinski is offline Find More Posts by Matt Dziubinski
Old Feb 21, 2006, 06:09 PM
kd7ost is offline
Find More Posts by kd7ost
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
I am wrong?MAGO
No, you are not wrong. It will work as you say. Everyone needs to remember this won't generally look the same as when you fly though. When we stand on the ground and slam full sticks to crank it around, we can't get that with the autonomous parts. The rate of turn needs to be limited and you have to give it enough airspace to work and be a little patient. More trainer like.
Dan
kd7ost is offline Find More Posts by kd7ost
Old Feb 22, 2006, 12:37 AM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
ok i was thinking a little about the altitude hold function and come up with a couple ideas on its operation..it would be nice to utilize the 10 bit onboard ADC of the PIC 16F876 im thinking a max Ceiling of 2000-2500 Feet would be good enough i figure a motorola MPX5100 Pressure transducer given we use the max ceiling of say 2000 feet we could have a resolution of around 5 feet or less.id like to hear what you guys recommend what route we should go here.
the Existing Pic 16f876 could be reprogrammed with the altitude hold function
given there is enough space leftover..
basic operation for the altitude hold
power on: initializes (LED status),Calibrates/Zeros out (ground = 0ft AGL)
once activated (same switch that activated RCAP) Takes pressure sample and maintains Pressure at wich the autopilot was activated at.
pretty simple.id like to know what everyone thinks on this.
Old Feb 22, 2006, 12:56 AM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Well it sounds simple All I can say that if I have a suitable pic programmer, and firmware file, I could probably burn it, and could also solder needed parts together, thats about it .....
One could use other ready to use stabilizing devices too...
BTW altitude hold is a good idea even using rudder, or for simple straight and level flight too.
Another thought I had for less power variation due to battery voltage changes comes from my heli flying - lets consider using governor mode for the prop.
This (with the right setup) would make sure RPM is constant during the whole flight.
Old Feb 22, 2006, 01:14 AM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
i was thinking about the RPM function wich will be nice,input could be via GPS or via a Pitot-static type sensor,but one thing at a time though
Gov mode would be a good idea for a fix but would not gurantee a airspeed,but would work for the time being.
i could very easily go out and but a UNAV alt hold and be done with it but the point of this project is a learning experience hopefully some more people chime in who can provide a little help to getting this done.
For Sale Wild Hare 28% 540T (ver 1.1), Local PU preferred AggieFlyer Aircraft - Fuel - Airplanes (FS/W) 3 May 02, 2007 06:41 PM
TwinBizJet, ver 1.1 Larry Dudeck Sport Planes 14 Apr 19, 2003 09:19 AM
Flying wings, 1 or 2 vert. stab(s)??? g00bd0g Power Systems 7 Aug 04, 2001 08:03 PM
Is this possible? 1 motor and 2 planes ChrisD Electric Plane Talk 4 May 31, 2001 12:03 AM
Top Speed of DAW Schweizer 1-26 2-Meter austin9000 Foamies (Kits) 1 May 17, 2001 11:13 PM
