Old Jan 07, 2012, 07:50 PM
Taiwan, 北市
Joined Dec 2010
Originally Posted by cyclops2 View Post
Hi Chen
I am soldering all connections to eliminate oversized connector plugs & pins.
This is turning into a enjoyable project. DIY is always more fun.
It's a smart idea ! Rich
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jan 16, 2012, 08:00 AM
United States, NJ, Frenchtown
Joined Mar 2003
GWS still teaching me better ways.
Installing the ailerons servo & rods. I just realized that those tiny round set screw control horn connectors are FANTASTIC !!
I am using 3. The Sullivan Products .032" very flexable push cable slides thru the clamping holes perfectly. 1 piece of flex wire fed thru all 3 holes adjust for neutral position. Tighten the servo screw first, then align a surface, tighten the setscrew, do the last surface.
LOVE the missing snap links & threaded shafts.
Ordered 2 more Sullivans. for R & E.
Thanks GWS.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Jan 24, 2012, 09:35 PM
Taiwan, 北市
Joined Dec 2010
Hi Rich,
It's a good reference from the post #779 of http://www.rcgroups.com/forums/showt...527072&page=52
Chen
Old Oct 05, 2012, 08:00 AM
dirdredd's Avatar
United States, GA, Clayton
Joined Jan 2010
Dir D Redd's Cargo-Trans Quad Setup
Well I crashed my Blue Angels (Fat Albert) Now I have two and may possibly get a third. Here is one that is almost finished. I have to touch up a few areas because the whole thing I painted by hand. I hope that some of you like what I have done thus far.
The Build: Main Wing Fiber glassed, Wood Motor Mounts
This is the Electronics.
4 X 10a Eflite ESC's
4 X ESKY 1200-KV Outrunner Brushless Motors
1 MG 9g Rudder Servo
1 MG 9g Elevator Servo
2 After Market 9g Aileron Servos
Now my only challenge is how to put a 2200 mah 30 - 40c lipo inside.
dirdredd is offline Find More Posts by dirdredd
Old Oct 08, 2012, 07:13 PM
Taiwan, 北市
Joined Dec 2010
I noticed that some pilots did successfully put two outrunners only on this Cargotrans, while another two engines were empty but their props. You might have been the first pilot who applied four outrunners on it. Good job !
Old Oct 15, 2012, 02:20 PM
dirdredd's Avatar
Joined Jan 2010
Why Thank You @ twn Chen. Now I just have to find a way to put a 11.1v 2200mah 30 - 40c lipo in her.
Old Oct 15, 2012, 10:43 PM
Taiwan, 北市
Joined Dec 2010
Oh you might have to carve the foam carefully for the lipo, and I think 30C or 35C one is good enough, it's lighter and cheaper at least.
Old Oct 22, 2012, 06:57 AM
Joined Apr 2009
Power!
I don't know the power rating on those motors but chanes are that thing will move vey fast. Hopefully you reneforced the wing! I'm looking forward to the flight video...
carlcorn is offline Find More Posts by carlcorn
Old Oct 23, 2012, 01:35 PM
dirdredd's Avatar
Joined Jan 2010
The C-160 Blue Angels Fat Albert
I have 2 Cargo Trans. The pics above is my Almost finished U.S.C.G. Quad.
Also, I am finishing My Blue Angels Fat Albert C-160. Double Prop.
Old Oct 23, 2012, 06:31 PM
Taiwan, 北市
Joined Dec 2010
Yes, Carlcorn is right, it's better to reinforce the two wings, especially the quad's one, as you apply more powerful motors than the stock ones on them.
Chen
Old Oct 23, 2012, 09:57 PM
Fly It Like You Stole It
United States, TN, Blountville
Joined Oct 2002
Anyone flown their cargotrans as a slope glider?
Did you fly it stock or did you add wing to the design?
Just wondeing if I should fiberglass it with 0.75 oz cloth to increase durability as well as some carbon tow on the top/bottom & sides...
RAFster is offline Find More Posts by RAFster
Old Oct 29, 2012, 04:16 AM
dirdredd's Avatar
Joined Jan 2010
This is my third one. as far as the wings go. they are reinforced. I used fiberglass to cover all my cargotrans main wing. with this grade of fiberglass.
http://www.hobbyking.com/hobbyking/s...dProduct=10905
Then I used a water base:
http://www.homedepot.com/h_d1/N-5yc1...3#.UI5JB2dyhgA
It adds a little weight but flying on rails with no wing bending.
I painted after everything is dried and harden.
Article GWS CARGOTRANS QUAD ARF Review Andy W Electric Plane Talk 27 Oct 06, 2012 02:28 AM
Wanted GWS Cargotrans Quad (C-130) SRodz Aircraft - Electric - Airplanes (FS/W) 3 Jun 17, 2007 06:53 PM
Sold GWS Cargotrans Quad&Twin -CHEAP- plus electronics. metalbuggy Aircraft - Electric - Airplanes (FS/W) 2 Aug 17, 2006 09:27 AM
Discussion Gws cargotrans quad c-130 prop! beaulac Electric Plane Talk 11 May 27, 2006 10:36 AM
