Old Jan 04, 2012, 06:23 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Hi Rich,
I'm afraid that rudder could not work so responsive as what ailerons do on such wing. Let me know how it makes turns if you decide to use rudder and elevator only.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jan 04, 2012, 06:59 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Thanks Chen.
I am installing A airleron system using .032" stiff wire in a close fitting plastic guide tube.
1 servo drives both airlerons & allows a clean wing.
cyclops2 is offline Find More Posts by cyclops2
Old Jan 04, 2012, 07:24 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Hi Rich,
Very good idea, that's the best one on markets. I did use the tube+wire one on my Kysho Melody long ago for controlling its elevator, the fully movable one. It's always not easy to have its neutral even the servo worked perfectly for me because I forgot to fix the curved tube firmly at the inside of its fuselage. The curved tube got moved always when the push rod wire moved forward/backward, the elevator stayed a little bit up when I released the stick from using up elevator, and a little bit down when the stick went back from down elevator.
The illustration on the picture tells you how to fix the tube better.
Chen
Old Jan 04, 2012, 08:35 PM
cyclops2 is offline
Joined Mar 2003
The plane below need rods more than 4 1/2' long. so I remembered that wire feed welders use about .032" diameter wire. 2 pieces of the plastic tubing did the length requirements.
The highly raised up elevator required a very flexiable control pushrod. .032" is ideal. I also forgot to put enough glue spots the first time I assembled the tubes. Same sloppy neutral point.
Old Jan 04, 2012, 10:05 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
It looks like a PBY, but it is with two more engines.
I'm sure you'll put enough glue on the spot this time on your Cargotrans. I'd add more spots for fixing the tube better if I had to apply the same tube+wire again.
Chen
Old Jan 05, 2012, 03:17 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Originally Posted by cyclops2 View Post
Pat
Do you know if anyone has flown the quad with only Rudder & Elevator ? Was the control OK. I fly scale like. No stunt stuff.
I've flown my (prop) quadtrans both powered and (with the props off) as a sloper. It did both jobs well - flying scale like, but I definitely think you need the ailerons. It has no dihedral to speak of and I'd be very concerned about directional and roll neutrality without some aileron input.
Also, if its not too late, I'd let some thin c/f strip (edge on) into the fuselage top longitidinally ahead of the wing. If you have a sharp landing (something in which I have developed a considerable, albeit unwanted, expertise) the front end of the fuselage can buckle and you end up with humpty dumpty. Ask me how I know this
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jan 05, 2012, 08:44 AM
cyclops2 is offline
Joined Mar 2003
Chen
It is a Martin flying boat. My first scratch build attempt. That plane is hand hollowed out from solid blue foam block. I can hand launch it and run along side of it untill touchdown.
It still flies with the 4 ...6 volt 400 brushed motors & 1 BIG brushed ESC.
Very slow acceleration on water. About 100'. 1 wide circle & a perfectly level flair on touch down. Looks as boring as the real plane when it flies.
Old Jan 05, 2012, 08:54 AM
cyclops2 is offline
Joined Mar 2003
Roger
I just realized that I might be able to run the plastic airleron tubes in the bottom of the wing spar slot. lots of room for 6 motorleads & the plastic tube pushrod.
I will do the back bone implant of some kind.
Rich
Old Jan 06, 2012, 10:26 AM
cyclops2 is offline
Joined Mar 2003
Sanding off the pimples adds more work ?
I finished sanding all the surfaces of whole plane. Looked great !
Then I saw all the dings I had put into it. By the the time I did the slotting for the airlerons. MORE dings. I am not filling any dings. I still have all the tails to do. Plus fitting the rest of the parts.
Do you guys do only 1 final ding filler after flight testing or as you build ?
Ding man.
Old Jan 06, 2012, 12:50 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Try a little hot water to get the dings out. Then, use a coat or two of water based polycrylic (you can get the Minwax brand at Lowes or HD, works great!).
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 06, 2012, 02:55 PM
cyclops2 is offline
Joined Mar 2003
Thanks Pat
Do not get to be as old as I am !!
My new 2 year old 8 oz. of Epoxy self hardned. I have 4 mini hinges left. I have no liteweight spackle. No 3 mm X 5 mm adaptors, No small ESC ( have loads of BP Hobby 30 amps ), no small heatshrink for all the motor wire solder joints, No Polyester wing center joint cloth.
What the heck did I do / Think, was going to happen when I finished my last plane ?
I have to write everything down as soon as it needs to be replaced.
I forget to remember to write it down fast enough.
Rich
Old Jan 06, 2012, 03:00 PM
cyclops2 is offline
Joined Mar 2003
Pat
Did the recommended airleron throws do the job ? How about rudder & elevator ?
Rich
Old Jan 06, 2012, 04:57 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Rich,
All recomended throws seemed to work fine for me.
Pat
Old Jan 06, 2012, 10:22 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Rich,
Take your time and take it easy.
You might be the first pilot/builder who intends to install four inrunners + gears on GWS Cargotrans. You have to solder many wires, and connect four ESC's in parallel with receiver, and battery pack as well. This is way more complicated than the stock brushed set up. Good luck
Chen
Old Jan 07, 2012, 07:23 AM
cyclops2 is offline
Joined Mar 2003
Hi Chen
I just finished The sanding & lite weight spackling of all the dings & filling in of the un-needed airleron cutout in the wings. It took me about 1 hour. Buut This will be my best looking GWS plane.
The solid Copper Thermostat wire, 18 guage, is perfect for these 12 mm sized motors. The 3 conductor has 3 different colors. So I only have to make the 3 wires of the 4 th motor black with a black felt tipped marker. No possible wiring errors. White, red, green & black.
Voltage drop at 11 volts & 6 amps. is .15 volts total. Very good in my book. I am soldering all connections to eliminate oversized connector plugs & pins.
This is turning into a enjoyable project. DIY is always more fun.
Edit
The elevator wire is .056" The electrical wire is .050".
Article GWS CARGOTRANS QUAD ARF Review Andy W Electric Plane Talk 34 Dec 31, 2013 03:59 PM
Wanted GWS Cargotrans Quad (C-130) SRodz Aircraft - Electric - Airplanes (FS/W) 3 Jun 17, 2007 06:53 PM
Sold GWS Cargotrans Quad&Twin -CHEAP- plus electronics. metalbuggy Aircraft - Electric - Airplanes (FS/W) 2 Aug 17, 2006 09:27 AM
Discussion Gws cargotrans quad c-130 prop! beaulac Electric Plane Talk 11 May 27, 2006 10:36 AM
