Old Dec 24, 2011, 07:49 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Probably Caliber Hobby www.caliberhobby.com stocks this adapter, GWADP001
http://www.gwsus.com/english/product...ve%20shaft.htm
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jan 03, 2012, 08:36 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Am I late for the maidens of the C-130s ?
Just finished up hollowing out the foam engine housings for the 12 mm gearboxes.
Does anybody have slack wires in the cowel area for engine pull out & repair?
Or did you do something else.
About ready to glue them in with some RTV lightly. So I do not tear out wing chunks during repairs.
cyclops2 is offline Find More Posts by cyclops2
Old Jan 03, 2012, 02:32 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I didn't have any slack wire in mine and had to pull everything apart when I upgraded to larger motors. Slack wire would be a good idea.
A friend of mine just finished a quad-EDF version and flew it at our field. Now I'm motivated to get mine out of mothballs and finish it since I just picked up a NIP brushed ESC for a song.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 03, 2012, 02:50 PM
cyclops2 is offline
Joined Mar 2003
I am at 16 to 17 oz on a scale. Just RC parts & the foam plane parts & with a 3C 2.2 amp hour Nano tech battery.
As I recall those 12 mm GWS motors were not thrust monsters.
I should be getting about 4 oz from each motor or 16 oz of thrust total. The plane looks " draggy " ? Is it. ?
The geared motors using GWS 4" x 4" props do a static 11,800 rpm. So the takeoff speed is about 40 mph
Does that set up provide enough power for add ons like the operating cargo door.
How does your plane do if only flown on R E M ?
Rich
Old Jan 03, 2012, 02:52 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Rich,
Did you say a 3-cell 2200 pack? If so, you're going to burn those motors out in one big hurry!
I flew mine with a ThunderPower 2S 1320, and it flew just fine. Not fast, but able to stay airborne without issue.
I would say go with a 2S 1300 or so pack. A 2200 will be way too heavy.
Pat
Old Jan 03, 2012, 04:49 PM
cyclops2 is offline
Joined Mar 2003
The motor is not a GWS brush type. It is a Hyperion 12 mm in a BP Hobbies Aluminum cased gearbox of 4.14 : 1 ratio. It can handle 8.5 amps with enough cooling. I keep it at 6 amps or less in closedup scale looking cowls like ours. The motor will be 1/2 way buried in the foam housing with some airflow out the back.
They are spinning the GWS EP 4 X 4 prop at 11,800 rpm & at 2.4 amps on a 10 volt pack.
The motor is cold during 3 minutes @ WOT.
Old Jan 03, 2012, 05:48 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Ah, OK. Good. Looking at the pic I couldn't tell if they were stock or upgraded.
Pat
Old Jan 03, 2012, 05:53 PM
cyclops2 is offline
Joined Mar 2003
Here is the 1 ounce power unit with a EP 4 x 4 on it.
Old Jan 03, 2012, 05:56 PM
cyclops2 is offline
Joined Mar 2003
Oh NO Pat.
You are warm & dry all winter.
I am at 30 to 40 F & 20 to 35 gusts. BOOOOO
High of 25 tomorrow.
Rich
Old Jan 04, 2012, 03:42 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Pat
Hi Pat,
Please tell me more - any pictures or video? Your friend's is the first flying quad EDF I've heard of. I shipped one to the UK several years ago but its been sitting in my build pile ever since. Could be I'm motivated to reach for it? Is your friend flying with the stock brushed fans (which is what I had planned)?
Seems to me that adding 4 brushless units together with four esc is going to add about $100 which I'd prefer to avoid. I don't need it to do anything more heroic than flying to scale.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jan 04, 2012, 02:49 PM
cyclops2 is offline
Joined Mar 2003
Roger
My cost is $ 29 for each motor & $ 8.50 per gearbox. X 4 is $142 .
Bigger is cheaper.
Old Jan 04, 2012, 02:52 PM
cyclops2 is offline
Joined Mar 2003
Pat
Do you know if anyone has flown the quad with only Rudder & Elevator ? Was the control OK. I fly scale like. No stunt stuff.
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Hi Roger!
Just pics for now, but it did fly pretty well on the stock power system. No overly fast, just a tad slower then the quad prop version.
Pat
Old Jan 04, 2012, 02:53 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by cyclops2 View Post
Pat
He made it 4-channel.
Pat
Old Jan 04, 2012, 03:06 PM
cyclops2 is offline
Joined Mar 2003
VERY nice engine housings.
Thanks for the pictures.
Innov8tive.com Has shipped the props & adaptors. Great people there.
Rich
Article GWS CARGOTRANS QUAD ARF Review Andy W Electric Plane Talk 34 Dec 31, 2013 03:59 PM
Wanted GWS Cargotrans Quad (C-130) SRodz Aircraft - Electric - Airplanes (FS/W) 3 Jun 17, 2007 06:53 PM
Sold GWS Cargotrans Quad&Twin -CHEAP- plus electronics. metalbuggy Aircraft - Electric - Airplanes (FS/W) 2 Aug 17, 2006 09:27 AM
Discussion Gws cargotrans quad c-130 prop! beaulac Electric Plane Talk 11 May 27, 2006 10:36 AM
