Old Jun 21, 2002, 01:49 PM
Bsouthwell is offline
Find More Posts by Bsouthwell
Bsouthwell's Avatar
USA, MS, Iuka
Joined Jan 2002
Bluecore F7F Tigercat Ready to fly!!!
Hi All,
Here's a few specs and pictures of my new F7F.
Span 34"
AUW 11.7 oz.
Power 2-DX-A with 8X6 gws props
aileron, elevator, rudder, throttle and retracts , Just kidding no LD gear . It is based on some pull out plans by Dave Boddington.
Going out to test fly it now..................
Bsouthwell is offline Find More Posts by Bsouthwell
Old Jun 21, 2002, 01:50 PM
Bsouthwell's Avatar
USA, MS, Iuka
Joined Jan 2002
Head on......
Old Jun 21, 2002, 01:51 PM
Bsouthwell's Avatar
USA, MS, Iuka
Joined Jan 2002
one more....
Old Jun 21, 2002, 02:11 PM
Mike Hall is offline
Find More Posts by Mike Hall
Mike Hall's Avatar
Albany, GA
Joined Jun 2002
I started working on a plug for a mold of a 36" wing span scale F7F years ago. Maybe I should get that plug off the shelf and finish it. I also used Bluecore foam to carve the fuselage. Let me know how that thing flys.
Mike Hall is offline Find More Posts by Mike Hall
Old Jun 21, 2002, 02:19 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Bill,
That looks good. My B-25 foamie turned out too big for twin GWS DX-A's, so I'm still looking for a candidate.
How long did it take you to build? Exactly how did you wire the two motors and what battery and ESC? I'm not good with electrical, so please describe the wiring carefully, if you can.
I've got a whole box of foam sheets ready to turn into something and a few DX-A's laying around.
Derek
DerekB is offline Find More Posts by DerekB
Old Jun 21, 2002, 03:11 PM
Bsouthwell's Avatar
USA, MS, Iuka
Joined Jan 2002
It worked!!!!!
Hi All,
It flew!!! It was very stable even in the bumpy air I was flying in. The climb performance was good but not vertical by any means. After all it's powered by DX-A's!! I rolled it a few times and it had a bit of lag due to the nacelles mass and the wings are a bit flexible in torsion. It looked great doing low passes and steep banked turns. I like it!!!I am taking it to the SEFF tonight along with my RRC Edge. Look me up guys and I will tell you all I can.
It took me from Monday eve to Late last night to build. Most of the time was spent on figuring out were to squeeze every thing in. I wired the engines in parallel , basically a Y servo cable, I used a GFS ESC from Radical and it has no problem handling the 4 servos. I used two on the ailerons to simplify the linkages. They sit in the side of the nacelles. I hard wired them in a Y cable to save a little weight. I have more wire in it than necessary but it is a prototype and will do better on the next one….. The battery is a 8 cell Maxell flat pack out of the RRC Edge 540.
Regards
Bill
Old Jun 21, 2002, 08:30 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Glad to here the flight went well. Sorry, I can't make it to SEFF. Rats.
Derek
Old Jun 21, 2002, 08:47 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
Derck
Where are you guys flying there will be moving down next month if I can get my planes there in one piece
russ6421 is offline Find More Posts by russ6421
Old Jun 21, 2002, 10:08 PM
mudfarmer_mike is offline
Find More Posts by mudfarmer_mike
Senior Member unum multum
mudfarmer_mike's Avatar
United States, AL, Huntsville
Joined Dec 2001
Bill:
It turned out nice!
Maybe I can make it to Iuka next weekend and you can let me fly it
mudfarmer_mike is offline Find More Posts by mudfarmer_mike
Old Jun 22, 2002, 01:44 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally posted by russ6421
Derck
Russ,
It's not clear. Where are you moving to? I live in Jacksonville, FL and the SEFF show is near Atlanta, GA.
Derek
Old Jun 22, 2002, 01:55 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Paint?
Bill,
I know you were rushed to get it ready for SEFF, but do you plan to paint it or color it with markers? It looks great as is, but some semi-realistic paint scheme would really transform it!
This might be the one to try the airbrush on. I'll guess it only adds about 0.10 to 0.15 oz. if you go easy with the paint. I'm also guessing that the dark colors will cover pretty well, so not much paint will be needed.
Derek
Old Jun 22, 2002, 02:02 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Or here's another one.
Once I started looking for photos just to check it out, I realized that's a cool plane. It's all motor! I also found a nice 3 view drawing - but I presume you already have one. If you are going to build another one, I can email it to you (file is too big to post here).
Derek
Old Jun 22, 2002, 06:25 PM
russ6421 is offline
russ6421's Avatar
ny
Joined Dec 2000
Derck
Jacksonville Fl
Old Jun 22, 2002, 08:14 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Beautiful Tigercat!
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jun 23, 2002, 10:24 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Derck
Jacksonville Fl
Russ,
I'm not too well connected around town regarding the popular flying sights. It's pretty fragmented. Jacksonville is very large, area wise. What area of town will you be moving to?
Derek
ACT Me-163 Ready to Fly! God help me! Smifta Foamies (Kits) 25 Aug 02, 2001 10:52 AM
Thanks to Fred, E-LMH Ready to FLY !! Daveairway Electric Heli Talk 3 Jul 25, 2001 12:48 AM
Sporty ready to fly full house bps Foamies (Kits) 0 Jul 04, 2001 03:59 PM
Ready To Fly DuskStiks CoClimber Parkflyers 9 Jun 18, 2001 11:07 PM
HYPERFLY-ALMOST READY TO FLY wingman2 Electric Heli Talk 4 Jun 12, 2001 01:24 AM
