Old May 18, 2001, 09:51 PM
austin9000 is offline
Find More Posts by austin9000
memphis, tn
Joined May 2001
Building Scale From Scratch
Hello,
I was wondering how people build scale from scratch models like the XB-70 in that column on this website. Do they use balsa?
I am interested in building a dual or triple mini fan 480 powered s-71 blackbird, but I am not sure what the best way to construct it would be.
The material I am leaning towards now is EPP foam. I was thinking about getting a big block and just start wittling with a dremel and maybe a hot knife or something, then maybe drill a few holes in it if it were too heavy, but this could get a bit tedious. Secondly, I was thinking about making some sort of a fiberglass mold and investigating getting liquid foam that would harden when cooled or something such as this. Does this exist in a feasible price range (I am guessing it has to exist to mass produce zagi's, etc.)?
I also saw a picture of someone who had built a scale B-2, and it was really cool. What construction technique did they use?
Austin Carpenter
austin9000 is offline Find More Posts by austin9000
Old May 19, 2001, 11:37 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
a few points... the sr71 seems to attract beginners (no criticism intended) but there are few worse choices for a first attempt. witness the fact that mention using 3! minifans.. what's the third one for ?
EPP foam is crash resistant, being very spongy, it's also difficult to shape into anything scale... try shaping , cutting, or sanding a piece as an experiment.
Molded planes can be magnificent... so is the skill and time required to make the plug and molds.
A first plane should be a simple one that is relatively easy to actually complete in a satisfying way.. there must be thousands of 1/2 finished models rotting in basements.
Bare is offline Find More Posts by Bare
Old May 19, 2001, 01:43 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
You can take a look at my L39 project at www.rcwizard.com/haldor to see how I did my first scale EDF. I used green foam to sculpt the fuselage, hotwired then sanded.
Haldor is offline Find More Posts by Haldor
Old May 19, 2001, 02:06 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
The Boeing JSF has been done and it is a simple subject to model, as long as you aren't gonna enter it in the Master Scale class. Keep it simple.
Here is my page on it: http://hometown.aol.com//kcox854272/x32.html
Kevin Cox is offline Find More Posts by Kevin Cox
Old May 19, 2001, 04:54 PM
memphis, tn
Joined May 2001
Nice looking plane, Kevin.
Do you have any more info on how it was constructed and designed, like how you knew what wing thickness to use, and how to shape the curved leading edge?
What did you make the scoop on the bottom out of, and where did you use the balsa? What is the thickness of the wall on the bottom scoop? What about the thickness and material of the two rudders (i am sorry that i don't know what they are called, but i mean the two things sticking up on the back, stabilizers maybe?)?
How fast does this thing go?
Finally could you please explain the error you made, I don't really understand it.
sorry again about all of the questions
Austin Carpenter
Old May 20, 2001, 12:49 AM
memphis, tn
Joined May 2001
Thanks for your reply,
After doing some more reserach, I found out that the sr-71 is a really tough plane to do with the hard edges, orientation, and all. Maybe a boeing JSF or B2 would be a better choice. The JSF would be pretty hard to shape though.
What about shaping EPS foam? And, I have some (a little) experience making fiberglass plugs and molds, but I am not sure what you put into the mold once you have made it. Can one purchase foam which comes as a liquid that would still be light and relatively durable? Or, would the plane be made out of some other material such as fiberglass or kevlar?
Yep, this wasn't going to be a first plane. I am getting a zagi pretty soon for that, but since this may take a while to build I am thinking I could get started in not too long.
Austin Carpenter
Old May 20, 2001, 09:46 PM
Kevin Cox's Avatar
Joined Jan 1997
The wing thickness and airfoil, in my opinion, is a function of the planned flight envelope. So it depends on what you are trying to do. The X-32 on the page had a 6% symmetrical airfoil at the root and 8% at the tip if I remember right. Most of the LE of my models are fairly sharp, but it is because I use balsa triangle stock. This makes it easier for me to consistently shape the LE.
The X-32 in its final setup was probably about 80mph.
The error that I made was on the inlet opening. I made it about 70% of the fan swept area instead of the planned 90-100%. It still worked well.
Old May 20, 2001, 11:49 PM
memphis, tn
Joined May 2001
Thanks Kevin,
I am planning on building a small albatross, then once I get that working, a larger one.
To construct my wing, I was going to build a a foam wing cutter, make the shape out of possibly plaster, then cut the core with the foam cutter. Then, put a balsa support sheets on part of the foam wing, leaving most of it uncovered ([until painting], like what you seem to have done (if I am looking at the picture right). What balsa thickness did you use for those cut-off triangle like shaped supports?
It's now time for me to learn about airfoils and make a wing patter.
You all have been a great help.
Austin Carpenter
[This message has been edited by austin9000 (edited 05-21-2001).]
Old May 21, 2001, 09:48 AM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Austin,
I am a fellow EDF newbe.
I have used blue construction foam on sevral jets, is is very durable. It is also about 6 bucks a sheet and I am on my 4th air frame off one sheet. I cut it out with a razor knife, rough shape the edges with the razor knife, glue the layers together when I need more thickness, and sand it with 80 grit paper. When I am satified with the curvs, I use very fine sand paper to smooth it out. This stuff sands very fast but makes a mess. I have been using less and less blue foam and more white to keep the weight down. The white foam is harder to work because the beads are so coarse. I frame the wings with basla like Kevin, and basicly try to read every word he has ever written. I use a balsa spar or plate in the nose of the jets because this is where they take the most stress in the Jason style landings . This is also needed for a good anchor for the bungee launch hook. There is nothing like sending the nose of your plane and radio gear down the field with the rest of the plane still on the deck . The blue foam is the way to go for easy fast and very curvy shapes. You can crash it every time like me and jsut take the 5 min epoxy to the field in force . Oh, if you do use foam and dont already know, regular CA glue is corrosive to the foam, and so are regular spray paints , so make sure all your glue and spray paints are foam safe like Testor. Kevin suggested to me to make the duct work out of construction paper and to keep it very straight forward to start. Make sure you use a good round intake lip too. Fuel tube works well. EDF is funny because just trying to throw something together for testing is often the big mistake. You need to make the best of every advantage you can just to get airborne. Kevin was offering his F-18 plans on this board, I jumped on the chance to see the guts of one of his jets to learn more, I suggest doing the same . Good luck, keep us posted and dont give up! I love building these jets so much I dont even mind if they dont fly because it just makes me more determined and satisfied when they finally do! Sorry about rambling, too much coffee .
JasonJ is offline Find More Posts by JasonJ
Old May 25, 2001, 09:57 AM
Christian Abeln is offline
Find More Posts by Christian Abeln
Master of Desaster ;)
Christian Abeln's Avatar
Dreieich, Hessen, germany
Joined Jun 1999
Hmmmm think the B-2 plans over...
Were building one and trust me:
If you arent into mathematics you will have problems flying this baby without vertical stabilisers...
We calculated the hell out of our brains and it seems like we finally found a solution
just to look how complex such a thingy can be have a look at: www.jet-connection.de
click on projects then on B2...
sorry I did not manage to make an english version, but Im working on it
Chris
Christian Abeln is offline Find More Posts by Christian Abeln
Old May 25, 2001, 10:00 AM
Joined Jun 1999
-> Maybe that was me
Old May 25, 2001, 02:00 PM
TimOBrien is offline
Find More Posts by TimOBrien
Palm City, FL
Joined Dec 2000
Chris Gould has B-2 plans available at Electric Flight International magazine (EFI) from Traplett. Had a couple of really good construction articles on it.
Anyone getting into EDFs should start reading his articles; he's a former jet jock and has a wide range of plans there from Speed400s to 14' B-52s.
TimOBrien is offline Find More Posts by TimOBrien
Question Building Airframe from Scratch kindred UAV - Unmanned Aerial Vehicles 4 Jul 26, 2007 02:20 AM
Question building a hearse from scratch deadsled Large Scale Cars 5 Oct 14, 2005 01:42 PM
Building a plane from scratch karpar The Builders Workshop 8 Dec 26, 2004 08:55 AM
Building a Flying wing from scratch LyndonC Foamies (Kits) 2 Jun 29, 2001 08:15 PM
