Old Feb 17, 2006, 10:45 AM
mrbaseballny is offline
Find More Posts by mrbaseballny
mrbaseballny's Avatar
Joined Sep 2004
Increasing Tx range underwater
I have read that R/C Submarines aren't able to go very deep due to the radio waves not being able to go very far through the water. What if a wire like what the full size subs use for sonar is trailed behind the sub? would this increase the depth that the R/C subs can go? Has this been tried before? and if so where can I read more about this?
Thanks for any help
mrbaseballny is offline Find More Posts by mrbaseballny
Old Feb 17, 2006, 11:54 AM
d3snoopy is offline
Find More Posts by d3snoopy
Joined Aug 2005
Good idea, but unfortunately it won't help you much. The reason has to do with radio waves. Radio waves lose power (amplitude) as they travel distances. this is called Attenuation. Now Attenuation is affected by 2 things: the medium that the wave is going through, and the frequency of the signal. A radio wave loses power a whole lot more quickly in water than it does in air. (Like 10-100's of times faster.) So, that's why radios have limited range in water, because going through a few feet of water just totally nerfs the signals power, and the reciever can't pick it up. (The signal attenuates even faster in salt water than in fresh water- thus why you pretty much can't run RC subs in the ocean except if you have the antenna sticking out above the water.) Now, the other part that effects attenuation is the frequency of the signal. Low frequency signals tavel a whole lot better than high frequency signals. That explains why real subs can recieve signals under water- because they are sent to them at really low frequencies. This is impossible for remote control subs, because of a number of things. First, the length of the antenna would have to be miles long. In order for an antenna to work right, it has to be at least the wavelength of the signal. At the really low frequencies that travel well in water, this means that the antenna would literally have to be miles long. Second, you would have an incredible amount of delay between when you input a control, and when the sub responds. I won't get into the details of that, but at those frequencies it would take in the order of minutes for the sub to respond to a control input. Third, the government won't allow it. The FCC has all the frequencies from ultra low to ultra high mapped out and certain frequency ranges are mapped out to certain things. Why? So that interferance doesn't happen. If you have someone trying to control a radio control plane on a certain frequency, and a radio station is transmitting on the same frequency, the plane will think that the music is instructions for it and it'll start dancing and most certainly crash. (Ok, maybe it'll just start acting really wierd and crash.) So, you have to stay within the ranges that the FCC says you have to- namely 27 or 75 mHz. (For ground, airplanes run on 72 mHz radios.) You can increase the length of your antenna, but it will only help you if you have part of it sticking out of the water. (I would suggest keeping the length at a multiple of it's current length.)
d3snoopy is offline Find More Posts by d3snoopy
Old Feb 17, 2006, 12:01 PM
HelloMoto is offline
Find More Posts by HelloMoto
Ohio, IL
Joined Feb 2006
How deep do you want to go?
HelloMoto is offline Find More Posts by HelloMoto
Old Feb 17, 2006, 01:05 PM
Joined Sep 2004
Thanks for the explaination. I was lookingto go no more than 10 feet or so
Old Feb 17, 2006, 01:42 PM
Ohio, IL
Joined Feb 2006
Standard radio gear will get you to at least double that without problems (in fresh water)
Old Feb 17, 2006, 03:19 PM
Joined Sep 2004
Oh, alrighty then, I guess I'm set
Thanks for the help!!
Old Feb 19, 2006, 06:58 AM
Nixie is offline
Find More Posts by Nixie
Nixie's Avatar
Joined Jan 2006
This Australian radio amateur has researched the topic. Have a look at this page:
http://www.qsl.net/vk5br/UwaterComms.htm
Nixie is offline Find More Posts by Nixie
Discussion UBEC causing reduced Tx range rickyblaze Electric Heli Talk 17 Feb 14, 2007 09:34 PM
Question Tx range issues PatientZero Electric Plane Talk 5 May 05, 2006 03:42 PM
Increasing a planes range...can it be done by.. rumme Electric Plane Talk 10 Oct 03, 2005 06:46 PM
Question frequency multiplier: increase bit-tx range? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Jul 31, 2005 05:10 PM
Tx range RichD Electric Plane Talk 2 Oct 25, 2001 01:15 AM
