| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
Horizon Hobby's Hangar 9 Brand Harmon Rocket RV-6 .46 ARF w/ EVO 46 Review
Based on John Harmon's Lycoming-powered record setting(256.376 mph) conversion of the venerable RV4, the Seagull Models Harmon Rocket .46 ARF is an affordable scale sport plane that flies as good as it looks!
Kit Includes:
Kit Requires:
AssemblyAlthough I've built and flown many park flyers from pattern to 3D, this was the first glow plane I've assembled, and in some ways it was easier to build than a park flyer since everything was bigger! I had some help during the build from a good friend and experienced glow flier, and throughout the build, we were very impressed with the overall quality and ease of assembly of this ARF. The Rocket was a very straightforward build with a good instruction manual that had lots of pictures to make the assembly process smooth. I can't say enough about what a joy this model was to build!
Ready to fly
Unlike many planes I've built, once the CG point was determined, we were very surprised and pleased to find that no additional weight was required, and the Harmon Rocket balanced perfectly!
FlyingThe engine used for this review was the new Evolution .46 2-stroke from Horizon Hobby. Most of my flying experience to this point has been with park flyers, so I was a little intimidated with the size and power of this model at first, but I must say that the Harmon Rocket was an absolute joy to fly. The maiden flight was made on a beautiful winter day in Texas. The wind was light and the sun was bright, perfect flying weather. The Rocket's control throws were very positive and definite. Evolution recommended an 11x7 APC prop, and I found the recommended propeller to be a great choice for this engine and plane combination. The Evolution engine started quickly and easily and was very reliable. I flew at half to three quarter throttle most of the time, and the motor's performance was excellent. As mentioned before, the balance was also just right, no balance weight had to be added to either end. I was able to throttle back comfortably with this combination. Flight times of about 12 to 15 minutes were no problem. After a few minutes, I took her up to a safe altitude and throttled back to induce a stall, and I was pleasantly surprised to find that the Rocket slowed to a crawl before the stall began, and it was very mushy and predictable.
Taking Off and LandingThe plane was very well behaved on the ground and did equally well once airborne. The strip at our club field is grass; to taxi and for more positive control in turning on the ground I used a touch of up elevator. Taking off was a piece of cake, and I needed only one click of down elevator trim once airborne, all other trims were perfect. Landings were easy as the Rocket settled right in with a nice glide slope with the engine at a fast idle.
Aerobatics/Special Flight PerformanceThe Harmon Rocket was fully capable of rigorous aerobatics. Axial rolls, hammerheads, and inverted flight were all possible. We did several loops, rolls, immelmann turns and split S's and they were very scale-like and smooth. Because the Rocket had such a thick wing and some dihedral, I expected it to perform rolls fairly "barrel-like", but I was amazed at how axial they were, much more like a pattern plane! Hammerheads were easily executed also. After I reached a full throttle upline, I throttled back to half and gave full left rudder and the tail kicked right over for a nice, smooth hammerhead. Knife edge flight was difficult to achieve due to the wing's dihedral; the Rocket tended to want to "roll out" each time I tried it.
Is This For a Beginner?Although not for a beginner, from a flying perspective I would have to say that this plane is suited to anyone with some aileron trainer experience. It was easy to control, very stable, and responded gently and predictably. It is definitely not intended for an outright beginner.
ConclusionAs far as the assembly, I would recommend this model for anyone who has any building experience. The manufacturers have done such a great job of pre-building that the more difficult stuff was already done. I really enjoyed building the Harmon Rocket. What a joy to fly! In-flight, the Harmon Rocket had no "bad habits". In many ways, the Rocket reminded me of a low wing Ultra Stick. It appealed to me strongly with its great looks, great color scheme and size. It was easy to transport and easy to see in the air. And it was not just a fine looker but a great flyer as well. If you tend to enjoy an airplane that goes where you point it, you will love this one. It is semi-scale but it managed to capture the essence of the full scale Harmon Rocket III. I just can't say enough great things about the Seagull Models Harmon Rocket III ARF. It assembled quickly, looked terrific, and flew like a true sport plane should. Seagull Models and Horizon Hobby have a real winner with the Harmon Rocket III!
Thread Tools |
#2 |
Grumpa Tom
Excellent review. And what a sweet flying airplane!
THANK YOU for making a video where we can actually hear the engine and NOT a bunch of goofy music instead!
#3 |
I told you once!
Great review Ronnie!
#4 |
way to go!
Parkfiyers to glow sport models
Ronnie, I know you are a good builder but there is a big difference between the two. This really speaks volumes for this model. BTW Watch out for that glow fuel it can explode on you if you don't handle it properly. Great review! keep it up. Last edited by sparks; Feb 17, 2006 at 09:15 AM. Reason: backhand |
#5 |
Will fly for food...
I have this plane and the name is very descriptive!
Great review and I enjoyed the movies! I have this plane also and it is SO MUCH FUN to fly! It's a little hard to see in the distance so I put orange dayglow tape on the bottom of the wing to help with orientation. I have a Magnum 52 on mine.Thanks again for the review!
#6 |
Great job Ronnie, I hope you get all that stinky stuff off you!
![]() This is making me want to finish my Sig Kougar! Mike |
#7 |
Ronnie great review and what a nice looking model ! That glow fuel does give that size model and above the advantage in power for those who can't afford Lipo's for that size plane. Looking forward to your next review! Johnathan
#8 |
I want one ! This will be my 2nd year flying if the wind ever stops and the temp ever goes up . It was -7 with a wind chill of -27 when I looked a little bit ago
. I was flying a Duraplane trainer and a Balsa trainer last season . Do you think this plane would be a good first low wing for me ? I still have the Duraplane the balsa trainer R.I.P. . I also thank you for not putting some goofy music on your video I much rather hear the engine . I have an OS .46 AX waiting for a plane .
#9 |
Size Matters!
I've been trying to resist!
Is it available in blue????
![]() Great review Ronnie! |
#10 |
"Have Glue - Will Travel"
Hobie,
The Harmon Rocket would be an excellent first low wing plane. It is a rock solid flyer. Thank you Rob! Ronnie |
#11 | |
#12 |
Hi,
Has anyone built this plance with a 4 stroker? If so, which one? Any complications on the installation? Ken |
#13 |
Size Matters!
saito fa 82 13x7 apc
Strengthen the horiz stab (the weight rear won't hurt you) Carbon gear off the funtanna 60 series I put the servos in the bay behind the wing and patched the covering. The 2300mahr rx pack is on forward servotray. Larger fuel tank - don't remember size though Flys very well and the saito - enough has been said about this engine. |
#14 |
ProBro #2797
I just baught one from RCU, NIB! This is a great ARF with quality matching or surpassing GP or H9 ARFs. I was very glad to find it as I've been wanting a little brother to go with my GP 1/4 RV-4!
I'll be strapping a Saito .72 to its nose, but im torn on what prop to use... I swung a 12x8 Evo prop when the motor was on my Pulse 40 (RIP) but im wanting a little more speed, so how would a 10x10 work? Or should I go with an 11"? Im also going to be doing some mods, like an aluminum spinner because the red one included doesnt match the red covering, im going to eitehr paint to cover teh stock gear white, and i'll be adding a 'U' wire to the elevators so I only have to use one servo for the elevator as my radio will not allow me to mix or trim individually to get equal throw from each up and down. I might add a bigger tank too as I have tons of 11oz. tanks from old H9 planes that have sense bit the dust, or that I have added bigger tanks to. Are there any mods to the airframe I should do? Rob, I see you said you strengthened the horiz stab, what did you do to it? |
#15 |
Jake - I also went with one servo on the elevator. Used the U wire and then epoxied a short length of CF rod to the wire for further strength and to resist wire torquing.
I use 4-40 control rods as flying wires to tie the v/stab to the h/stab. Top side only. Some say you have to do both top and bottom but mine seems to be working well. Front gear is junk and way too thin. I replaced with gear off the Seagull Spacewalker. About 30% thicker and very similar size. About $9 as I recall. Just had to drill new attaching holes. Also, put some poly varish over the gray paint on the motor box - it does not hold up to fuel very well. Good luck! Ken |
| Thread Tools | |
| Article Horizon Hobby's Hangar 9 Brand P-47 .60 sized ARF Review | tailskid2 | RCPowermag Archive | 12 | Mar 08, 2009 10:33 PM |
| Article Horizon Hobby's Hangar 9 Brand Ultimate Trainer P-51 Mustang PTS ARF Review | raythomas | RCPowermag Archive | 10 | Mar 04, 2009 12:17 AM |
| Article Horizon Hobby's Hangar 9 Showtime 3D ARF Review | Steve H. | RCPowermag Archive | 5 | Sep 01, 2007 06:59 PM |
| Article Horizon Hobby's Hangar 9 Brand P-40 ARF Review | tailskid2 | RCPowermag Archive | 3 | Nov 14, 2006 02:06 AM |
| Article Horizon Hobby's Hangar 9 Brand Twist . 40 & Evolution 46 ARF Review | Mendnwngs | RCPowermag Archive | 13 | May 11, 2006 08:39 AM |
