Old Feb 15, 2006, 11:05 PM
T.J. Kong is offline
Find More Posts by T.J. Kong
T.J. Kong's Avatar
Northern California
Joined Feb 2004
Question
Do I have the wrong idea about setting throttle curves?
From what I have read, the maximum rpm that you would want to set your throttle curve to would be the max rpm that your motor can produce at maximum pitch. I'm running two different helicopters with proven motor/pinion/battery combinations and I cannot achieve the same headspeeds as others. The setups are:
Trex, 325 blades, + 10 degrees pitch, Neu 1105, 9t pinion, 4s TP 2100, CC35 max rpm 2370
3DPro, Stock blades, +10 degrees pitch, 400DH, 8t pinion, 3s TP 1320, CC25, max rpm 2000
I have checked both setups on governor high and fixed throttle and obtained the same results. Both of the rotors spin quite freely and there appears to be no excess friction in the drive train. Can anyone suggest what I might be doing wrong? Thanks.
T.J. Kong is offline Find More Posts by T.J. Kong
Old Feb 16, 2006, 01:31 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Remove pinion, then check if the ESC light is turning on at full throttle.
Toshi
TMorita is offline Find More Posts by TMorita
Old Feb 16, 2006, 05:24 AM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Toshi. The light means it is at full throttle?
Greybird is offline Find More Posts by Greybird
Old Feb 16, 2006, 06:33 AM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
I think Toshi's point is to check that 100% on the throttle curve of the TX (or possibly less than 100%) lights the LED on the ESC.
If you cannot get the LED to light when the TX believes it is at full throttle then the ESC is NOT at full throttle - so there may be a lack of power / HS.
ukgroucho is offline Find More Posts by ukgroucho
Old Feb 16, 2006, 10:37 AM
T.J. Kong's Avatar
Northern California
Joined Feb 2004
Thanks Toshi,
I didn't think that you should run a motor at full speed without a load. So, it's ok to do that for a short period?
Old Feb 16, 2006, 10:59 AM
T.J. Kong's Avatar
Northern California
Joined Feb 2004
UKgroucho-
I just read in another thread that you run the 1105 on 4s. What headspeed do you run and does it bog down at full pitch?
Old Feb 16, 2006, 12:55 PM
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
I'm running around 2600 - 2700. I've only ever tacho'd it at zero pitch (doing it on my own, holding heli ... there was another complete thread on this lunacy).
Anyway.. yes you can bog it a little if you do something really agressive - typically it's when I'm trying to recover from some kinda 3D mess up and it's heading for the deck at speed. But in general... no it maintains that HS.
The TP2100 is very good as well... I only see the 'bogging' with the old PQ 1800s which I think are 12C -16C... I just don't think they can deliver the amps when it really gets tough.
I'm running basically what you state - 9t, 325 pros, HS56s on cyclic, 401 and 9650. Kontronik Jazz ESC
Do I have the wrong replacemtent motors opforr BladeRunner Heli 14 Jan 30, 2005 10:18 PM
Do I have the wrong flight pack? NoVaNewB Parkflyers 10 Mar 03, 2003 11:14 PM
Throttle curves - Why do we need Žem? Allex Electric Heli Talk 8 Jan 19, 2003 05:09 PM
why do you need throttle curves jared salbato Electric Heli Talk 6 Sep 25, 2002 02:36 PM
Bought a 400X and I have no idea what to do Joe B Foamies (Kits) 8 Mar 02, 2002 11:31 PM
