Old Jun 20, 2002, 05:16 PM
FX1SUB is offline
Find More Posts by FX1SUB
Green Member
FX1SUB's Avatar
NJ
Joined Mar 2002
How do I check Amp draw?
I keep hearing how this motor combo draws x amount of amps and so on. Is there a website that explains all of this and how to check amps. I feel silly asking this since I already have three well flying planes, but I guess it's time to learn how the motor systems work. Hope I'm posting this in the right place...Thanks
Joe
FX1SUB is offline Find More Posts by FX1SUB
Old Jun 20, 2002, 05:42 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
You either need a watt meter or a multi meter. Very few multi meters can measue more than 30 Amps. If your stuff is smaller and draws less than 20 A, than a sears multi meter is fine, to measue current, you have to break the circuit and put the meter in series with the motor. There are some half decent low $ inductive meters out there that just clip around the wire and measure the strenght of the magnetic field to give current and are fairly accurate.
Most of the big advertisers here on the zone like hoby lobby sell watt meters for RC modeling though at a good price.
JasonJ is offline Find More Posts by JasonJ
Old Jun 21, 2002, 10:09 PM
YVR is offline
YVR
Find More Posts by YVR
YVR
Sean in YVR (Vancouver)
YVR's Avatar
Vancouver, BC
Joined Sep 2001
You want an Astroflight Whattmeter. If you're at all serious about electrics, you'll find it an invaluable tool for testing different setups (cells, props, motors). You can put whatever connectors you use on it and simply plug it in between your battery and esc. The display will give you amps and mah used. They come up occasionally in the For Sale forum, but they're always snapped up immediately. You won't know how you lived without it!
Sean
YVR is offline Find More Posts by YVR
Old Sep 06, 2002, 02:13 PM
rplourdejr is offline
Find More Posts by rplourdejr
Joined Dec 2000
I cannot seem to find any info telling the difference between Astroflight's Watt Meter and the Micro Watt Meter.
Anybody know what that is?
Rob
rplourdejr is offline Find More Posts by rplourdejr
Old Sep 06, 2002, 04:21 PM
4 Scale is offline
Find More Posts by 4 Scale
Trampling out the vintage
Joined Feb 2002
When I bought my Astro Wattmeter from Kirk at New Creations he said that the micro is for very small motors, such as used on indoor, and the regular Wattmeter is for parkflyers and up. Mine does a good job measuring current etc. to at least as small as the GWS A motors, which is as small as I go. I agree this thing is really needed if you are serious at all about electric flying. It is both fun and easy to use. I have a multimeter too and that is more of a pain to use.
4 Scale is offline Find More Posts by 4 Scale
Old Sep 06, 2002, 04:38 PM
mimai is offline
Find More Posts by mimai
North Vancouver, BC, Canada
Joined Jun 2001
The micro watt meter measures 0 to 15 amps to 2 decimal places. I don't know the upper limit for the regular watt meter but it displays only to a single decimal place.
The advantage over a multi-meter is the watt meter displays amps, volts and watts at the same time.
The micro watt meter should be able to measure up to speed400 size except for the jst connectors supplied.
mike i.
mimai is offline Find More Posts by mimai
Old Sep 06, 2002, 05:00 PM
cactus is offline
Find More Posts by cactus
Micro Fpv=BVLOS around couch
United States, CO, Durango
Joined Sep 2001
The great thing about the AstroFlight Whattmeter is the ability to see what the amps are pulling at different throttle settings. I use this along with the (60 * ah)/ Amps = Duration in Minutes to get an Idea of what i should set my timer to on my Tx for when to land
I also use it to charge batteries with capacities under 1ah due to the inacurate display by the 110D charger I use.
Its a great tool!
cactus is offline Find More Posts by cactus
How to check amp draw? Jason Paul Power Systems 4 May 23, 2005 12:20 AM
how do I test the amp draw on my lipo batt jim florentine Batteries and Chargers 7 Nov 29, 2004 12:38 PM
Question How do I lower the AMP draw? Shogun thewz Mini Helis 5 Sep 10, 2004 05:30 PM
How do i measure amp draw? moocowfish Electric Plane Talk 5 Aug 25, 2004 07:39 PM
How do I measure Amp draw? buzzbee Beginner Training Area (Aircraft-Electric) 5 May 23, 2004 12:40 PM
