Old Jul 08, 2013, 08:22 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Originally Posted by Wobisch View Post
Hi folks
My Eagle is airborne. Having no supporter I decided to handlaunch my F-15. Almost full throttle and here we go.
Installed a WingCam from HK and will report the whole flight as soon as the files are downloaded.
My Bird was a little tail heavy and after 6 minutes of flying I recognized a different speed on full throttle. I landed and had to cut out the battery which was seriously hot and short before melding! Cooled it down with my car's air conditioning.
Glad it did not acturally catch fire in the car - that would have been
Looking forward to the flight video.
Still, all is well that ends well .... Mike
empeabee is offline Find More Posts by empeabee
Old Jul 08, 2013, 09:18 AM
Wobisch is online now
Find More Posts by Wobisch
fortuna favet fortibus
Wobisch's Avatar
Schweiz, AG, Merenschwand
Joined Oct 2011
herewith the link
Shumate F-15 Eagle Maiden flight (5 min 44 sec)
Wobisch is online now Find More Posts by Wobisch
Old Jul 08, 2013, 09:24 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Looks and flies great.....nice job Wobisch!
DamonH is offline Find More Posts by DamonH
Old Jul 08, 2013, 09:43 AM
Wobisch's Avatar
Joined Oct 2011
... I was aware of that and did held the battery in my hand after some cooling down in the shadow first.
Old Jul 08, 2013, 10:49 AM
empeabee is offline
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Ah I'm preaching to the Converted - sorry.
The Video looked fine, though at times it did seem that the rear deck was flexing quite a lot at high G.
Thank you for posting, all in all a very good flight & good looking model.
Old Jul 08, 2013, 06:58 PM
gbman is offline
Find More Posts by gbman
United States, TN, Arlington
Joined Jan 2005
Elevator linkage problem
Maidened my F-15 this afternoon, first two flights went way better than I anticipated. Third flight the elevator seemed a bit mushy right off the bat so I got her on the ground as soon as possible. The control horn has come loose from the carbon fiber stabilator rod. I had a very good friction fit before gluing the horn to the rod. Also cleaned both surfaces with denatured alcohol. Thin CA and kicker. Any suggestions for securing the control horn to the stabilator rod? I could drill a fine hole through the horn and carbon fiber rod then put a pin through both to keep them in line. My concern would be compromising the integrity of the carbon fiber rod by drilling a hole through it. Any suggestions? Thanks!!
gbman is offline Find More Posts by gbman
Old Jul 08, 2013, 10:31 PM
pistnbroke is offline
Find More Posts by pistnbroke
absolutely maybe
pistnbroke's Avatar
Australia, WA, Currambine
Joined Apr 2011
Great job Wobisch!
Regards
Ian
pistnbroke is offline Find More Posts by pistnbroke
Old Jul 08, 2013, 11:06 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Contrats on the maiden. CA the horn to the CF rod just like you did before. You don't want it too solid. These elevators are prone to ground strike if you don't release the stick on landing. The CA provides enough strength for mild abuse but fails if hit hard (which is what you want). otherwise next time it will be your servo gears that strip and that's a bigger problem to fix. Just take a bottle of thin CA with you to the field for those less than perfect arrivals
If you really feel you want the extra strength I suggest the CA first, then when it's dry, mix some 5min epoxy and make a "trap" around the base of the horn.
vanderbrander is offline Find More Posts by vanderbrander
Old Jul 09, 2013, 12:18 PM
gbman is offline
Joined Jan 2005
Thanks vanderbrander! I've CA'd the horn and topped it off with some 5 min epoxy with micro balloons. Now I just have to hope it holds in the future. Appreciate your input!
Old Jul 13, 2013, 09:51 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
+1 on the micro balloons. That should keep it secure. Cotton Flox would be good as well.
jetcaptain is offline Find More Posts by jetcaptain
Old Jul 17, 2013, 01:59 PM
gbman is offline
Joined Jan 2005
I've been to the field twice since the elevator repair. 10 flights and everything is holding up well. Enjoying the F-15 as I've grown more accustomed to flying her. Thanks again for the repair suggestions.
Old Jul 18, 2013, 02:21 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
wobisch and pistnbroke - Congrats! Great looking models and nice flying on both!
gbman - Yes, I have had some trouble in the past with that linkage coming undone as well. Never in flight, just in landings on tall grass or hangar rash. I now use thin CA for the initial glue-in, and then a light coating of epoxy all over the intersection. Haven't had one break loose since.
jetset44 is offline Find More Posts by jetset44
Old Jul 18, 2013, 02:22 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Yet another reason for JetSet44 to smile. and the rest of the world as well
Yes, I got a smile both from that great landing and from this comment!
Old Aug 03, 2013, 03:46 AM
Wobisch's Avatar
Joined Oct 2011
Father and Son had some fun
Today I wrecked my F-15. She broke in two pieces just behind the wing.
Men, that impact was hard. During a flyby I hit the ground! Video is in production. F-15 is reparable. Have to change some things. She is tailheavy and thrust us not enough. Glass coating of the bottom was excellent. Otherwise I would have build a new bird.
Old Aug 03, 2013, 12:02 PM
Wobisch's Avatar
Joined Oct 2011
My Video inclusive Crash
F-15 Eagle Parkjet (1 min 42 sec)
Build Log F/A-22 Raptor Park JetóPart 2 jetset44 Pusher Prop Jet Models 1598 Aug 21, 2016 03:21 PM
Mini F-15 Eagle Park Jet Build LBMiller5 Pusher Prop Jet Models 31 Jul 20, 2016 09:35 PM
Discussion Saturday jet movie F-15 Eagle fullscale speleopower Electric Ducted Fan Jet Talk 3 Mar 11, 2006 08:57 PM
Mini-Review F-15 Eagle Park Jet jetset44 Pusher Prop Jet Models 2598 Feb 15, 2006 02:12 AM
Alert F-15/18 Park Jet (EDF) Questions MLaCoste Electric Ducted Fan Jet Talk 16 Nov 05, 2004 01:55 AM
