Old Dec 04, 2011, 06:19 PM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
my question is still same, forget about flying the plan and adjust elevator, i m concern about CG
. 1 : in video when i fly yes its go up (elevator was in normal setting )
. 2 : i did it trim up ( so from tail side it should up " force plan to move down ")
question is that if i go to actual CG which is as per plan 2.9 (cuz my length is small)
plan already heavry from nose as you can see in video so why when i fly it its going up ? showing its tail heavy,
i can not move batter more forward cuz 2.9 cg showing alrady heavy from nose
if i pull battery back , then that mean when i will fly plan it will more heavy from tail
ahh lot of confusion.
its flying good with CG 2.1 and elevator trim up (arround 10degree or 15degree up)
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Dec 04, 2011, 08:15 PM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Up elevator forces the tail Down, to lift the heavy nose up. You can get the same effect by moving the battery back towards the tail and reducing the Up elevator trim.
A little bit of aerodynamics.
The faster you go, the elevator becomes more powerful and with the large elevator trim you have, if you dive and go faster, so the nose will come up automatically, and you have to push the nose down to stop this zooming up. If you move the batter back (a small bit at a time) you will be able to reduce the Up trim, so reducing the effect of speed variation.
There will come a point where you get the balance point too far back, and the aircraft will become very sensitive to elevator control, and become difficult to fly - your balance point is now too far back.
Many trainer aircraft are setup nose heavy because it is self stable, as the speed goes down, so the nose drops the increase the speed, and as the speed increases the nose rises to reduce the speed, which is good while you are learning to fly, but this make aerobatics difficult, and people then move the balance point backwards (a little at a time) as their skill increases. But even the best pilot in the world will fail to fly an aircraft with its balance point too far back, which is why I said move the balance point back s l o w l y.
Hope this helps
empeabee is offline Find More Posts by empeabee
Old Dec 05, 2011, 04:31 PM
is there any one who is using 2200MAH Battery for this plan and have pic to show where is his batter location?
Old Dec 05, 2011, 04:40 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Aqeel,
A lipo that big can be used, but you have to shove it way far back to make the CG. A different size of battery won't change where the CG needs to be located. You just need to find the proper CG first, then place the lipo in a position that makes the plane balance on the proper CG point.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Dec 10, 2011, 02:04 PM
Won2Race is offline
Find More Posts by Won2Race
Won2Race's Avatar
United States, MA, Boston
Joined Jun 2006
Im using one that big. The battery needs to be at the very back of the cockpit area for balance. I like the longer flight times but I do notice the extra weight, though.
Won2Race is offline Find More Posts by Won2Race
Old Dec 21, 2011, 12:50 PM
jhi is online now
jhi
Find More Posts by jhi
jhi
jhi's Avatar
Norway, Sogn og Fjordane, Naustdal
Joined Jun 2009
Steve Shumate's "F-15 Eagle" - maiden
Hi all!
Motor: RCTimer 2212-6 http://www.rctimer.com/index.php?gOo...6&productname=
Servos: RCTimer MG9025 http://www.rctimer.com/index.php?gOo...8&productname=
Battery: Turnigy 1.6Ah nano
ESC: HobbyKing HW30A (25A - max.30A)
Propeller: APC style 6x4 (pusher)
Radio: Futaba T7C (programmed with "Flaperon mix" and "Air brake")
AUW: 22.3oz (632g)
Again, thank you Steve Shumate for your plans, excellent drawings and instructions! Easy to follow and makes the building process a joy. This is my third depron model, previously I have built the Polaris and the Sukhoi SU-37.
Maiden yesterday, and I have mixed feelings. Not because of the plane, but because of my flying! I have decided to include the entire maiden flight, hoping to receive some good advice from the experts. I was tempted to take the plane up again at once, but resisted, I felt that I had had spent all my luck for one day.
You can see I had no control at around 60s on the video. After two right turns it started to become boring and I wanted to make a left turn . Maybe because of too much throw combined with a lot of expo (40%) things got out of hand, and I nearly crashed. For a second or two I could not see the plane but kept flying - throttled up, a little up elevator and to my surprise I could see the plane again! The aileron throw is about ±38mm, and elevator is ±35 - Steve's recommodation is ±1 1/2" (38mm) and ±2" (51mm). How much throw do you have guys?
Takeoff. The propeller is a APC 6"x4" pusher (turning left), so I got an expected right roll right after launch. I guess it is normal since I probably used too much throttle (got too excited!), but could easily correct in time. Next time I shall try with less throttle..
/Jan
F-15 Eagle maiden.mp4 (3 min 25 sec)
Here are some photos of my F-15 Eagle as "required" by Steve
jhi is online now Find More Posts by jhi
Old Dec 21, 2011, 02:15 PM
al_cappuchino is offline
Find More Posts by al_cappuchino
al_cappuchino's Avatar
Germany
Joined May 2009
well done, great plane :-)
al_cappuchino is offline Find More Posts by al_cappuchino
Old Dec 21, 2011, 02:47 PM
DanielMadrigal is offline
Find More Posts by DanielMadrigal
Falcon's rc
DanielMadrigal's Avatar
USA, GA, Byron
Joined Apr 2009
nice looking plane jhi
DanielMadrigal is offline Find More Posts by DanielMadrigal
Old Dec 21, 2011, 02:56 PM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
Yes, both look cool to me? A bit of torque roll perhaps on take off? Also, maybe reduce your elevator throw or use some expo? Other than that it looked cool? But I am a long, long way from being any kind of expert pilot!!! Good lookung models/lovely flying site!
electriceye is offline Find More Posts by electriceye
Old Dec 21, 2011, 05:34 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Really nice F-15. Great job shaping the nose cone.
jetcaptain is offline Find More Posts by jetcaptain
Old Dec 21, 2011, 07:42 PM
awesome..
Originally Posted by jhi View Post
Hi all!
AUW: 22.3oz (632g)
Again, thank you Steve Shumate for your plans, excellent drawings and instructions! Easy to follow and makes the building process a joy. This is my third depron model, I have previous built the Polaris and the Sukhoi SU-37.
/Jan
https://www.youtube.com/watch?v=kzM9R6xrGYo
Old Dec 21, 2011, 10:30 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Great looking model, jhi, and you're welcome for the plans! In the video, it looks like it fly fine before and after the incident at the 60 sec mark, so my hunch this was just pilot disorientation, possibly combined with excessive stick inputs. That's easy to do with a white model against a snowy white background! And yes, roughly 60% throttle is all you need to get in the air smoothly and without torque roll.
Thanks for the pics and video! And good luck on the second flight.
Steve
jetset44 is offline Find More Posts by jetset44
Old Dec 23, 2011, 05:53 AM
jhi is online now
jhi
jhi
jhi's Avatar
Joined Jun 2009
My F-16 Eagle maiden.
Thank you all for nice comments and good advice!
I have lowered the R/C rate a little and also reduced previous -40% expo (Futaba) to -35% expo. To help with orientation I also painted some more under the wings - similar scheme to the one above the wing. Waiting for weather to improve, too windy and rainy at the moment - fingers crossed.
Merry Christmas and fly safe!
/Jan
Old Dec 27, 2011, 10:16 AM
Germany
Joined May 2009
F-15 Crash
Hello Friends,
my 100% F-15 crashed today.
I have to bulild a complete new forward fuselage:
Nosecone
Forward Fuselage Side
Bulkheads...
Old Dec 27, 2011, 05:24 PM
rcflyer50 is offline
Find More Posts by rcflyer50
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
Beautiful plane and beautiful country!
rcflyer50 is offline Find More Posts by rcflyer50
Build Log F/A-22 Raptor Park Jet—Part 2 jetset44 Pusher Prop Jet Models 1597 May 03, 2016 10:21 PM
Mini F-15 Eagle Park Jet Build LBMiller5 Pusher Prop Jet Models 29 Apr 23, 2010 08:19 AM
Discussion Saturday jet movie F-15 Eagle fullscale speleopower Electric Ducted Fan Jet Talk 3 Mar 11, 2006 08:57 PM
Mini-Review F-15 Eagle Park Jet jetset44 Pusher Prop Jet Models 2598 Feb 15, 2006 02:12 AM
Alert F-15/18 Park Jet (EDF) Questions MLaCoste Electric Ducted Fan Jet Talk 16 Nov 05, 2004 01:55 AM
