Old Oct 14, 2011, 12:48 PM
CBflyguy is offline
Find More Posts by CBflyguy
6mmFlyRC
CBflyguy's Avatar
Joined Aug 2005
Great looking model. A personal favorite.
CBflyguy is offline Find More Posts by CBflyguy
Old Oct 16, 2011, 10:56 AM
al_cappuchino is offline
Find More Posts by al_cappuchino
al_cappuchino's Avatar
Germany
Joined May 2009
Hi There,
The Canopy is scratchbuildt bu using what we call "Schrumpfschlauch" the material you use when you put your Batteries together, may be shrink tube is the right english word,
The Pilots also made scratchbuildt by depron.
The F-15 is a great flyer, it also loves wind.
Yours Al
al_cappuchino is offline Find More Posts by al_cappuchino
Old Oct 16, 2011, 12:20 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Al, your cockpit and canopy look great!!!! Your pilots too... Yes, the F15 is a great flier, it was my first foam jet I built.. w.
Waltjg is offline Find More Posts by Waltjg
Old Oct 16, 2011, 12:35 PM
Germany
Joined May 2009
Hi,
I made another gimmick for the F-15
An afterburner (LED)
Old Nov 13, 2011, 11:25 AM
MSMRCK is offline
Find More Posts by MSMRCK
MSMRCK's Avatar
Italia, Piemonte, Torino
Joined Sep 2008
My F-15J
Here is my F-15J from Steve Shumate plans
Maiden flight yesterday: flies well , only a little underpowered!
Some data:
weight 571 grams
motor Turnigy TR 28-26 1900kv
propeller 8 x 3,8
ESC 18A
battery 2S1P 1550mAh
I will try with another prop, maybe with 3S1P, or another motor...
Any suggestion for a motor in the HobbyKing range?
massimo
(TORINO Italy)
MSMRCK is offline Find More Posts by MSMRCK
Old Nov 13, 2011, 11:58 AM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Great work, massimo! I think that's the first F-15J paint scheme I've seen in this thread, and it looks really nice. Can't help much with the HobbyKing motors, I've never used or even read much about them. But the Suppo 2212-06 motors are now becoming a virtual standard on park jets in this size range. The work great with 6x4 prop and 3s batteries.
jetset44 is offline Find More Posts by jetset44
Old Nov 13, 2011, 04:02 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Massimo,
Try this one. Same specs as the standard Suppo 2212-6 2200kv motor. Fly it with a 30A ESC and an PAC 6X4E prop.
http://hobbyking.com/hobbyking/store...dProduct=12919
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Nov 14, 2011, 12:05 PM
Germany
Joined May 2009
Hi Massimo,
I use this one:
http://www.rctimer.com/index.php?gOo...7&productname=
It works very good with the eagle.
I use 3S 1300 - 1500 Lipo, 30A ESC PAC 6x4
The Motor has 2200 KV
Maybe it ist the same as the hobbyking motor
Al
Old Nov 14, 2011, 12:08 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I would go with Al's suggestion for RCTimer. I've actually had better luck with the Suppo brand than the DYS brand (what HobbyKing sells). I've had a few of the DYS ones throw magnets.
Pat
Old Nov 14, 2011, 01:54 PM
MSMRCK is offline
MSMRCK's Avatar
Joined Sep 2008
Thanks for your help!
massimo
Old Nov 14, 2011, 05:08 PM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
and here is package
http://www.ebay.com/itm/RC-Hobbies-2...item1c0b29faf6
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Nov 23, 2011, 09:42 PM
is there any one who is using or used 2200Mah batter ,can i see a pic of your battery location ?
Old Nov 24, 2011, 01:20 AM
pajlotmato is offline
Find More Posts by pajlotmato
Slovakia, Veľký Krtíš
Joined Dec 2006
Very nice work Massimo, beatifull paint job...
Some data:
weight 571 grams
propeller 8 x 3,8
ESC 18A
massimo
(TORINO Italy)
pajlotmato is offline Find More Posts by pajlotmato
Old Nov 24, 2011, 01:53 AM
Marlbororman is offline
Find More Posts by Marlbororman
United Kingdom, England, Hull
Joined Aug 2011
well i used 2200 battery, but aint got the plane anymore or a pic , but had to mount it pretty far back in the fuz, towards the le of the wing i think. Not sure but think i slotted one of the formers for it to slide in place.
EDIT. Whoops scratch that, a quick search revealed that i did the above on the Jetset f18, sorry.
Marlbororman is offline Find More Posts by Marlbororman
Old Nov 24, 2011, 06:54 PM
Here is my process, still not sure about CG, have to do 1st test flight once good then i will come to paint.
Build Log F/A-22 Raptor Park Jet—Part 2 jetset44 Pusher Prop Jet Models 1598 Aug 21, 2016 03:21 PM
Mini F-15 Eagle Park Jet Build LBMiller5 Pusher Prop Jet Models 31 Jul 20, 2016 09:35 PM
Discussion Saturday jet movie F-15 Eagle fullscale speleopower Electric Ducted Fan Jet Talk 3 Mar 11, 2006 08:57 PM
Mini-Review F-15 Eagle Park Jet jetset44 Pusher Prop Jet Models 2598 Feb 15, 2006 02:12 AM
Alert F-15/18 Park Jet (EDF) Questions MLaCoste Electric Ducted Fan Jet Talk 16 Nov 05, 2004 01:55 AM
