Old Feb 13, 2006, 06:42 PM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Build Log
Depron CAP 10b Design 05-09-06 FIRST FLIGHT! -w- pics!
I like this depron stuff.
So much so that I think I want to build something different.
The hiperbipe proved to me that there is a way of getting a very scale aircraft out of a sheet of "weighs nothing" foam.
So, I'm going to do one of my all time favourite aerobats.
The Mudry Cap 10b - ala The French Connection aerobatics team
Like so..
Once again, designed in Rhino 3d to be as mouldable as possible. Here's where it stands at the moment.
Curare is online now Find More Posts by Curare
Old Feb 14, 2006, 06:48 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
and here is the unrolled cap, ready to be printed out and stuck onto some depron...
Now all I'm waiting on is the depron
Good things come to those who wait!
*impatient*
Old Feb 14, 2006, 08:27 PM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
You gonna share those nice looking plans or hold out on us................Ilove full fuse foamies.......................?
TM
JAM is offline Find More Posts by JAM
Old Feb 14, 2006, 10:39 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
I will once I know that it works man..
Old Feb 14, 2006, 11:30 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
Here's a cute one, yours should be even nicer with full fuse.
http://www.skyhooks.ca/CAP10.htm
MKH
MKH is offline Find More Posts by MKH
Old Apr 02, 2006, 08:16 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
It has begun.
After waiting forever and a day, I finally picked up some depron on thursday.
After my initial misgivings about some parts of my design, I decided to bit the bullet and use 6m for all the tail surfaces, ailerons, formers and a few other odds and sods.
So the shopping list was 2 x 3mm sheets and 1 x 6mm sheet.
I then printed out all of the parts @ 1:1 scale on my work plotter (incidentally a B1 sheet is the same size as the depron sheets I can buy 1000 x 707.
A quick spray with spray bond, and then whack it down,voila all my templates ready go, just get an exacto and start cutting. You'll also notice some of the stupidy I went to take weight out but leave in rigidity on the formers. Also on the foam templates I left my olding lines to helpe construct the beastie.
Old Apr 02, 2006, 08:27 PM
JAM is offline
JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
I'm with ya' on this one.............I got a bunch of sheets of cellfoam88 waiting to be put to a good use........I hope this turns out cause I want one.
JAM
Old Apr 03, 2006, 12:54 PM
snakeX2 is offline
Find More Posts by snakeX2
Flap chap
snakeX2's Avatar
Most Southern England, Brighton UK
Joined May 2004
Hi, im tackling similar idea of a full fuse depron 3D model for 550 grams AUW, 2200 3S LiPo. What sort of weights are you expecting?
James,
snakeX2 is offline Find More Posts by snakeX2
Old Apr 03, 2006, 07:53 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
Under 300 grams if I can snaffle it but I'm only using a 1500mAh pack, we'll see.
Old Apr 03, 2006, 08:01 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
tape is your friend.
Well, moving right along.
With all of the peices cut out I set about making the right shapes for the fuselage. Getting the rear turtledeck to work is pretty simple as the original had stringer spines clearly visible, so it's a simple task of score with a pen and fold. I then held the shape together roughly with tape, and filled the turtle deck with hot water. Boom, instant hold with no internal stresses.
I then fitted most of the formers and did the front , but the old rolling pin trick to start with and then more hot water.
Voila, one made fuselage, I then put the rear turtledeck spine in, glued the tail together, (cutting the slots for the tailplane AFTER it's cut, so that everything fitsn nicely) and started to work my way up the fuse, gluing in some more formers, checking that it's all straight, at all times.
Old Apr 03, 2006, 08:21 PM
JAM is offline
JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Looks promising sofar......keep up the good work.
JAM
Old Apr 03, 2006, 09:14 PM
JAM is offline
JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Say what's the WS and projected power plant???????
JAM
Old Apr 03, 2006, 09:50 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
Wing span is 1050 and the powerplant is my trusty Himax 2025/4200 on a 5:1 gearing.
I'm hoping a 10 x 6 will make it perform like a pattern ship.
Old Apr 04, 2006, 03:44 AM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Thats sounding very good Curare. What static thrust does your motor setup produce?
J,
Old Apr 04, 2006, 06:04 AM
Driver330 is offline
Find More Posts by Driver330
Altamonte Springs, FL
Joined Nov 2004
Curare,
Are you going to share your plans?
Thanks.
BoKo
Driver330 is offline Find More Posts by Driver330
Discussion Vq Cap 10b statesy Scale Fuel Planes 6 Dec 17, 2010 03:53 PM
Depron Beaver group design/build GIEric Scale Kit/Scratch Built 5 Aug 24, 2005 05:56 PM
F/S Depron CAP from 3DFoamy (local VB area) Ted U Aircraft - Electric - Airplanes (FS/W) 3 Aug 06, 2004 05:12 AM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
