Old Jun 19, 2002, 09:39 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
Can you help me with this?
http://www.rcgroups.com/forums/showt...threadid=47887
Thanks Ray
raythomas is offline Find More Posts by raythomas
Old Jun 29, 2002, 11:19 AM
Seattle Jim is offline
Find More Posts by Seattle Jim
Seattle, Washington,USA
Joined Jan 2001
Hi, Ray. On my small Dumas airboat, I mounted a Dubro Quikswitch in front of the radio compartment on the right side of the deck. My antenna is on the opposite side of the deck, parallel with the switch. This keeps them far enough in front of the prop to avoid any mishaps. (Well, so far!) You don't really need the charge jack - just leave the pigtail loose inside your radio compartment. Since mine is electric, I have to open the compartment every run anyway to charge the batteries. I've found that alkaline cells for the radio are better anyway - I get two months use out of a fresh set. Sure beats charging nicads every week! Hope this helps ....... Jim. BTW, my electric setup - MM Reverse motor, 3.5 gearbox, 10 x 8 prop on 12 cells is awesome. Much faster than the gas version, I'm sure. It's almost out of control! Love it!
Seattle Jim is offline Find More Posts by Seattle Jim
Can you help me with my power supply, please? Flybyguy Batteries and Chargers 3 May 23, 2004 12:36 AM
Can you help me with my power supply, please?! Flybyguy Power Systems 0 May 22, 2004 09:18 PM
Mr. Lin--can you help me with my Chinese, please? Carter GWS (Grand Wing Servo) 12 Mar 01, 2004 11:49 AM
Cool Is it a P-40? Can you help me identify this aircraft temp_oct Parkflyers 1 Jan 04, 2004 11:46 PM
Can you help me with stabilizer design? jdmartin8 Parkflyers 5 May 20, 2001 10:53 PM
