Joined Jan 2002
Rod,
Hope you continue posting these graphs as another standard test to the same protocol for all LiPos. It will give us something to compare our "standard" protocol results to, particularly as regards temperatures reached @ depletion. BTW, have you seen this? http://www.rcgroups.com/forums/showp...1&postcount=58 Best regards, - RD |
Saehan 'ProLite V2' 2100 mAh Burst Profile
The discharge profile I chose to put on them was one that I had seen for one of my electric aerobats: 8 seconds low C discharge (~6C) followed by 2 seconds of high discharge at ~20C - all on a repeat.
The graphs of delivered power, voltage and temperature is shown for this pack, and can be compared to the previous two. Rod |
I rather like the look of these cells given that I attach quite a lot of importance to light weight. Shame about the cell mismatch though.
Rod, do you have any idea if these Hyperion cells are the ProLite V2? They could be the old ones I suppose but is there any obvious way to tell them apart from the V1 (TP) 2100s other than the cell markings? |
1. Run the discharge and look at the volts / capacity 2. Measure the temperature during discharge 3. Look at the cell ID - you would have to dis-assemble the pack for this! All three ways require you to buy the pack! Rod |
15C/20C FMA/KOKAM 2000 3S 'CellPro'
This pack is a relatively new 3S KOKAM 2000 HD 3S 'CellPro' that has seen <30 flights as part of a 3S installation. It has been subjected to some 'abuse' - fully charged I connected a 2S to this 3S pack in parallel for several minutes (by mistake) and generated some 'heat'. So I cannot state for sure how representative it is. It is however useful whilst I'm getting together my thoughts on discharge profiles
I again applied the same profile to this pack (up to its stated 'burst' rating of 20C): 8 seconds low C discharge (~6C) followed by 2 seconds of high discharge at ~20C - all on a repeat. The graphs of delivered power, voltage and temperature is shown for this pack, and can be compared to the previous three. Rod |
OK,
I noticed the lower temperatures on the last run so decided to 'stress' this pack a little more and match current to the two 2100 packs I carried out; to give a 6.5C/21C burst profile (1C higher than stated max 'burst'). Attached below are the usual graphs for a 13A/42A burst profile in 80%/20% ratio. Rod |
