Old Feb 11, 2006, 01:18 AM
FlybyPDX is offline
Find More Posts by FlybyPDX
HeliFreak
FlybyPDX's Avatar
Portland, Oregon
Joined Apr 2004
best pusher prop foamie for beginer???
I am going to teach my GF to fly
I want to teach her with a pusher so when she crashes it will not bend the shaft, break the prop, ect.
I was looking at the easy star... looks like a solid bird.
Any sugestions? Any pushers that are EPP that would be good to start with?
FlybyPDX is offline Find More Posts by FlybyPDX
Old Feb 11, 2006, 01:28 AM
FlybyPDX is offline
HeliFreak
FlybyPDX's Avatar
Portland, Oregon
Joined Apr 2004
it would be nice if one had ailerons too
Old Feb 11, 2006, 01:36 AM
kernelsandirs is offline
Find More Posts by kernelsandirs
Three Mile Pilot
kernelsandirs's Avatar
Las Vegas
Joined Sep 2005
Easy Star is the absolute best possible plane you could teach someone on, very solid, no bad behavior at all, it does not have ailerons by default but it is not too hard to add some, with either FFF, or Balsa.
Check out http://www.mpx-easystar.de/
they have a bunch of mods, including aileron mods.
kernelsandirs is offline Find More Posts by kernelsandirs
Old Feb 11, 2006, 01:54 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
If you want to teach somebody to fly ... keep it simple = no ailerons.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Feb 11, 2006, 02:11 AM
FlybyPDX is offline
HeliFreak
FlybyPDX's Avatar
Portland, Oregon
Joined Apr 2004
I was thinking if it had ailerons I could disable the servo (or not put one in) until ready.
Old Feb 11, 2006, 02:14 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
yea R/E/T would be best to start out... If you have the electronics already, or dont mind buying them, Then my recomendation would be the park shark ( http://www.foamtasticmodels.com/prod01.htm ) You can get it as a kit or plans, its not EPP, but you could build it out of EPP, (in fact im building one out of epp for my daughter now, will have an EPP body and blucor wings) Its super stable, turns great, and is tough... I let my dad fly my first one, he did a full throttle nose dive from about 30 feet (he confused the elevator up/down direction), it crinkled the nose a bit and broke the tail, but 5 min with a hot glue gun and I had it back in the air The park shark has a 32" wingspan VS the 54" span of the easy star, and weighs just over half what the easystar weighs... meaning that smaller batteries will give you longer flights...
dacaur is offline Find More Posts by dacaur
Old Feb 11, 2006, 02:32 AM
Joined Sep 2000
Usually, models equipped with ailerons really need them for proper control. There are few models which deviate from this rule, like the MiniMag for example.
Jürgen
Old Feb 11, 2006, 06:51 AM
bluescoobydoo is offline
Find More Posts by bluescoobydoo
bluescoobydoo's Avatar
harwich essex
Joined Sep 2004
i used a aerobird extreme it flys in strong winds and the spares are cheap it also has a pro and beginner mode so you can get use to how ailerons will handle even though it has not got any plus everything will fit back in the box for transport.
it also has a large wingspan so you can see it in the air, dont let the name extreme put you off it will fly itself in to a landing if you point it into wind
bluescoobydoo is offline Find More Posts by bluescoobydoo
Old Feb 11, 2006, 10:17 AM
Sonofagun is offline
Find More Posts by Sonofagun
J. Titors gr8 grandson...
Sonofagun's Avatar
Charlotte,NC
Joined May 2005
Park Shark.
Sonofagun is offline Find More Posts by Sonofagun
Old Feb 11, 2006, 11:02 AM
sixman is offline
Find More Posts by sixman
worst builder ever!
sixman's Avatar
Eastern colorado
Joined Jul 2003
Easy flying pusher? Look no further than a frog! Tons of info on the build and all kinds of advice right here in the foamies form. An awful lot of people swear by the model. No ailerons, but it flys very nicely without them.
sixman is offline Find More Posts by sixman
Old Feb 11, 2006, 11:06 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
the EZ* is good but needs a big field, because it flies fairly fast and doesn't do tight turns.
RobinBennett is offline Find More Posts by RobinBennett
Old Feb 11, 2006, 12:07 PM
Johnnie_w2 is offline
Find More Posts by Johnnie_w2
Johnnie_w2's Avatar
Humble Texas
Joined Jun 2004
I see that the Frog and the Park Shark have been brought up
Johnnie_w2 is offline Find More Posts by Johnnie_w2
Old Feb 11, 2006, 12:53 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Good job! for your next challenge, can you find 7 unicorns in this thread?
Old Feb 12, 2006, 05:51 PM
Joined Sep 2000
Needs a big field? I have flown mine Indoors at numerous occasions.
Jürgen
Old Feb 12, 2006, 07:04 PM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
I'll vote for the Frog. I made my last one in a profile version. Every kid in the neighborhood has crashed it--including me. When the nose gets too crumpled looking I just cut it off and put on another. Very stable. Great trainer.
FirstShirt is offline Find More Posts by FirstShirt
Discussion Pusher Prop Help for Eskay XT400 Dmerino Power Systems 8 Apr 28, 2007 01:23 AM
Discussion Pusher prop jet for SPEED 400 motor? lolzor Pusher Prop Jet Models 1 Aug 12, 2006 10:23 PM
Discussion Best Motor and Prop Combo for Cox p-47 jewhite23 Parkflyers 1 Apr 18, 2006 06:40 PM
What is the best brushless+prop combo for a magpie eran_k Aerial Photography 2 Jul 14, 2005 11:07 AM
Best Motor/prop/battery for high altitude WickedFunRC Foamies (Kits) 5 Jul 12, 2002 12:32 AM
