Old Feb 10, 2006, 04:50 PM
TAUMULLER is offline
Find More Posts by TAUMULLER
Joined Apr 2005
Gws C130 Help
Question for all the gws c130 fliers.
In the process of building a gws c130 cargo trans( hercules). The kit I got has the nacelles for 2 engine and 4 engine use. I would like to use the 4 engine setup.
I need to know what motors are being used on the 4 engine setup .
Brushless , non brushless , small thin motor or regular can type and what kind of perfoemance ,should I expect. Also what type of lipo battery pack do you reccomend .
I would like to use the larger stock motors, but on the 4 motor setup. I think that would look nicer especially spinning a 4 bladed prop.
But like all the other gws airplanes I own , thay dont fly well stock, and I have modified every one with brushless motors and lipos.
Any input would be great, also were do I find extra motor nacelles for the
larger motor set up , I need 2 more .
The weight should be just under 20 ounces after paint etc.
TAUMULLER is offline Find More Posts by TAUMULLER
Old Feb 10, 2006, 06:31 PM
vise101 is offline
Find More Posts by vise101
Vertically challenged.
Peachland B.C. Canada
Joined Nov 2002
Hello. You will love the Herc!!!
Mine uses the 4 motor setup. 4 IPS motors with the geaboxes removed. Not sure what the total current drain is but I would suspect somewhere around 8-10 Amps. I am using an "8C" Kokam 1500ma lipo with mine. Pack never comes out hot, even with no cooling holes. I can get around 20 min flights, I just fly it around gently.
Weight is 501g, with batt.
I would imagine with the 4 larger 300 size motors you would have a hefty amp draw and need to carry a larger batt. If you get the weight too high it will be a pig in the air.
There are some good Herc threads in the GWS forum, check them out.
Good luck with your Herc.
Kevin.
http://www.rcgroups.com/forums/showthread.php?t=350254
vise101 is offline Find More Posts by vise101
Old Feb 10, 2006, 06:36 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
What are you talking about? Unless you want to make every single model plane a flying rocket, GWS stock power system works just fine on most of their planes. The stock motors with GWS C-130 works well already you have more than scale power. There are many video around showing how well it flys on stock, e.g. check out the video at www.hobbyhorse.com. They have video of one totally stock GWS C-130.
If you use the "larger" motor then twin motor is already overpowering. If you use 4 motors the weight will definitely exceed 20 oz and flys like a rocket.
shschon is offline Find More Posts by shschon
Old Feb 10, 2006, 07:07 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Mine is the the stock 4 motor setup also. I have absolutely no intention of changing anything. It's one of my favorites!
Glenn.
wellington53 is offline Find More Posts by wellington53
Old Feb 12, 2006, 06:25 AM
strife is offline
Find More Posts by strife
strife's Avatar
GMT +2:00
Joined Apr 2005
Wellington, do you have more photos? That's really nice! I love the skiis!
strife is offline Find More Posts by strife
Old Feb 12, 2006, 08:04 AM
Glenn
Joined Jan 2004
strife, Any particular angle of photo?
Glenn.
Old Feb 12, 2006, 10:41 AM
strife is offline
strife's Avatar
GMT +2:00
Joined Apr 2005
Can you show some more details on the skiis? It looks like a good paint job too - what are the markings/flag?
Old Feb 12, 2006, 12:25 PM
Glenn
Joined Jan 2004
As I'm British born and bred I tried to come up with something like RAF colours but at that time I did'nt have enough paint to do a proper job. The skis are just the lightweight dubro ones. She ballanced OK with just the one pair, The nosewheel was removed also.
Old Feb 12, 2006, 02:12 PM
strife is offline
strife's Avatar
GMT +2:00
Joined Apr 2005
Nice, Glenn. Thanks.
Old Mar 18, 2006, 06:48 AM
Chazzman is offline
Find More Posts by Chazzman
Chazzman's Avatar
Rochester NY
wellington53
how did you mask the nose of your c130 to paint it black?
Chazzman is offline Find More Posts by Chazzman
Old Mar 18, 2006, 08:02 AM
Glenn
Joined Jan 2004
Hey chazz, I didn't mask anything, just used a good paint brush.
Glenn.
Old Mar 25, 2006, 01:10 AM
panzerd18 is offline
Find More Posts by panzerd18
panzerd18's Avatar
Melbourne, Australia
Joined Dec 2005
I thought the electric engines came with the arf?
Where I live you can either buy the c-160 twin engined or c-130 four engined
panzerd18 is offline Find More Posts by panzerd18
Old Aug 18, 2006, 05:28 PM
derailed is offline
Find More Posts by derailed
rc transports rule!
new brunswick canada
Joined Jul 2002
hi all
i just bought the cargo twin today
the beauty is the nacelles and cowls for twin and quad are in the box along with instructions for both
now all thats missing is the motors and other toys
lol
the plane is now available as twin or quad prop,and twin or quad ducted
btw the quad ducted are edf 50s and twin ducted are edf 55
derailed is offline Find More Posts by derailed
Old Aug 20, 2008, 02:21 PM
Eric1180 is offline
Find More Posts by Eric1180
USA, TX, La Vernia
Joined May 2008
God they look so cool but i herd there are many version is there and site that sells all of there so i can compare. Sorry so late 2008
Eric1180 is offline Find More Posts by Eric1180
C130 Help Dave Lindsey Scale Kit/Scratch Built 13 Dec 26, 2002 09:06 AM
GWS Zero Help eplanaddict Beginner Training Area (Aircraft-Electric) 5 Jul 14, 2002 11:18 PM
GWS charger help ronrandle Batteries and Chargers 4 Jul 13, 2002 12:09 AM
GWS Glue!! Help! drbird Parkflyers 16 Jul 11, 2002 06:01 PM
GWS mixer help ANZAC BISCUT Power Systems 1 May 15, 2001 03:01 AM
