Old Mar 31, 2006, 09:59 PM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
Originally Posted by SON OF PALEFACE
U will need matching props , but 1 needs 2 B reverse pitch
Hey Scott , I still havent got mine yet , when did U post them ??????
Hi,
I think Mon. The post office will not give a tracking number for International shipping. I sent them Air and it was like $5.50 for your box.
Have fun with them and let me know how they work out?
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Mar 31, 2006, 11:13 PM
JIMFRISKY is offline
Find More Posts by JIMFRISKY
Jimfrisky
United States, CA, Simi Valley
Joined Jan 2001
Cool Makes Sence Thank You! Can Hardly Wait For Sound !
JIMFRISKY is offline Find More Posts by JIMFRISKY
Old Apr 01, 2006, 06:23 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by R&RRC
I did a twin outrunner design on my F-14.
I used two Hyperion 2205-34 outrunners controlled individually by their own Phx 10. With such a nice model, I was concerned with one motor shuting off in mid-flight. Both motors are powered by one 2100 3Cell. The reason for this is if you ran two batteries, (one to each motor) and one of them went out, for a split second, you would have more thrust on one side than the other. By running one battery they would both quit at the same time and allow for a nice safe glide down in the worst case scenerio.
I don't think you should worry about differiental thrust in the case of one stopping either for a split of a second or permanently! I have a Concorde pusher with two motors, one on each side, and I have lost one of the props. I could still fly with one and had no problems with stability in air. With your F-14 I think the props are so close to each other that you won't even notice apart from the lack of thrust.
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Apr 01, 2006, 08:40 AM
Jimfrisky
Joined Jan 2001
Thanks Ben. Oh boy tell us about that beautiful concord
Old Apr 01, 2006, 09:07 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Build thread is here with plans and everyhing!
I have been thinking of making a larger Concorde with two LS Park Jet Specials
Ben_E
Old Apr 01, 2006, 10:25 AM
Joined Nov 2003
Now your talking! Heck put 4 on there
Scott
Old Apr 02, 2006, 05:37 PM
flyguide7 is offline
Find More Posts by flyguide7
Planes, need more planes
flyguide7's Avatar
United States, MO, Chesterfield
Joined Feb 2006
smoked my first one
I recieved my 3 Park Jet specials on Saturday afternoon and installed one on my su-27xxl with a 20 amp ESC, powered with a thunder power 3 cell 920mah lipo. I installed a 7x6 apc prop and when I tested it a put the juice to it, it seemed to run a little slow compared to what I have heard, however it nearly caught on fire (literally) after about 15 seconds. I let it cool down, changed ESCs and lipo, ran it for 5 seconds at 25 percent and it was hot enough to burn me.
What the heck did I do wrong? I was running my old rimfire outrunner with no problems whatsoever with the very same setup. What am I doing wrong? I have two other J.P.s (I have not yet used) and I am concerned for the other two.
flyguide7 is offline Find More Posts by flyguide7
Old Apr 02, 2006, 06:11 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Ouch! Well, I'll have to let Bob or Scott answer this question definitively but I'm betting the 7x6 prop was too big for this motor. Bob recommends using a 4.75x5.5 to 6x5.5 prop max. I pushed it a little by installing a 7x3.5, but verified on a Wattmeter first that it didn't exceed the 18 amp limit of this motor. A 7x6 is almost certainly over that limit and is probably what fried the motor...
Note the Rimfire has a much lower Kv than this motor so it doesn't use as much current on the same prop.
Steve
jetset44 is offline Find More Posts by jetset44
Old Apr 02, 2006, 06:32 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
The prop is way too much , I agree with Jetset
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Apr 02, 2006, 06:35 PM
flyguide7's Avatar
Joined Feb 2006
Steve
Thanks Steve, oh well live and learn. I did'n t get any directions with the motor, I guess I should have read up on it in the forums here. Thanks again for the input.
By the way I am about finished with your f-14 I got through 6mm RC, Thanks for the great design.
Ed
Old Apr 03, 2006, 02:44 PM
Jimfrisky
Joined Jan 2001
Hey Guys For Little Screamers Web Site Is Up And Running You Can Buy There Now!
Old Apr 03, 2006, 03:23 PM
Joined Nov 2003
HI,
I will replace that motor no problem! I will re-build it. Also max prop 6x5.5. I am very sorry for you not receiving the info sheet with them.
I have not made up the insert but will do it this week.
Again sorry about that.
Scott
call me at (425) 971-9121
Old Apr 03, 2006, 03:24 PM
Joined Nov 2003
First time I seen one look like that?
Buddy was cooking for sure.
Scott
Old Apr 03, 2006, 03:26 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Hi flyguide7,
Too bad about that! On the SU-27XXL it is not a fast plane anyway. I know guys that are using this motor on that plane with an APC 6x4 and it's perfect! Vertical for days, and as fast as that airframe can go. Try it again with the 6x4 and reply back
rvincent is offline Find More Posts by rvincent
Old Apr 04, 2006, 09:47 AM
flyguide7's Avatar
Joined Feb 2006
I spoke with Scott at Little Screamers, Awesome support! I will continue to recommend their fine products to all my r/c pals.
Scott kindly offered to rebuild my motor. Which I will send out today.
Question is the LSPJ enough motor for my 6MM RC F-14? I am finishing that project so it will be available to maiden this weekend, weather permitting.
I installed a 5x 4 prop on my SU-27 with the LS PJ Special and oh my word! Scary power! I cant wait to fly it. I was pulling 13.3 amps at WOT. And after about 1 minute of run time, it was not even warm.
Build Log Eurofighter Typhoon for the Little Screamers Park Jet errolw98 Pusher Prop Jet Models 316 Nov 14, 2011 07:11 AM
Sold Little Screamers Park Jet Motor sgil2001 Aircraft - Electric - Power Systems (FS/W) 2 Aug 10, 2007 07:52 PM
Wanted WTB Little Screamers Park Jet motor wcntech Aircraft - Electric - Power Systems (FS/W) 2 Mar 21, 2007 11:18 PM
Wanted Little screamers Park jet motor Artsloper Aircraft - Electric - Power Systems (FS/W) 0 Sep 15, 2006 09:26 PM
Help! Little Screamers Park Jet woes levelOne Power Systems 5 Sep 05, 2006 12:43 AM
