Old Feb 09, 2006, 07:52 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
I can tell you this much, it is it's own motor! No Copies of another motor and not 24g either Now that I know it works well with the APC 7x4................ It should make a really HOT Hydro motor!! I was using one on my newest boat with a 6x5.5 for all out speed, but with this revelation of the 7x4, it might be the perfect set up for a hydro I need to test one and see. We have been using the 7x3.5 for some time now.
rvincent is online now Find More Posts by rvincent
Old Feb 09, 2006, 08:13 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Originally Posted by rvincent
Steve,
Were you using a 1320 Gen II pack or a Prolite? Your specs seemed a little soft? I get 17,400 rpm's on 17 amos and 175 watts. Confirm your battery for me please.
I used a 6-month old TP 1320 Prolite pack for the testing. I was also a little surprised at how soft my numbers were, given what you've been seeing. But I think the reason is I've got nearly 3 feet of 16 gage wire running from the battery to the motor in my T-38, and the resistance losses from those long power wires are probably significant.
Could be that my pack is worn down a bit, too, since it's seen a lot of flights. I did have a problem initially with the low-voltage cutoff tripping when I first tested the LS motor--the high amps brought the pack voltage WAY down. So I had to enable the soft cutoff to make this setup work OK.
Steve
jetset44 is offline Find More Posts by jetset44
Old Feb 09, 2006, 11:02 PM
rvincent's Avatar
Joined Jul 2004
Wow! Have the PL's been out that long? Man how time flies!!
Well If you get a chance, please try that motor on a shorter "leash" and let me know? My bandit also has long battery lead wires. In your post above it says battery to motor? Is it battery to ESC long? or esc to motor long?
Old Feb 09, 2006, 11:55 PM
jetset44 is offline
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
I used the stock length from ESC to motor and extended the wires between the ESC and battery. The actual length of the extension is about 26". Unfortunately, I've already soldered up that extension and don't have any spare speed controls right now, so I can't test it on a shorter "leash" soon. But even with the lesser power output, I'm very happy with how the LS motor flies my T-38!
Old Feb 10, 2006, 05:07 AM
SHELBY1 is offline
Find More Posts by SHELBY1
It's me Glacier Girl
Joined Aug 2004
I'm availible for testing.
SHELBY1 is offline Find More Posts by SHELBY1
Old Feb 10, 2006, 05:57 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Originally Posted by plane_spotter
Does anyone know if these are available in the UK??
Is someone from LS going to answer this question, or even the US one about availability. Not fair to get us all steamed up if we can't get at it and I can't find it on littlescreamers.com site?
Roger Lombard is offline Find More Posts by Roger Lombard
Old Feb 10, 2006, 07:46 AM
rvincent's Avatar
Joined Jul 2004
Send us an e-mail or better yet, just call the number listed on the website. These are available, just not up on the site yet.
Old Feb 10, 2006, 10:04 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Buyer beware when dealing with LS - They are not very prompt when it comes to shipping product. Fine if you are in no hurry.
Bajora is online now Find More Posts by Bajora
Old Feb 10, 2006, 06:15 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Just a thought...
How would these relatively hot motors work in a EDF?
What do you think??
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Feb 10, 2006, 07:36 PM
rvincent's Avatar
Joined Jul 2004
If you want about 30,000 rpm's ok. We will another specific motor for that soon. I am currently working on a set up for the Wemotec Micro fan. I won't need the KV that the Hyperion 6000 has because the outrunner won't even break a sweat spinning that little rotor. Effectively the the rpm the motor will spin unloaded is what it will spin the EDF Like I said, doing testing right now and it looks real good! In Fact I'm thinking an EDF 50 Wemo with a cut down Kyosho rotor for the extra pitch would be the hot tip! I'll let you know!
Old Feb 12, 2006, 04:58 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Hey Bob, long time LS'r Bill here. What's the possibility of me getting that rewind we discussed a while back? My first ever LS is still spinning away but I really wanna do up one of these screaming park jets. Is LS S/N 00002 gonna hold up to this hot wind?
bildo baggins is offline Find More Posts by bildo baggins
Old Feb 12, 2006, 05:36 PM
rvincent's Avatar
Joined Jul 2004
Hi Bildo,
Of course it will All parts are the same, only the wind is different. Send me a pm and remind me of our discussion. I just did one for another guy here on RCG. Tell me what you want and we will work it out
Old Feb 12, 2006, 05:44 PM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
Little Screamer PARK JET, SPECIAL EDITION, ROCKS the house at Great Planes indoor fest, The "SE" was blowing away anything in the air on my ALLIE KAT, but get this, I was using 2 cells while everyone else was at 3 cells.
I was running an APC 5.2.5 X 4.75 on a 2 cell 1320 ProLite. FWIW it was the quietest motor of the bunch..............
3 Cell allycat is a WHOLE differant level of speed and I personally could not handle it indoors.
c/f is offline Find More Posts by c/f
Latest blog entry: Time Capsule Heli
Old Feb 12, 2006, 07:52 PM
cdebaca is offline
Find More Posts by cdebaca
cdebaca's Avatar
USA
Joined Oct 2005
Hi Bildo,
Hey rvincent,is there a LS for 45oz + if so were can I get one?
Anthony.
cdebaca is offline Find More Posts by cdebaca
Old Feb 13, 2006, 04:53 AM
Littlescreamers is online now
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
Thank you for the nice words
Scott
Littlescreamers.com
Littlescreamers is online now Find More Posts by Littlescreamers
Build Log Eurofighter Typhoon for the Little Screamers Park Jet errolw98 Pusher Prop Jet Models 316 Nov 14, 2011 06:11 AM
Sold Little Screamers Park Jet Motor sgil2001 Aircraft - Electric - Power Systems (FS/W) 2 Aug 10, 2007 06:52 PM
Wanted WTB Little Screamers Park Jet motor wcntech Aircraft - Electric - Power Systems (FS/W) 2 Mar 21, 2007 10:18 PM
Wanted Little screamers Park jet motor Artsloper Aircraft - Electric - Power Systems (FS/W) 0 Sep 15, 2006 08:26 PM
Help! Little Screamers Park Jet woes levelOne Power Systems 5 Sep 04, 2006 11:43 PM
