Old Jun 18, 2002, 11:49 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Location Of Main Gear for a Taildragger Conversion
I am looking into converting a tricycle gear trainer I have into a taildragger and want to know what the formula is for figuring out where to mount the main gear in relation to the CG and leading edge of the wing?
cactus is offline Find More Posts by cactus
Old Jun 18, 2002, 12:25 PM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
As a general rule, the center of the wheel hubs should be at the LE.
VP
Viper Pilot is offline Find More Posts by Viper Pilot
Old Jun 18, 2002, 12:33 PM
tphillips is offline
Find More Posts by tphillips
Hey, I wanna fly too!
tphillips's Avatar
United States, TX, Justin
Joined Sep 2001
Mike,
I don't know any formulas, but a few of the tail draggers I have in my hanger all have the gear +/- 1/2" from the leading edge. This covers anything from a Champion (+1/4"), E3D (+1/2") to 60" Shoestring (-1/4") or GEE BEE R2 (0")
Terry
tphillips is offline Find More Posts by tphillips
Old Jun 18, 2002, 01:07 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Generally I place the mains so the front of the wheel is visible when looking down at the plane..
This is close to the leading edge, as on this Seniorita...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jun 18, 2002, 01:23 PM
crashmeister is offline
Find More Posts by crashmeister
florida keys
Joined Jun 2002
Here's the guidance from the book, "Basics of RC model aircraft design". With your plane in a level attitude, and at a height that gives you your desired prop clearance, draw a line straight down from a point on the bottom of the wing at your forwardmost cg straight down. Now draw another line downward from that same point at an angle of 15-20 degrees from the vertical line toward the nose of the airplane. The contact point of your wheel will be where that second line touches the ground. The center of the wheel is located dierctly above that spot. Sorry for the long explanation, but I'm trying to describe this from a drawing in the book.
crashmeister is offline Find More Posts by crashmeister
Old Jun 18, 2002, 03:51 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
Thanks guys! Sounds straight forward enough. Now I need to figure out what tail wheel I am going to use....
Question Best main gear for Hubdave Frame tywhite31p Mini Helis 9 Apr 12, 2006 01:21 PM
How many teeth on the main gear for the Trex 450? WreckRman2 Mini Helis 16 Jan 14, 2005 10:36 PM
Belt driven main gear for BB or Falcon ?? superdave42 Micro Helis 42 Sep 20, 2004 11:39 AM
hb elite mainshaft and main gear for hb v2 jacob Micro Helis 0 Aug 16, 2004 01:41 AM
F/S New Main gear for the Corona Lv2Fly Aircraft - Electric - Airplanes (FS/W) 1 Jul 14, 2003 01:26 PM
