Old Feb 08, 2006, 02:06 PM
Sky Rat is offline
Find More Posts by Sky Rat
Hobby Roustabout
Sky Rat's Avatar
San Antonio, Texas
Joined Feb 2006
Fan Fold/Bluecor Tips and Techniques
Hello All,
I've been lurking on this site for a little over 2 months and I have to say that I'm hooked on RC Planes.
Foamies especially.
I picked up some Bluecor on clearance yesterday (1/4 inch, film on both sides), and it's burning a hole in my hobby table.
I've read several wonderful tips about using bluecor scattered over several different threads at this forum.
But they are all over the place.
And I don't see a sitcky for FFF/Bluecor tips. So I thought I'd start one.
So how do you work blueor?
how do you bend it or fold it?
How do you make curves with it?
What is the best way to make wings with it?
what tips do you have for access panels and support rods?
How do you get the film off?
How do you paint it?
how do you cut it?
how do you sand it?
So what will be my first project with bluecor?
Well GO_RC's Millenium Falcon kit of course.
So all you sage experts, please post your tips for bluecor and help us newbies out.
Sky Rat is offline Find More Posts by Sky Rat
Old Feb 08, 2006, 02:27 PM
ZORCY is offline
Find More Posts by ZORCY
flying? like a penguin
ZORCY's Avatar
Toronto, ON, USA, Earth
Joined Jul 2005
thats a lot of questions in one thread
cut= with a razor knife (unless you have big $, then a laser cutter)
sand= like very very soft bulsa,
film= only remove it if it is needed, it stiffens up the board
access panels= nio mags
bend it=hot, hair drier or ziplocks with hot water in a 'mold'
curves=hmm depends, like a circle, razor knife still works, like a dome, pie slices glued together
glue=foam safe superglue, but if you have time gorilla glue or any polyetholine glue(spell that) its a water proof outdoor woodworkers glue, get diff names at wally world home depot, anywhere
ZORCY is offline Find More Posts by ZORCY
Old Feb 08, 2006, 02:33 PM
Sky Rat is offline
Hobby Roustabout
Sky Rat's Avatar
San Antonio, Texas
Joined Feb 2006
Thanks Zorcy!
One question, how do you sand like very soft balsa?
I'm a display model refugee and sanding was one of the things I was HORRENDOUS at.
Old Feb 08, 2006, 02:35 PM
ZORCY is offline
ZORCY's Avatar
Joined Jul 2005
afraid i have not painted yet, its kinda gutsy for a falcon. an easy one is the STC. and very forgiving to crash. the hydrofoam is a fun idea, but i have only built in, i have not put any power to it yet. if you are going to build, might as well build the cd rom motor too. that is another year of research, so cheat and get a kit with directions.
Old Feb 08, 2006, 02:46 PM
ZORCY is offline
ZORCY's Avatar
Joined Jul 2005
get a sanding block, or several, many grits, glue the paper to the block (disposable lumber) 80 is to be used like a saw, it CUTS away foam. have a hand vac there too, lol, you will see. most work, that will look good, will be cut, cut at a beval or formed with heat. most foamies are built to fly, crash and repair. sanding is more to fit parts together
Old Feb 08, 2006, 02:48 PM
ZORCY is offline
ZORCY's Avatar
Joined Jul 2005
try the stc link here for an easy build, it cuts, glues, re-enforces and even rolls some foam
http://www.rcgroups.com/forums/showthread.php?t=354237
Old Feb 08, 2006, 03:15 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
you can curve bluecor without heat .. i dont heat any of my stuff .. as far as tips and techniques check out mtflyer , jmorgan , Vyceroy , Scotta , jetset44 , Ralph A. D'Amelio .. do a search for threads by these guys .. there you will find a wealth of information ..
Vyceroy is offline Find More Posts by Vyceroy
Old Feb 08, 2006, 03:35 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Painting blucore foam
Paint=acrylic cheapy paint at hobby craft stores. A bottle usually costs about .89 cents Cleans up with water. Be sure to let it dry real well before touching. I draw my outline with a sharpy, (try to match the color of the paint) and then use a small paint brush to paint the plane. This one took about 1.5 hours, (includes two stripes on the bottom)
aerolite is offline Find More Posts by aerolite
Old Feb 08, 2006, 03:45 PM
rcallison is offline
Find More Posts by rcallison
Foam Wannabe
Joined Nov 2005
Hey Sky Rat, just wondering, where did you find the 2 sided BluCore in San Antonio?
rca
rcallison is offline Find More Posts by rcallison
Old Feb 08, 2006, 04:23 PM
Sky Rat is offline
Hobby Roustabout
Sky Rat's Avatar
San Antonio, Texas
Joined Feb 2006
rca
Lowe's on Austin highway.
It's on clearance for about $16.
I'm seriously thinking of going to buy a second unti of it.
thanks for the link Zorcy.
Does the scoring technique work for deeper curves on bluecor?
Old Feb 08, 2006, 04:52 PM
Skully is offline
Find More Posts by Skully
Bring a shovel
Skully's Avatar
New Caney, TX
Joined Jan 2006
The Lowes in Kingwood, Tx had some 1/4 inch a couple weeks ago. Bought two bundles. There may still be some left. Yup, $16.
Painting -- I found that using Minwax Polycrylic water based to seal the foam very well. Well enough that I sprayed some Testors and some Krylon on a test article with no bad affects.
Skully is offline Find More Posts by Skully
Old Feb 08, 2006, 04:57 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
testors wont eat the foam any way ..
Old Feb 08, 2006, 05:05 PM
Skully is offline
Bring a shovel
Skully's Avatar
New Caney, TX
Joined Jan 2006
Strange Vy, I wonder why it isn't used for painting more. On the otyher hand, Krylon on unprotected foam did cause problems. The area with Polycrylic was protected.
Old Feb 08, 2006, 05:43 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
yeah the water based polyurethane does great at sealing the foam .. i put it on over the paint also so offer some protection to the paint..
Old Feb 08, 2006, 05:59 PM
Sky Rat is offline
Hobby Roustabout
Sky Rat's Avatar
San Antonio, Texas
Joined Feb 2006
that polycrylic sounds like a good idea.
Bluecor Fan-fold P-47 Ready to Fly! AZ_Astro Foamies (Kits) 54 May 27, 2006 06:19 PM
Bluecor Fan Fold in Phoenix Arizona? MikeDPP Foamies (Kits) 15 Feb 28, 2003 11:40 PM
Desperate! Is there any BlueCor Fan Fold Foam in Arizona? AeroMojo Foamies (Kits) 3 Aug 02, 2002 01:20 PM
Fan Fold / BlueCor in the UK ? Where ! ? Steve Wrona Foamies (Kits) 3 Jul 13, 2002 12:01 PM
Fan-fold covering/painting tips only. hardlock Foamies (Kits) 28 Mar 12, 2002 02:20 PM
