Old Jun 18, 2002, 09:36 AM
Reco is offline
Find More Posts by Reco
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
Problem with Acrylic paints
Well I assumed something and you guessed it I shouldnt have. I have been using Model Masters water based ACRYL paint in my Badger brush and it has always worked great on foam. The only thing I dont like is the small amounts you get in the little bottles. I mean 1/2 of an ounce is not enough to cover lets say a Foxbat. And of course this paint isnt cheap. So I thought I would try some water based Acrylic house paint. Well after I thinned it down with water to many different viscosities it still will not cover foam very good it will not cover the small valleys in the foam and it goes on semi transparent. Is there another option than what I have tried to get get large quantities at a reasonable price?
Reco is offline Find More Posts by Reco
Old Jun 18, 2002, 11:57 AM
joey221 is offline
Find More Posts by joey221
suffering gravity surge
joey221's Avatar
Westminster, CO
Joined Oct 2001
You might want to try thinning with Floetrol instead of water. I've done that before with good results.
Also, the little vials (about the size of a roll of quarters) of "craft" acrylic paints are dirt cheap -- usally about $1-$2 per vial. Huge assortment of colors.
I just finished some pretty radical reconstruction of a fiberglass sailplane fuselage, and painted it with a red metallic craft acrylic paint, and it looks pretty good, particularly for the approximately $0.10 in paint it took to spray it!
Joe
joey221 is offline Find More Posts by joey221
Old Jun 18, 2002, 07:34 PM
Ragnar is offline
Find More Posts by Ragnar
Oz Member
Ragnar's Avatar
Near Mallala, South Oz
Joined Nov 2001
The best results I've achieved are with alcohol based acrylics, namely Tamiya and Gunze Sanjo. The Tamiya paint is thinned either with their thinner, (expensive) Iso-propypl alcohol, (better) or Methylated Spirits (dirt cheap) you can thin it 'til its more like a wash than a paint and it still covers perfectly. (though thin, of course!) The best results are with the consistancy of milk, and a couple of coats will do it. (Depending on the colour and what your painting over) They are only smallish containers, 13ml I seem too remember, but will cover a large area. (One to do a GWS tiger moth all-over in yellow, with two good coats, then another later when I decided to change to an aluminium finish. Three tins sky, dark earth and green for a 48" spitfire, etc.) Good range of colours, and that's where I go to Gunze if Tamiya don't have it, 'cause here they are a bit more expensive.
Hope it helps,
Cheers,
Russ
Ragnar is offline Find More Posts by Ragnar
Old Jun 18, 2002, 09:27 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Hmmm.
I painted an anti glare panel ( flat black ) on a jet like model with the Acrylic Latex house paint, thinned just enough to let the airbrush spray it, and it worked great. It was applied on top of Ultracoat heat shrink covering, and the spinner and was still stuck tight to both after the crash. Spinner was shattered but all pieces were still nicely painted!
Bad flight, good paint adhesion.
The Formula U enamel works great on foam and is cheap. My TM with a OD/tan camoflage paint job used about 1/4" out of the the 4 oz jars!!
Does take a couple of days to dry though.
Dave
DaveW is offline Find More Posts by DaveW
Air Brushing with Acrylic Paints? Turbobeaver GWS (Grand Wing Servo) 17 Jul 30, 2004 12:13 PM
Problem with Schulze isl6-430 charger Scud Electric Plane Talk 4 Jun 21, 2001 12:36 AM
Range problem with mini Rx Tyson Electric Plane Talk 12 Jun 19, 2001 01:57 PM
The Problem with Electrics is... John E Electric Plane Talk 26 May 28, 2001 10:08 PM
Problem with GP Electrifly C30 ESC Steph280 Electric Plane Talk 6 May 15, 2001 05:07 PM
