Old Jun 17, 2002, 05:57 PM
stevek is offline
Find More Posts by stevek
Joined Feb 2002
Using Lithium Batteries for Receiver Pack
Folks,
I posted this in the sailplane forum, but the thread didn't get much traction. After reading through this forum, it seems the posting may be more appropriate here...
Here's the post...
I've got an Omega E Glider that I'm finally starting to get comfortable with. Recently, I had a flight that included a killer thermal on the last climbout. Came in for a landing and had the best landing to date with this plane.
When I got home, I was using the remainder of the charge in the battery to test some programming and found out that there was no "remainder" to the charge. I was incredibly lucky!
I'm now thinking of adding a receiver battery in addition to the battery for the motor. I've got a couple of 2 cell Lion batteries that are 750 MaH at 1.5 Oz (picked these up from Hobby-lobby for my Pico Stick - good long flights out of that and I've even had it in a thermal once). I Figure these should readily drive the 4 servos in the plane for something like a day and 1/2 :-).
What do I need to do to use these? Since the voltage out of the pack is something like 7.2 V, it would seem I need something to regulate the voltage to that required for the receiver. Is there something on the market that does this, or would it just be easier to get something like a speed controller (rated for 4 servos - any suggestions) and use that.
Any and all suggestions welcome!
stevek is offline Find More Posts by stevek
Old Jun 17, 2002, 06:28 PM
sanjoh is offline
Find More Posts by sanjoh
Master Crasher
sanjoh's Avatar
Sunrise, FL
Joined Nov 2001
I've been using li-ion in my giant scale stuff and just converted a tx over. You'll need a voltage regulator, I found the best deal at http://www.maxxprod.com/mpi-21.htm 6v for 19.95. 1500 li-ion would last a very long time. Next you'll be looking for larger tx batteries!
sanjoh is offline Find More Posts by sanjoh
Old Jun 17, 2002, 06:39 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
$20 seems a little steep... for $4 from radio shack you can get a 1A 5v regulator, they might have heavier duty ones there as well... or at other electronics shops...
opualuan is offline Find More Posts by opualuan
Old Jun 18, 2002, 03:43 PM
stevek is offline
Joined Feb 2002
Sanjoh,
Thanks - that's the sort of thing I figured would be out there! Now that I know they exist (in a form other than just the raw voltage regulators), I'll see what options there are.
I may be looking for a 4.8V or 5V regulator as this would make the battery last longer and I'm not sure I really need the extra speed or torque on my servos.
Old Jun 18, 2002, 06:25 PM
Quacker is online now
Find More Posts by Quacker
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
You might be interested to know that many receivers and servos run very well on 3.1 volts. This makes them a candidate for one cell with a nominal 3.6-3.7 volts. Consider puting your cells in parallel. I have only tested the Hitec 555 and FMA Extreme5. They are both flawless. The Extreme is even fully spec'd at 3.5 volts. I run my DLG glider with the Extreme, two HS-50's and a gyro on only one 830mah li-ion. It goes fro more than 5 hours.
Q
Quacker is online now Find More Posts by Quacker
Site Sponsor
Old Jun 24, 2002, 06:10 PM
Ripley is offline
Find More Posts by Ripley
Don't provoke my wife!
Fort Worth Texas
Joined May 2002
Quacker, so you think I could use one li-ion cell in my 2 meter sailplane using 2 micro servos and Hitech 555. What kind of charger do you have to use and how much are they.
Ripley is offline Find More Posts by Ripley
Old Jun 24, 2002, 06:19 PM
yb2normal is offline
Find More Posts by yb2normal
Frequent User
yb2normal's Avatar
Broomfield, CO, USA
Joined Jan 2001
Regarding the regulator at http://www.maxxprod.com/mpi-21.htm, which makes it sound pretty slick about how it regulates down to 6v and then bypasses the regulator. This is actually a feature of most any linear vreg that you buy... once the voltage goes below that which it can regulate it just becomes a pass-through device. The trick is finding one that minimized the forward voltage drop.
I've seen Quacker's qualcomm powered DLG, very light with that single Qualcomm.
yb2normal is offline Find More Posts by yb2normal
Old Jun 24, 2002, 08:52 PM
Quacker's Avatar
Joined Jul 2001
Ripley:
When servos are run at 3.6 volts, there is not much power available. For a DLG, that's fine. For a 2 meter, you need to judge carefully.
Q
Site Sponsor
Lithium batteries for twin Speed 400s mjemery Batteries and Chargers 1 Nov 23, 2003 05:20 PM
Which Lithium batteries for a speed 400? ErnieR Batteries and Chargers 7 Nov 20, 2003 11:34 AM
Alert Very interesting read on Nimh and Lithium batteries for Planes Mmarshall Batteries and Chargers 4 Mar 13, 2003 09:11 AM
Any advantage using AE cells for receiver batteries? dvint Electric Plane Talk 8 Jan 12, 2003 10:34 AM
Using TX charger for flight pack? KnifeEdge51 Batteries and Chargers 3 Jan 01, 2003 10:39 AM
