Old Feb 06, 2006, 07:37 PM
rpmp3 is offline
Find More Posts by rpmp3
Joined Feb 2006
weed eater motor in a boat
I am interested in making my own boat and putting a weedeater motor in it has this been done and are there kits or helpfull hints to share, I am pretty handy and have tools to do it, also do small engine repair on the side, any thoughts of going about this.
rpmp3 is offline Find More Posts by rpmp3
Old Feb 07, 2006, 02:02 AM
ernest2 is offline
Find More Posts by ernest2
all my boats are broken
ernest2's Avatar
manila
Joined Aug 2004
hi! i have an airboat with a homelite 25cc as the engine. it was great and fun till the engine blew. anyway, yes you can do that. i am not really an expert (knows very little) but i am sure other guys can answer questions you'll ask.
by the way iam also planning on putting a honda gx31 motor in a boat. but i have to wait till my engine arrives before i make the boat plans.
goodluck!
ernest2 is offline Find More Posts by ernest2
Old Feb 07, 2006, 05:28 PM
rpmp3 is offline
Joined Feb 2006
can you buy plans for a boat
Old Feb 09, 2006, 03:37 AM
sharpshooter is offline
Find More Posts by sharpshooter
sharpshooter's Avatar
Adelaide South Australia
Joined Sep 2004
Hi there.
Plans are available from www.rcstore.com for a large range of boats or looking in the back of Radio Control Boat Modeler.
sharpshooter is offline Find More Posts by sharpshooter
Old Feb 10, 2006, 03:23 PM
w3bby is offline
Find More Posts by w3bby
Helsingborg, Sweden
Joined Jul 2005
Free plans available for a v hull, 42". Send me your e-mail and I'll get them to you. Also if you want dxf or pdf.
Boat is on a number of other forums with some good build threads.
w3bby is offline Find More Posts by w3bby
Old Mar 06, 2006, 12:17 PM
ib456 is offline
Find More Posts by ib456
Joined Sep 2005
A good place for advice is www.jrcbd.com very helpful guys.
ib456 is offline Find More Posts by ib456
Old Mar 12, 2006, 08:33 AM
Master crafter is offline
Find More Posts by Master crafter
be a designer, not a assembler
Franklin,NH
Joined Mar 2006
Hi , i,m a new here but have built many RC wacker powered rigs.The latest is a 1/4 scale auto gyro ultra light.The bigest problem to over come is the overheating here.I have rectified this with water cooling by removing the head on the engine and recutting the fins cylindrical with a hole saw on a drill press and then adding a upper and lower port for water circulation,by adding some brake line for the lower.Then adding the outer jacket (a common tin can of proper size) and adhering it with JB weld.To make life simpler preheat the cylinder head with a torch and the JB weld will solidafy allmost imediatly( but be careful not to reach the point of bubbling of the adhesive).Alittle bit of hands on testing should be proformed first to reach the proper heat range and not to overheat or structural integrity of the adhesive will be lost.For boat aplication the feed tube is a simple piece of tubing with a slant cut foward as to give more than ample water movement
Master crafter is offline Find More Posts by Master crafter
Old Mar 26, 2006, 11:51 PM
Nat Ferguson is offline
Find More Posts by Nat Ferguson
Seal Beach, CA
Joined Feb 2006
Check out this website devoted to the Gas R/C Boats. I know the owner, he's a good guy. www.insaneboats.com
Nat Ferguson is offline Find More Posts by Nat Ferguson
Old Jul 04, 2010, 02:10 PM
rcboatdriver12 is offline
Find More Posts by rcboatdriver12
Joined Jul 2010
W3bby I would like those plans rcboatdriver1234@yahoo.com
rcboatdriver12 is offline Find More Posts by rcboatdriver12
Old Jul 05, 2010, 09:39 AM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
Engine HP and boat weight are the most important thing to rembemeber when building your boat. Many choose to ignore these things only to see a slow boat. Not all homelite engines will work. Todays engines are junk! With the right tools and parts you can build a nice boat.
txt killer is offline Find More Posts by txt killer
Old Jul 07, 2010, 12:28 AM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
http://www.modelgasboats.com/
http://www.modelpowerboat.com/forum/article/home.htm
http://www.zippkits.com/
PROACE is offline Find More Posts by PROACE
Old Jul 07, 2010, 12:34 AM
PROACE is offline
PROACE's Avatar
Joined Jan 2002
I just posted some helpful links which may answer a lot of your questions about building an weed eater type gas boat.
I am currently building a Zip Kits "Easy Vee" $59 and it is going to be powered by a Zenoa 23cc water cooled gas engine, cost about $199.
On ebay you can buy the China made Zenoa knock-off for about $75
If you aready have a weed eater engine you can find info on how to convert it for RC boats on the links I posted above.
Have fun!
Ace
Old Jul 09, 2010, 09:29 AM
Joined Apr 2008
You can't just use any weedeater engine. Most are junk. Some are real good. The first thing to look fore in using a weedeater type engine is if it has a clutch. The second thing to look for is HP. 2 hp is recommended. Third look for upgrads for the engine.
Old Jul 09, 2010, 03:29 PM
Winkman1 is offline
Find More Posts by Winkman1
Jersey Shore
Joined Aug 2008
What brand weed eater engine would you recomend ?
Winkman1 is offline Find More Posts by Winkman1
Old Jul 17, 2010, 09:09 AM
Joined Apr 2008
look at the 30 cc range commercial grade trimmers. Don't waste your time with Ryobi engines. Junk for boats. A good engine should have a clutch option and be able to get replacements parts for. I prefer Homelite before 94" and Echos after 00" I also like Zenoah but they are expensive.
Discussion So my dad gave me his never before ran 62" +/- Weed Eater Boat (update with pics) Excogitate Racing Boats - Internal Combustion 10 Jul 20, 2010 07:39 AM
Discussion Can I use a car motor in a boat? mistel Scale Boats 6 Aug 24, 2006 09:52 AM
eBay: HussleCraft Mono GAS BOAT with 25cc Weed whacker MOTOR mdttb Boats (FS/W) 2 Mar 13, 2004 06:51 PM
Upgrade 380-Size motor in Aero Cruiser by Hobbico ooananoo Beginner Training Area (Aircraft-Electric) 4 Jun 06, 2001 10:32 AM
Plettenberg Moskito Brushless motor in Adrenalin! Erik Johansson High Performance 9 May 18, 2001 05:54 PM
