Old Feb 06, 2006, 07:15 PM
bobert13581 is offline
Find More Posts by bobert13581
Joined Jul 2005
3M 77 spray for EPP
I am about to start my first attempt at an EPP foamie. (still choosing between nasty, yak or slofly - throw in your $.02 opinion if you like)
I have read a lot that people use 3M 77 contact spray to enable them to attach sticky tape to EPP.
The conversations between all the yankees talk about buying this 3M 77 spray at wal-mart etc.
Where would an aussie source such a product. Anyone seen it at LHS or hardware stores?
bobert13581 is offline Find More Posts by bobert13581
Old Feb 06, 2006, 07:32 PM
nator_au is offline
Find More Posts by nator_au
RC recluse
nator_au's Avatar
Australia, NSW, Fletcher
Joined Dec 2004
It can be hard to get. And is generally about $30/can. My Local Bunnings doesnt have it.
I have used foam safe spray adhesive from the craft store with success. Goes for about $6 can. Generally used for attaching photos o boards, and general craft sticking jobs.
Having said all that, 3m77 is the best stuff you can get, assuming you can find it somewhere.
Brett
nator_au is offline Find More Posts by nator_au
Old Feb 06, 2006, 08:17 PM
GlennS is offline
Find More Posts by GlennS
Flying 3 mistakes high
GlennS's Avatar
Melbourne, Australia
Joined Jun 2004
I picked up a can of 3M77 at my local Officeworks a couple of weeks ago in Narre Warren. It was a bit exepensive, cant quite remember, around $25 or so.
Cheers,
Glenn.
GlennS is offline Find More Posts by GlennS
Old Feb 06, 2006, 08:59 PM
ravencsr is offline
Find More Posts by ravencsr
Melbourne, Eastern Sub.
Joined Sep 2004
As Brett said, it can be hard to get. I got mine from up the road at a stationery supplier where I work for around $22 I think, last year.
It wasn't called 3M Super77 but 3M MultiPurpose and was in a green can I think. Anyway I thought it was way better than a cheaper can of craft spray I got before it. Very high tack.
Raven
edit.............
Just went in on the way back from lunch
$19.39 467g 3M MultiPurpose
IMT Stationers
Hawthorn East
98229077
imtstat@bigpond.com
ravencsr is offline Find More Posts by ravencsr
Old Feb 06, 2006, 09:14 PM
salisbug is offline
Find More Posts by salisbug
I failed linkage geometry
salisbug's Avatar
Joined Jun 2002
refer this thread in the slope forum
http://www.rcgroups.com/forums/showt...ght=richardson
Glenn
salisbug is offline Find More Posts by salisbug
Old Feb 06, 2006, 09:16 PM
osmium_192 is offline
Find More Posts by osmium_192
Toof-fairy
osmium_192's Avatar
Perth, Australia
Joined Sep 2005
77 is a black can i think, might have seen in in Perth RC, cant remember the price.
Owen
osmium_192 is offline Find More Posts by osmium_192
Old Feb 07, 2006, 02:19 AM
GuyP is offline
Find More Posts by GuyP
Australia, NSW
Joined Sep 2005
Your right Owen it is a black can & it's great stuff.
I can't quite remember where I bought this can from or how much I paid but am pretty sure I got it from Hobbies in the hills.
cheers,
Guy
GuyP is offline Find More Posts by GuyP
Old Feb 07, 2006, 03:39 AM
Toof-fairy
osmium_192's Avatar
Perth, Australia
Joined Sep 2005
Definately a used can, lots of glue all over the exit area.
That pic should help one locate it.
BTW, are toyworld stores franchise run and stock is determined by the local empoyees? Theres one at Australia fair that sells zap, superglue 1oz for 5.99 AUD. I got 1, even though i didnt need it, but when i was there i maybe saw some spray glue. (MAYBE but probably wasnt)
Owen
Old Feb 07, 2006, 08:48 AM
RussellK is offline
Find More Posts by RussellK
Foam disposal expert
Joined Sep 2003
I called 3M Australia once and they confirmed that 3M Super77 and 3M MultiPurpose was the same stuff - the challenge I find is getting the big-arsed cans of the stuff. Office Works stocked them at one point, but haven't had it lately.
I use all the 3M spray adhesives for my work including the Photo Mount and Remountable sprays and they are streets ahead of other products, not just in the adhesive, but also in the spray pattern and droplet size.
RussellK is offline Find More Posts by RussellK
Old Feb 07, 2006, 09:41 PM
BMtech is offline
Find More Posts by BMtech
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
3M77 the old type is at Clark rubber stores, have a look at the can to see if it uses acetone or cyclohexene the new has acetone in it. The old will work on eps foam as well.
Rick
BMtech is offline Find More Posts by BMtech
Old Feb 07, 2006, 10:28 PM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Blackwood has the old version thats where I get mine
SteveW
steve wenban is online now Find More Posts by steve wenban
Old Feb 08, 2006, 08:29 PM
Toof-fairy
osmium_192's Avatar
Perth, Australia
Joined Sep 2005
Acetone will melt foam, but use it at a distance and the acetone evaporates before it hits the foam. People use this technique for acetone based paints.
Worth a try
Owen
Old Feb 08, 2006, 10:34 PM
GuyP is offline
Australia, NSW
Joined Sep 2005
Like SteveW said Blackwoods at Smithfield NSW sell the Multipurpose stuff.
They sell the 467gm cans.
Old Feb 09, 2006, 05:29 AM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
I use UHU glue I got from bunnings on EPP most of the time. Cant remember what it it is called. Its light and strong, but does need to set overnight to become really strong. Cost $6 for 90ml. For instant gluing cant go past hot glue.
Eagleburger is offline Find More Posts by Eagleburger
Old Feb 09, 2006, 08:56 AM
Toof-fairy
osmium_192's Avatar
Perth, Australia
Joined Sep 2005
Is UHU the clear thick glue that strings? I have the original UHU and that eats through foam, but its real cheap when you buy it from asia. I got the largest tube thats 20cm long and 4cm in diameter for about $5 australian (converted)
Owen
Discussion Any substitute for 3m-77 spray before taping cooper998 Flying Wings 8 Nov 25, 2006 11:40 AM
3M 77 spray adhesive? ViperR Foamies (Kits) 4 Nov 08, 2002 01:57 AM
3M-77 Spray adhesive in the UK Javawookie Foamies (Kits) 1 Aug 26, 2002 02:22 PM
FS--3M 77 Spray Adhesive old formula xen Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2002 01:02 AM
3m 77 Spray in England??? Martin Hanstead Foamies (Kits) 2 Apr 23, 2002 07:11 PM
