Old Jun 17, 2002, 04:56 PM
Mark Sanders is offline
Find More Posts by Mark Sanders
Mark Sanders's Avatar
Windsor, UK
Joined Jun 2001
Ripmax Alienator Mini-review
Just got back from a successfull maiden flight - this baby does exactly what it's advertised to do - fully aerobatic yet unstallable.
see URL=http://www.ripmax.com/FS_Aircraft_EPSportARTF.html]http://www.ripmax.com/FS_Aircraft_EPSportARTF.html[/URL]
I was attracted to this arft as unlike twin jet et al, it has a front motor so can use all the standard motor/prop setups AND avoids the annoying noise the rear drive ones make. I lifted a drive straight out of the estreak (10x cp1700, endo, 2.8:1 & Aeronaut 11x6.5) and after about 2 evenings of fitting wooden spars, radio gear and a weird but effective motor mounting it was ready. Its one piece with battery access, thro a screw down top hatch. It got off easily from hand launch, no trim required - and flew incredibly smoothly - Sort of cross between a conventional e-streak type aerobatic and a delta. It has more drag than the estreak and all up weight is 45oz - 5 oz heavier, so will not go straight up on this setup. Also as it has a fair bit more drag from all the 'starwars' fins and things - so is not as fast - but well fast enough (eg faster than the other 4 slimmers at the field tonight). Rolls are fairly axial, and its smoothness generally flattered my skills - eg I felt confident in doing long low fast passes on 1st flight. The shape is strange in the sky - but its nice to see something interesting looking that works well. After fast landing Hotliners and estreaks - landing was dead easy - it slows down nicely without stalling, it really doesnt stall just looses speed with a slightly nose up attitude (so spot landings are back on the agenda again for me ) for 44 its a must have.
Mark Sanders is offline Find More Posts by Mark Sanders
Old Jun 17, 2002, 06:51 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Mark,
This does look like a good home for an E'streak power train !
Thanks for the report.
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Jun 18, 2002, 07:07 PM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
I reckon this plane is well named as far as looks go
Seems to have some good reviews however
davidleitch is offline Find More Posts by davidleitch
Old Jun 18, 2002, 08:02 PM
Bill Germanson is offline
Find More Posts by Bill Germanson
Name it, I've crashed it
Bill Germanson's Avatar
JAX, FL
Joined Feb 2002
I see that Tower sells a lot of the RipMax stuff but not this model. Then I went and did a search on "Easy Street" and look what I found.
http://www2.towerhobbies.com/cgi-bin...1&I=LXUZ64&P=7
It was kit for $32.99. Looks like the same kind of thing that Great Planes did with the EStreak kit to ARF.
Any thoughts on who in the U.S. sells the ARF version?
Bill
Bill Germanson is offline Find More Posts by Bill Germanson
Old Jun 27, 2002, 05:06 PM
mitchellj is offline
Find More Posts by mitchellj
UK
Joined Oct 2001
How did you fit 10x1700 cells in ?
I am rebuilding mine and need some ideas since this was one of the problems with my old layout (which had 8x2100).
I also had problems keeping the nose up on landings which sort of spoiled my hopes of very high angle of attack spot landings (and caused me to spend a long time finding a suitable folding prop), you obviously don't have this problem. Did you move the COG or something ?
mitchellj is offline Find More Posts by mitchellj
Old Jun 28, 2002, 05:40 AM
Windsor, UK
Joined Jun 2001
Hi mitchellj
After assembling the ply inner structure I powerfiled out a 10mm high ply rib which seemed to right in the middle of the battery bay. This gives massive space for up to 10 x 3000Mah - I've only tried upto 2400's but prefer the cp1700's for lightness. The cofg I flike is 5mm back from the recommended posn. ie 90 mm in front of main spar.
I've recently switched props to aeronaut 10 x 10 (approx ie 10 x 7 + 5 degree angled yoke). This is alot faster with the endo and 2.8:1 gear, and although motor calc says the time sholiud be the same I seem to get much longer flights - maybe because I now have to back off to save the wings being pulled off. This plane really rocks - its so smooth and can turn so tight, but it does drop quite quickly once power is off (thats compaired to the more streamlined stuff I normally fly). and as speed comes off, so does elevator authority - I usually land with full up elevator, but only slightly nose up - part of its 'no-stall' characteristic. Avoid low speed, low height maneovers with the nose pointing down - I guess that applies to all except 3D machines
Additionally - the foam used is standard expanded Polystyrene EP, (cheapskate ripmax) not the better expanded polyproylene EPP, as Multiplex use for picos and twins. PS is more prone to hanger, car and landing rash. I've got round this by using clear wide self adhesive tape to reinforce vunerable areas.
Mark, Windsor UK
Old Feb 12, 2003, 06:53 PM
oldpilot is offline
Find More Posts by oldpilot
oldpilot's Avatar
Australia, NSW, Mona Vale
Joined May 2002
ANYONE for the ALIENATOR as a Slope Soarer???
Patrick.
oldpilot is offline Find More Posts by oldpilot
Old Feb 19, 2003, 01:23 AM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
How thick is the wing and how wide is the wing's chord?
(I may try my hand at coverting on for sloping, since they are selling for ~$30 on Tower Hobbies.)
dave_lilley is offline Find More Posts by dave_lilley
Old Feb 19, 2003, 03:42 AM
Windsor, UK
Joined Jun 2001
WOW $30 ...... snap it up for e power or slope - thats under half the UK price... a fantastic price for a VERY underated model. Mine is still flying like new - on rails over a massive speed range - with now 100's of flights under its belt. Only mod was to increase elevator area (see pic below) to give it more authority at low speeds. Still found no vices what so ever, and even without rudder servo attached can do all I want (including wingovers - by entering at slight angle). I'm still on Endo + 2.8:1 gear & 10 x 10 but may try BL soon for more continuous out of sight verticals.
Measuring sizes just shows how 'different' this shape is; here are the sizes Dave; Root thickness (just before wing becomes surface that goes to rear of plane, measured in line of flight) 26mm with a cord of 240mm. This tapers to19mm and 180mm at tip (excluding cut off rear corner).
Slope or Powered it can carry an enormous load eg 10 x 2400's or even more - due to big areas ..... Mark
Old Feb 24, 2003, 06:49 AM
oldpilot is offline
oldpilot's Avatar
Joined May 2002
DAVE
I have only just got my Alienator kit, so haven't started on it yet.
I am building it as a sloper but in a way that it can be converted to E flight later on if I want to.
Only changes will be
1. An EPP nose instead of the plastic cone.
2. Delete the centre fin and increase the area and aspect ratio of the other two so it looks more like an S37 Berkut FSW.
Since I make a habit of buying a new Futaba Attack 2ER set for each new sloper, ($78.89 AUD,--- cheaper than two new servos and an RX and RX/charger switch.) , I cant make use of the rudder anyway.
Should have less drag, and penetrate better.
Cheers. Patrick.
Old Feb 24, 2003, 11:02 AM
Texas
Joined Aug 1999
Thanks for the info guys! Mine should be here today. I have several projects to work on first, but I hope to have mine flying soon. (Contrators working on my house broke two of my planes!)
I'm also going to make an EPP nose. I had considered setting it up so that it can be powered by electric power too, but I also thought about covering it with tape to toughen it up for the slope. If I add tape, I won't make it convertable, since the tape will add weight.
Old Feb 24, 2003, 03:28 PM
Windsor, UK
Joined Jun 2001
At $30 I'd buy 2; one for slope with tape (yes it is polystyrene foam so vunerable to scratches on rock or heather landings). And one for e-power.
Old Feb 24, 2003, 05:33 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
That's on 10 cells, right? Have you measured the current?
I have an Endo geared 2.8:1 on only 8 cells (RC2400s); with an Aeronaut CAM 10x8 that pulls 45A static. I normally fly it with 10x6 blades which drops the current to 37A.
With a 10x10 and 2 more cells your Endo must be leading a hard life (but it obviously copes)!
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 25, 2003, 07:56 AM
Windsor, UK
Joined Jun 2001
Yes Bill 10 cells cp1700's & 2000's. Current (from memory was 45-48amps on fresh pack - and i ASSUMED it unwinds in the air ;-). The endo does get hot, so I never fly 'back to back' to let it cool. (I fly something else for 15mins). But with this setup it seems to be fine. I really like the 10x10 .. a great combination of thrust and speed. Mark
Old Feb 25, 2003, 08:47 AM
Joined Nov 2000
That's weird, I was definitely getting about 45A with the 10x8 and 8 cells! Perhaps my timing isn't optimal though, I just turned the end-bell till the rather scary firework display from the brushes stopped!! I went back to the 10x6 blades in the end as I got much better duration with only a slight drop in performance .. that's in a fairly sleek 1.6M V-tail 'warmliner'. But your setup sounds excellent, the Alienator obviously benefits from that extra pitch!
Have you had to replace the brushes on the Endo? I remember the E3D threads saying at those currents they wore out pretty quickly.
Vectron Blackhawk Mini-Review (long) Danal Estes Electric Plane Talk 4 May 07, 2007 11:18 PM
Ripmax Alienator..Check it out! Duane Foamies (Kits) 4 Feb 20, 2003 06:08 AM
First flights of my new FVK Tango and mini-review! jshelton Electric Sailplanes 0 Dec 03, 2001 02:20 AM
RipMax Alienator ARE Foamies (Kits) 2 Nov 21, 2001 11:26 AM
T-52, Hobby Lobby "All Metal Gearbox", 10x6 Folding Prop (Mini-Review) thelocust Foamies (Kits) 0 Jun 05, 2001 04:43 PM
