Old Feb 05, 2006, 05:12 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Tiny-Tiny-Tankbuster - Ju 87 STUKA - Scratchbuilt
I have several kits of the Ju 87 here around (Guillows and FSK), all just in their boxes - no motivation to build!
Now I gotta kick and reworked some of my old drawings.
--- And I started to make my own version - just from the scratch!!
the raw model is about 13" and 5 gram of weight ( until now)
Harpye is offline Find More Posts by Harpye
Old Feb 06, 2006, 12:10 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I'm watching
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 06, 2006, 12:22 AM
MagnusEl is online now
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
She`s a nice looking "bird"!!
Magnus
MagnusEl is online now Find More Posts by MagnusEl
Old Feb 06, 2006, 11:43 AM
Harpye is offline
Harpye's Avatar
Germany
Hope to finish the wheelpants today and perhaps to start painting!!
Any good suggestions for a cammo scheme????
Hansjoerg
Old Feb 06, 2006, 01:08 PM
Tobi is offline
Find More Posts by Tobi
Albatros biplane addict
Tobi's Avatar
Hamburg, Germany
Joined Dec 2004
Ju 87, flown by Stuka Colonel Hans-Ulrich Rudel
If you don't mind depicting the Stuka of a notorious Nazi, then Rudel's "Kannonenvogel" would be my scheme of choice.
More images under http://www.rlm.at/start_e.htm?cont/gal12_e.htm&1
Could you please give us some more details about your carving technique? Your Stuka really looks great, and 5 grams for a peanut sized WWII model (yet without motor/gear, Lipo, Plantraco etc.) seems to be an option ...
Tobi is offline Find More Posts by Tobi
Old Feb 06, 2006, 03:28 PM
Harpye is offline
Harpye's Avatar
Germany
I decided to paint it free...
Unfortunatly my skill in painting planes is not so good ( have to practize more ) what means more planes )
It is no carving, - it is a kind of vacforming without vacuum very easy in tooling and lasts about an hour for the fuse..
Here is a tutorial I wrote about what you called carving and what isn't...
Http://people.freenet.de/Modellbauwa...uiltreport.pdf
Old Feb 06, 2006, 04:01 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hansjoerg,
after all these models you've made, I kind of do not feel like posting in your threads anymore...
These models are excellent!
Have you already decided what electronics to put in?
I also made a Stuka once, from paper, a Fiddlersgreen one. It was about 30 cm span, it was a model to try with the Plantraco electronics.. I never came any further than the paper model only
Anyway, I really love this model. Incredible that you made this while still doing a tutorial for us!
Thumbs up,
Dave
RNAF is offline Find More Posts by RNAF
Old Feb 06, 2006, 04:07 PM
Harpye is offline
Harpye's Avatar
Germany
I think about the following components...
Penta RX 3Gram
2x Xinyu Servo 3,8Gramm
YGE04 Controller - 2Gram
Micro BL - ( not yet built) 4Gram
2x 145 Kokam 7,6Gram
over all ~ 34Gramm @ 32cm WS
( only wish to be better in painting!!!)
Thanks for compliments Dave - but you will do this, too
Hansjoerg
Old Feb 06, 2006, 04:18 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hey Hansjoerg,
it's not that I'm doubting your flying skills, but don't you think it'll be a racer?
Maybe another propulsion and batt? It'll save grams!
Dave
Old Feb 06, 2006, 04:34 PM
Harpye is offline
Harpye's Avatar
Germany
What else system that is allowed to use in Germany - Plantraco ( I'm not sure that it is allowed) - and I really dont know much about flying using actuators... There is another set, that is called Nuke "airborne" -
in combination with a superslicker propulsion set - it would work @ 1 cell kokam!!
so
Nuke Set ( 9 Gram)
1x145 Kokam 4gram
Motor gear Prop 5 Gram
All together about 30 gram
not much weight safed ( 5 to 6 gram) - but costs about double as the "standardcomponents" and has about 150m of range compared with 500 m with the first selection.
I use a slowflyer foil with a high FA to FF quotient - so I will need large prop...
I quess it will be fast but not too fast.... and if this doesn't fit I will build a larger plane and use the components in that.
Hansjoerg
Old Feb 06, 2006, 05:10 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Plantraco on 868mhz is allowed in the EU
geared 6mm pager.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Feb 06, 2006, 06:16 PM
watersharer is offline
Find More Posts by watersharer
Time wounds all heels.
Phoenix, AZ
Joined Jul 2001
Nuke is known here in the states as Cirrus MicroJuele.
I had a lot of issues with mine, the gear is neater than all get out, but the servos would never center properly. Made it hard to fly micro planes when you couldnt trim them out.
I have heard that the newer servos are improved, but not sure if mine are old or new. The Rx is nice, better range than you need at this scale, and the ESC's are fairly high quality. My only gripe was the servos, fragile and poor centering.
watersharer is offline Find More Posts by watersharer
Old Feb 06, 2006, 07:32 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
MJ works good with Falcons, if you reverse a couple of wires, or PinPoints as they come wired... The whole flight pack (RX, ESC, 2 servos) is now $80 on sale at Hobby People...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Feb 07, 2006, 12:11 AM
flyingjibus is offline
Find More Posts by flyingjibus
Tamer of Penguins
flyingjibus's Avatar
Portland, Oregon
Joined Sep 2003
Your paint job looks great. I have painted many Stuka's and when you put the crosses and such on there it will look just fine. Kind of a desert/jungle scheme.
Amazing work all around.
flyingjibus is offline Find More Posts by flyingjibus
Old Feb 07, 2006, 12:41 AM
Harpye is offline
Harpye's Avatar
Germany
Graham - Allowed in the EU is not allowed to use in Germany - I wanted to build myself a superregenerative receiver with about half a gram - I started with design - ( colpitts OSC and 3V lowcost PIC) but I talked about
possibilities of certification to the German " Netzagentur" the told me that approval referreing to RTTE Rules of radio and telecom must fit and the test would take me some thousands of $... I asked @ Plantraco and the told me that they fit some EMI approvals but the werent able to tell me if they fit te RTTE - ( in Germany 868MHz UHF is reserved for wireless phones) - I will ask back!!!
Mike - didn't hear of MJ yet - will get informations about!!!
Watersharer - I preferred the nuke set - until now -seems to be not the right kit .....
Thanks for the compliment on painting - but I'm still not really satisfied!!
Anyone know of a Junkers Ju-87 Stuka kit or ARTF? The Max-Q Parkflyers 12 Mar 07, 2009 09:07 AM
Scale Model JU-87 STUKA convert from paper model yctseng Scale Kit/Scratch Built 37 Nov 30, 2007 02:17 PM
Yippee! Detailing a GP JU-87 Stuka Phantom Phreak Fuel Warbirds 4 Jun 21, 2004 06:55 AM
Ju-87 Stuka, Divebomber! D W Parkflyers 87 Dec 04, 2003 07:10 AM
fs JU-87 Stuka 34 inch wing span CLARKE Aircraft - Electric - Airplanes (FS/W) 5 Jun 10, 2002 06:54 AM
