Old Jul 26, 2006, 02:19 AM
Bigplumbs is offline
Find More Posts by Bigplumbs
Keep building, buying,fly
Bigplumbs's Avatar
Suffolk, In the UK
Joined May 2004
Originally Posted by casioppc
Hi Jurgen and any expert here
I flew the FunJet on mega 4T on APC 6x4 (drawing about 29A) and on warp4 3T on APC 5.5x4.5 & 5x5 (both props drawing about 40A) on same FlightPower 2150-3S pack and strangely the FunJet flies faster on mega 4T on 6.5x4. I thought my warp4 is spoilt so I borrowed my friend's warp4 3T and also encounter same slower speed as compared to mega4T.
Do you know why is it so?
Thanks in advance.
This is indeed confusing especially as I was about to buy a mega 16/15/3 to put in mine. I can only think that it is something to do with efficiency. At 40 amps compared to 29 amps you should have around 100 more watts of power. This could all be going in heat I surpose but it is confusing.
Also I run 3 mega 16/15/4 's on 3 cell lipos and only ever get around 22 amps.
The other thing of course is that you might be approaching the airframes max speed but with that thin wing I doubt it. Also if you look at Jurgens funjet on a fun 400/28 (similar to a mega 3 turn) it is certainly faster than mine on my 16/15/4.
Stupid question but is it possible the prop is slipping or even out of balance as this will effect efficiency ?
Not much help I am afraid but just some thoughts.
BTW Just flew mine on the 16/15/4 and APC 6 X 4 and I thought 'Do I rearly need quicker' ?
www.densplanes.co.uk
Bigplumbs is offline Find More Posts by Bigplumbs
Old Jul 26, 2006, 02:37 AM
Bigplumbs's Avatar
Suffolk, In the UK
Joined May 2004
Mega 16/15/3
I would quite like to see some video of a funjet flown on a Maga 16/15/3 on 3 cell lipo if anyone has any
Regards
Dennis
Old Jul 26, 2006, 04:35 AM
ModelTony is offline
Find More Posts by ModelTony
ModelTony's Avatar
Irvine, Scotland
Joined Jun 2004
Thanks in advance.
Your figure for the Warp4-3 does seem rather high. I had about 31 amps running 5.5 X 4.5. I am using a Graupner 5.5x5.2 now and it gives a little increase in speed. To about 75 on the level using a speed gun.
For a given motor speed a 6 x 4 prop will probably give a greater static thrust than a 5 x 5, but as the airspeed increases the thrust from the 6 x 4 will reduce at a higher rate than the 5 x 5 until at a certain airspeed the thrusts will be the same (for example, say at 70 mph). If the airspeed increases above 70mph the 5 x 5 will have the greater thrust. As the aircraft flies faster the drag increases and when the drag equals the thrust the aircraft will stop accelerating. If this speed occurs before 70mph the 6 x 4 will have higher thrust and so the aircraft will fly faster with this prop, if above then the 5x5 prop will give the greater speed.
Tony
ModelTony is offline Find More Posts by ModelTony
Old Jul 26, 2006, 11:39 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
casioppc,
To know the full story, you'd need the RPM. I suspect that the lower kv motor is faster because it has enough torque to turn the slower prop faster. The higher kv 3T motor is probably slightly overloaded and cannot turn the prop fast enough to use the higher pitch speed.
It is either that, or your eyes are deceiving you, and it really IS faster.
To know for sure, buy or borrow a tachometer and measure the prop rpm. Then calculate the pitch speed based on the RPM and prop pitch. I think that things will "add up" then.
Jeremy Z is offline Find More Posts by Jeremy Z
Old Jul 26, 2006, 11:41 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Thanks in advance.
The MEGA should not run at more than 25A, but even at 29A it should be much more efficient than a WARP 4 at 40A. The 6.5x4" prop should also be more effcient than a 5x5". For a direct comparison, you would need to run both motors with the same prop.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 26, 2006, 11:44 AM
Joined Sep 2000
If it is too fast, you can always throttle back. If it is not fast enough at full power, there is not much you can do.
Jürgen
Old Jul 26, 2006, 12:45 PM
Bigplumbs's Avatar
Suffolk, In the UK
Joined May 2004
That was faster
Just put an APC 6 X 5.5e on mine with the Mega 16/15/4 with a flight power 1800 mah 20c 3 cell and she was considerably faster than with the APC 6x 4e and had very good climb/vertical. It was more windy though so perhaps not a fair test. My battery was hotter but not too much. I will test the amps to see where I am on the 6 x 5.5. Jergen is correct about the spec of the 16/15/4 being max 25 amps but I feel they can take more as has been proved in many other forums.
What fun we have especially with this little gem of a plane
Old Jul 26, 2006, 02:53 PM
Bigplumbs's Avatar
Suffolk, In the UK
Joined May 2004
Put my 6 x 4 Back
Tried the 6 x 5.5 prop with my Thunder Power 2100 13 C and it got rather hot. I have put my trusty 6 x 4 APC back on her and I think I will stick with that.
Old Jul 27, 2006, 08:01 AM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Just got the new Multiplex Himax motor for the Funjet. I'tll be interesting to see what it throws out. Has anyone used one of these yet.
I would be trying it out right now considering I've got a couple of weeks of work, but er indoors decided she wants the decorating done. NOT FAIR.
Mark
www.rcflights.co.uk
MarkJayne is offline Find More Posts by MarkJayne
Old Jul 27, 2006, 11:41 AM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Ok, managed to check the Amp draw with the new motor.
She's pulling 31 Amps with a 2500 20C 3s1p and a 5.5x4.5 prop.
I may even get a quick flight later on.
Mark
Old Jul 27, 2006, 01:13 PM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
So which Himax is that? 2815 or 2825? I'd like to hear how it does.
Matthew
Matthew Allen is offline Find More Posts by Matthew Allen
Old Jul 27, 2006, 01:40 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Matthew
Its the HA2825-2700.
I flew it tonight. Very good. I had a few issues with my receiver as I had to move it behind the battery. Because this motor is quite a weight, the CG was to far back so a little rearranging was needed. I launched at full throttle and she flew straight with a nice gentle climb. Speed was also good with plenty of vertical performance.
Just need the RX sorting out as I did have a little interferance ( well she went down actually ).
Anyway I did get the flight on video, so I'll edit it up and let you guy's know when its up and running.
For now....
Mark
www.rcflights.co.uk
Old Jul 27, 2006, 03:04 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Video is now up on running of the Funjet with the new Himax HA2825 BL Motor.
The link is on the home page and not in the video's section.
Mark
www.rcflights.co.uk
Old Jul 27, 2006, 03:38 PM
beetlebiz is offline
Find More Posts by beetlebiz
France
Joined Jul 2006
That's cool Markjayne, mine is ready to fly with the same motor. How do you think using a 5x5 APC E ?
beetlebiz is offline Find More Posts by beetlebiz
Old Jul 27, 2006, 04:48 PM
kraaijer is offline
Find More Posts by kraaijer
Belgium
Joined Apr 2006
Mark
www.rcflights.co.uk
Mark,
I could be wrong, but it looks like it is not as fast as your previous setup....
Other then that, awsome filming there as usual
Ron
kraaijer is offline Find More Posts by kraaijer
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
