Old Dec 23, 2008, 05:16 PM
fishboy77 is online now
Find More Posts by fishboy77
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Originally Posted by Thekid3418
Another key if you're going to abuse lipos is to not discharge them as much, a lipo will be much happier only discharging to 50% or 40% of its capacity. If you push every flight down to 20% (the recommended level), your batteries will start wearing out sooner. The further your batteries are drained the more likely they are to have differenent voltages in the cells, this will cause wear and tear
This has been my experience as well. I have several of the uber cheap Mystery 2400 mAh 15C packs with over 100 cycles on them and they are still going strong. But I only use about 60% of the total capacity each flight.
fishboy77 is online now Find More Posts by fishboy77
Old Dec 23, 2008, 06:57 PM
jnyoun is offline
Find More Posts by jnyoun
Spritual Pilot
Silicon Valley, CA
Joined May 2001
How do you know the percentage of battery discharge? Let's say the battery capacity is 4s 2200mah. Could you explanin more what it means by only 50% of the capacity? Is there any good way to measure that the battery contains 1100mah at some point? Or, the voltage will tell the capacity?
jnyoun is offline Find More Posts by jnyoun
Old Dec 23, 2008, 08:51 PM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Time your flights and then see how many mah's go back into the battery to charge it full. Then adjust your flight times from there.
If you fly your 2200mah battery for 5 mins and then recharge and it takes 1100mah back in then you know a 5 min flight will take you down to approx 50% depending on throttle variations during each flight.
Wingwrecker is offline Find More Posts by Wingwrecker
Old Dec 23, 2008, 10:35 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Yeah, you really just have to get a feel for it. It all depends on how much WOT you use, and how aggressive of a setup you are using. I would say if you kept a flight around 4 minutes you'd be fine. I usually fly my stuff for 5 minutes. And im either on throttle or off, not really inbetween. I just guess at it.
You have to get a feel for how your batteries react too. If you fly them down to 50% and they are fine (no balance issues, warm to the touch) then you know you can fly a little longer. Its just if you push it in every way time in and time out, thats when they become unhappy
Thekid3418 is offline Find More Posts by Thekid3418
Old Dec 23, 2008, 10:40 PM
neiloneil is offline
Find More Posts by neiloneil
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
there should be a way to tell by the voltage..but im not that bright...pun intended
neiloneil is offline Find More Posts by neiloneil
Old Dec 24, 2008, 12:52 AM
efether is offline
Find More Posts by efether
Crash - Rebuild - Repeat
efether's Avatar
Atlanta, GA
Joined Aug 2007
50% of capacity = 1/2 of the mAh rating of your pack. If you have a 2200 mAh pack...then 50% = 1100 mAh. Think of your mAh as Fuel. Voltage = power. If your pack drops below 3.0 volt per cell (12.0 for a 4S), you should be landing...regardless of how many theoretical mAh are left in the pack. I have some 3S2200 ThunderPower V2 packs that hit 9V with only 1600 mAh expended....theoretically, I still have 600 mAh to go...but reality says..."Land!"
As for how to tell when you're at 50%:
1. Time your flight and then charge your pack. Your charger will tell you how many mAh you used, and use some math from there.
2. Use an in-flight telemetry system that can report back to you. EagleTree makes one, and there are some out there that will even talk to you.
Personally, I use math. And I use it before I ever maiden a plane...
Flight time = Battery Capacity (Amps, not mAh) * 60 / Draw.
So, at 40 amps, using a battery with a capacity of 2200mah
Flight time = (2.2 * 60)/40
Flight time = 3.3 minutes or 3 minutes 18 seconds WOT
Fire up your watt meter...and get out a calculator. This equation will help you set your initial timer.
I hope this helps.
-Eric
efether is offline Find More Posts by efether
Old Dec 24, 2008, 03:22 AM
jnyoun is offline
Spritual Pilot
Silicon Valley, CA
Joined May 2001
Well, I am a little bit surprized that you are following all of these complicated procedures to figure out the discharge capacity. In my case, even until two weeks ago, my lipo charger did not have a LCD to show the charged capacity. Seems like it is going to be far beyond what I expected, hobby..
By the way, I have been using my home-made Lipo charger almost for 5 years. I have never had any problem so far. A few month ago, I started to use it with balancer. However, without balancer, it just worked fine.
Unfortunately, my DIY charger only supports 3s packs. Two weeks ago, because of the need of 4s packs, I purchased Turnigy ACC-6 charger. It worked good, but not that much better than my old charger.
The picture below was taken in 2003. I am still using it. Probably, I charged a couple hundred times so far. It is rather safer because the number of electric componet are small and the circuit is simple (less chance to broke)..and it can be immediately detected any problem if it has...(However, I don't recommend to use this kind of charger for your safety).
Old Dec 24, 2008, 09:19 AM
rstein9 is offline
Find More Posts by rstein9
The Flying Herb
rstein9's Avatar
Santa Barbara, California
Joined Jul 2007
a bit paranoid?
i put my batteries in and run them until they stop.
same lipos for over a year charging them everyday....i even balance them once in a while.
just fly.
rstein9 is offline Find More Posts by rstein9
Old Dec 24, 2008, 11:17 AM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
yup i fly to 2.9 volts/cell everytime i get around 100 discharges
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Dec 24, 2008, 03:32 PM
efether is offline
efether's Avatar
Atlanta, GA
Joined Aug 2007
Yup...I do that with my slow stuff...like my Speedwing EX, or my foamies. But when I have a high wing loaded bullet flying around at 130+ MPH...I like to know when I'm low on gas and need to land.
If I fly until the pack is exhausted...I only get one shot at a landing...and sometimes I need 2 or 3 passes to bleed the speed enough for a touchdown where I want it. That...and the fact that I enjoy Math...it's not too hard for me to figure out when I'm running dry
-Eric
Old Dec 24, 2008, 04:19 PM
lammy1000 is offline
Find More Posts by lammy1000
Joined Jan 2005
Can you guys post the duration of your flights and when(if) you set your timer alarn. Thanks and please don't leave out details. My set-up with micro-dan 2505 2800kv on Fusion 3s 2200 lipo has been an exciting plane, but winter temps prevent concluding any real data. I limit flights to too cold fingers at 6 minutes, but the reality might be ~11 minutes which is more than enough flight time. Landings on snow have been smooth with one exception at 24 deg which did not appear to make the foam brittle.
I am surprised that the heavier inrunner motors dominate, especially since the microdan 4800kv "velocity" motor is a 600 watt motor that should satisfy most speed freaks?
lammy1000 is offline Find More Posts by lammy1000
Old Dec 24, 2008, 04:35 PM
Lostlad is offline
Find More Posts by Lostlad
What smoke?
Lostlad's Avatar
SoCal
Joined Feb 2008
I use the Medusa in-runner and can say when running next to a microdan you can really see a power different, even when I see Arc motors next to the microdan.
The microdan is ok but doesn't have some speed or punch out like a good in-runner can do. Don't get me wrong they are good motors but it's like saying I'll have the store brand soda because they almost taste the same as a Pepsi or Coca Cola.
Lostlad is offline Find More Posts by Lostlad
Old Dec 24, 2008, 06:24 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
There is clearly a correlation between pack voltage and % discharge, however I'm not sure how consistent this correlation is between different brands of batteries. However, I do know that 3.8V/cell (resting) is about 40% capacity for both Mystery packs as well as the silver Zippies.
Old Dec 24, 2008, 07:04 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
With my Suppo 2212-06 (2200 kv) and APC 5.1x4.5E prop I'm averaging about 10 amps in flight, which should yield about 12 minutes of flight from my 2400 mAh Mystery packs without exceeding 80% capacity. This motor/prop combo pulls about 18 amps at WOT, which is probably about as low as it gets in this forum.
Some of the 47 mm ARC motors (eg the 1.5T) can handle 1000 watts continuously and 2000 watts for short periods. When you have that much power behind you, an extra 3 ounces of AUW is negligible. At around 500 watts, when the MD 2505 starts to sweat, the big ARCs are still running efficiently. The MD 4800 is designed for a 4" prop (and even then you're up to 50-60 amps on 3s) that won't provide much thrust (20 ounces) for a FJ. I'm not dogging the MDs - they clearly have their place. But so do the big inrunners.
Old Dec 25, 2008, 12:12 AM
chuck George is offline
Find More Posts by chuck George
USA, NH
Joined Sep 2004
Merry Xmas
chuck George is offline Find More Posts by chuck George
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
