Old Dec 13, 2008, 01:47 PM
FL Knifemaker is offline
Find More Posts by FL Knifemaker
St. Boondock
FL Knifemaker's Avatar
Joined Aug 2008
I was suprised to see the guy start it in the back of his car I'd prefer to put that motor in slightly larger, more forgiving platform...........at least until I got used to it. More wing would require less running on the launch too
FL Knifemaker is offline Find More Posts by FL Knifemaker
Old Dec 13, 2008, 02:36 PM
jimweda is offline
Find More Posts by jimweda
Fast, faster & fast again
North Hollywood, CA
Joined Jul 2007
Yes that is. That's the first Funjet turbine I've seen, but I did see some pretty cool video on a Twinjet with a mini turbine on it. Sweet, but those are so expensive.
Jim
Originally Posted by War Machine
Is that really a FJ with a turbine ?
(scoll down to the pic)
http://www.rcgroups.com/forums/member.php?u=1636
jimweda is offline Find More Posts by jimweda
Old Dec 13, 2008, 03:14 PM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Personally I think this parkjet is even cooler!
Air-Tech Mini SU-35 powered by Lambert Kolibri (1 min 55 sec)
Ben D Wing is offline Find More Posts by Ben D Wing
Old Dec 13, 2008, 03:52 PM
jimweda is offline
North Hollywood, CA
Joined Jul 2007
Oh man that was sweet. I'm surprised that didn't turn into a weenie roast on launch. Sweet flyer. Hopefully one day these will come down in price so I can get into turbines, even the mini ones. They sound fantastic. Thanks for the video, I hadn't seen that one before.
Jim
Old Dec 14, 2008, 02:22 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Originally Posted by EyeFlyPlanes
what kind of motor & prop?
It was on flight #3...the first 2 flights were the same...plane rolled to the left every time...motor is a Mega 16/15/3 with a 4.79X4.79 prop with a 3S 2200 25C lipo. When you guys launch your plane are you at WOT?
bighead93 is offline Find More Posts by bighead93
Old Dec 14, 2008, 02:29 PM
Zeta30 is offline
Find More Posts by Zeta30
Team Mulikow
Zeta30's Avatar
Joined May 2007
I launch at 3/4 throttle and throw at about a 60 degree angle up.
Zeta30 is offline Find More Posts by Zeta30
Old Dec 14, 2008, 02:31 PM
slowdragon is offline
Find More Posts by slowdragon
Joined May 2006
I was told by a friend to try half throttle on launch on my Stryker and man it is nice to launch it that way or just a little above half. Slowdragon
slowdragon is offline Find More Posts by slowdragon
Old Dec 14, 2008, 02:33 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
That's torque roll, normal, mine does it. I do full throttle and a hard slightly up throw. I'm using a 6x4 prop so it bites better/quicker. It's more of a challenge with the smaller props.
I have learned not to freak out as it looses altitude and rolls. Quick jerky pokes of the stick bring it down. Small easy corrections with some expo and it's off.
Don't make the mistake my buddy is good at - he doesn't pay attention to the wind and sometimes launches with it, not too helpful.
flydiver is offline Find More Posts by flydiver
Old Dec 14, 2008, 04:26 PM
Eagle50 is offline
Find More Posts by Eagle50
Full throttle baby!
Eagle50's Avatar
Arizona
Joined Jan 2007
Evolution of addiction.......
Wow first slowflyers, then pusher props, then EDF's and now I can easily see moving forward into the small turbine$! There is something about that sound that can just catalyze one's need for speed!
Addiction:
"The compulsive need for and use of a habit-forming substance, characterized by tolerance and by well-defined physiological symptoms upon withdrawl"
Eagle50 is offline Find More Posts by Eagle50
Old Dec 14, 2008, 06:29 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
What prop should I use?
Old Dec 14, 2008, 07:23 PM
jimweda is offline
North Hollywood, CA
Joined Jul 2007
Yeah, I know what you mean. If it wasn't so expensive I'd already be flying a turbine. Maybe one day they'll drop enough for the average joe to run. I doubt it, but one can alway hope.
Jim
Addiction:
Old Dec 14, 2008, 08:30 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
HXT 2835 (380S) 2700kv Brushless Inrunner
Has anyone tried one of these on a 4S? If so how did it work out?
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
Motor Size: 2835 (380S)
Speed: 2700kv
ESC Required: 25A
Voltage Range: 6~12v
No Load Curr: 1.2A
Max Load: 35A
Diameter: 28.2mm
Length: 37mm
Front Mounting Hole Distance: 19mm
Front Mount Thread Size: M3
Shaft Diameter: 3.2mm
Shaft Length: 12mm
Weight: 102grams
brati4 is offline Find More Posts by brati4
Old Dec 14, 2008, 08:36 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
Thats a good 3s motor but on 4s your prop size will be too small to go fast. they run hot.
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Dec 14, 2008, 08:39 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
thanks for the info. Any help is most appreciated. I'll primarily be running a 4S 2200-2350 batt.
Old Dec 14, 2008, 09:43 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
From experience using a 4s lipo
this motor with a 4.7 x 4.2
This motor on a 6 x 5.5: 105 mph 450 watts 6 x 6 graupner 470 watts and 108 mph
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
