Old Dec 09, 2008, 02:23 AM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
I have heard many ways to install servo's. I did what MPX suggests in thier manual in mine. Wrapped the servo in tape then CA'ed them in. I can say it makes it fairly easy to remove as I have had to replace a servo in my FJ once in 75+ flights.
Another that is commonly used is Hot melt glue. Holds everything in tight as its needed and actually does come back off with a little rubbing alcohol to soften without too much fuss.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Dec 09, 2008, 06:09 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Also, wrapping the servo in masking tape and then using UHU Por as a contact adhesive works very well too, not to mention bathroom silicone sealant!
Ben D Wing is offline Find More Posts by Ben D Wing
Old Dec 09, 2008, 10:17 AM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
United States, CA, Santa Clarita
Joined Feb 2008
Originally Posted by fishboy77
Nice. I have a NIB FJ on the way. Are there any tricks for installing the servos in such a way that you can remove them without damaging the wings?
Ya absolutely. When u put them in, make sure you don't put any ca on the bottom of the servo. Just outline your servos with CA - Then when u put the servo covers on, again sparingly with the ca on the 4 corners -but make sure youve used enough where its not flappin in the wind and its completely flush. Then when your ready to remove, get an exacto knife and very carefully cut through the ca so as to not touch any foam. Everything should break free pretty cleanly.
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Dec 09, 2008, 11:50 AM
numb_thumb is offline
Find More Posts by numb_thumb
Bay Area, CA
Joined Sep 2007
1. Ordinary double sided tape or servo tape sold in your LHS.
2. Glue gun.
3. Strapping tape.
Cut the double sided tape and peel off one side of the tape and stick it into the servo bay. Using the other end of a hobby knife or similar, rub the tape with enough pressure so that it sticks well and also compresses uniformly into a thin tape.
Peel off the top side and stick the servo in. Press the servo with enough force to ensure a uniform stick.
Hot clue the four edges and more if you want to and then I usually lick my fingers and run my fingers on the glue to squeeze it just a bit in between the servo edge and the bay.
Let the glue dry and apply a layer of strapping tape over the bay. Servo cover can then be installed after you have completed the control horn assembly.
Why hot glue & double sided tape instead of CA? CA gets brittle when dries. In the event of a mild crash, the shock is directly transferred to the servo (and to the gears) and this increases the chance of ripping the gears.
Using double sided tape and hot glue helps ease the shock, just a bit, if not more. The double sided tape acts as a cushion and the hot glue nevers gets brittle.
And it is easily removable too.
Happy flying !!!
numb_thumb is offline Find More Posts by numb_thumb
Old Dec 09, 2008, 01:43 PM
fishboy77 is online now
Find More Posts by fishboy77
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Wow, thanks for all the advice, guys!!! My FJ is scheduled to arrive TODAY. Woohoo!!!
fishboy77 is online now Find More Posts by fishboy77
Old Dec 09, 2008, 03:01 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I used certain parts of aileron servo holders on my EZ* - servos just slide in as a very tight fit.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 09, 2008, 04:02 PM
bighead93 is online now
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
My build is just about done! I am running HS-65MG's and wrapped tesa tape around the area that makes contact with the foam...applied CA and installed! Tight fit but will allow removing it without damaging the wing. I got a question for you guys already flying your FJ's...anyone use magnets to hold on the canopy? I can't see how these little clips will hold tight at a really high rate of speed...got any pics if so?
bighead93 is online now Find More Posts by bighead93
Old Dec 09, 2008, 04:14 PM
jteplane is offline
Find More Posts by jteplane
Fly by Night
jteplane's Avatar
Phoenix, AZ
Joined Jan 2007
Yes Im using magnets, I extracted them from an old cdrom brushless motor (rectangular in shape) and used one both sides canopy and fuse. I also man one large canopy so I can have access to the rear electronics....
jteplane is offline Find More Posts by jteplane
Old Dec 09, 2008, 05:39 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Anyone know what size the motor screws are that mount the motor plate to the Fuse?
Old Dec 09, 2008, 05:50 PM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
this one should do the trick
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Dec 09, 2008, 06:05 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
I was going to take it up to my local Home Depot...allen heads are the easiest to work with but I thought I would ask if anyone know the size...I have read that they strip pretty easy...is there a trick to getting them in without stripping them?
Old Dec 09, 2008, 08:56 PM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Take the original flathead screws (which do suck) with you to your LHS or hardware store and have them match up the threads. Do get allen head bolts. They make it soooo much easier if you plan to tinker with motors.
Wingwrecker is offline Find More Posts by Wingwrecker
Old Dec 09, 2008, 09:09 PM
jonnyjetprop is offline
Find More Posts by jonnyjetprop
jonnyjetprop's Avatar
USA, FL, Apopka
Joined Sep 2003
3mm, I think.
John
jonnyjetprop is offline Find More Posts by jonnyjetprop
Old Dec 09, 2008, 09:17 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
3x16 by my measurements.
Old Dec 09, 2008, 09:34 PM
Joined Feb 2008
If I remember correctly, the manual gives a number for the type of screw and it was the same number on the package of screws I got from my LHS. Could be wrong on that one though..
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
