Old Oct 20, 2008, 08:27 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Hey, guys... how will the Arc 28-47-2 perform on 3s with a 5x5 prop?
I'm itching to get started on a Funjet...looking for a setup that will run fast on 3s but have room for a major boost by moving up to 4s.
Thanks!!
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Oct 20, 2008, 08:56 AM
efether is offline
Find More Posts by efether
Crash - Rebuild - Repeat
efether's Avatar
Atlanta, GA
Joined Aug 2007
Thanks!!
That motor...with a 6x5 prop on a 3S will push the Funjet up to about 110 MPH; 127 MPH on 4S, and the 140+ range on 5S. You'll be pulling up to about 60 amps as the size of the pack grows. Just be careful...over 130 MPH, smaller servos (like the HS-55) can't move the control surfaces. Built it with Servos that can do 30+ oz-inch of torque if you're going to push it...and also re-enforce the elevons...the foam bends a that speed too.
Be safe...and have fun
-Eric
efether is offline Find More Posts by efether
Old Oct 20, 2008, 10:00 AM
xyz-2-xyz is offline
Find More Posts by xyz-2-xyz
California
Joined Mar 2008
Originally Posted by Aio_1
Where do you fly?
Anything but a very lightweight Funjet doesn't seem like a suitable plane to be flying near houses and roads.
i fly at a local school. really a bas space but i havent crashed a plane in two years. I think i had some interfearance... idk my 3s 2500 blew up into flames. i wish i had a camera to folm the whole thing.
xyz-2-xyz is offline Find More Posts by xyz-2-xyz
Old Oct 20, 2008, 11:30 AM
Joined Jun 2005
-Eric
Great info!! Thanks, efether.
Good to know that the HS-55s will work above 100...but I think its good advice to just start with stronger ones.
Old Oct 20, 2008, 01:05 PM
Joined Jun 2005
I ordered up my Arc 28-47-2 motor!! I hope to get some flights on this thing before the snow flies.
I am hoping that I don't slit my wrist on the fist launch.
It looks dangeous to launch one of these pusher prop planes.
Old Oct 20, 2008, 02:37 PM
gwong is offline
Find More Posts by gwong
gwong's Avatar
Vancouver, B.C., Canada
Joined Sep 2003
Originally Posted by Zeta30
I have never had problems with torque rolling with mine. Granted I don't have a real powerful set up, I'm only pulling about 400 watts but torque rolling has never even been close to a problem.
Yes you are right, on closer inspection my port side servo failed in flight. It was working as I always do a preflight check.
I just check them as I was going to put the servos into another plane and the starboard side servo is dead. The servo is a HS65.
Cheers,
Gord.
gwong is offline Find More Posts by gwong
Old Oct 20, 2008, 02:49 PM
bigandy is offline
Find More Posts by bigandy
Pesky Landings!
bigandy's Avatar
Abergele, North Wales, UK
Joined Apr 2004
Hi Folks,
I've had a good search through this thread, and so far drawn a blank. I was wondeirng if anyone knew of a scaled up Funjet at all? I'm looking at something a little different as a quick build winter project, and I was thinking that my Funjet flies great, it would be really cool as a x2 scale version (Obviously with a more powerful motor!)
Cheers
Andy
bigandy is offline Find More Posts by bigandy
Old Oct 20, 2008, 05:25 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
you could do a twinjet with a single motor. Or better yet a twin jet with TWO motors
Thekid3418 is offline Find More Posts by Thekid3418
Old Oct 20, 2008, 05:53 PM
neiloneil is offline
Find More Posts by neiloneil
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
all hell ..i got that suppo 70A esc as a combo with the motor from lightflight...is this esc crap??...i hate to keep ordering from hong kong every week..doesnt hobby city have a us warehouse?
neiloneil is offline Find More Posts by neiloneil
Old Oct 20, 2008, 07:26 PM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Originally Posted by bigandy
... it would be really cool as a x2 scale version (Obviously with a more powerful motor!)
Did you say x2 ???
Wingwrecker is offline Find More Posts by Wingwrecker
Old Oct 20, 2008, 07:29 PM
Joined Feb 2008
I'll give you the same advice I've given others, as it works great for me. Learn to launch left-handed so that you can keep your right hand on the elevator during launch. This wont stop your wrist from gushing but it sure helps to keep the plane from skiffing the ground...
Old Oct 20, 2008, 07:31 PM
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
Originally Posted by Wingwrecker
Did you say x2 ???
sweeta!
Old Oct 20, 2008, 08:32 PM
skaffen is offline
Find More Posts by skaffen
Ook!
skaffen's Avatar
New Zealand
Joined Aug 2007
Hiya. I'm planning a Funjet with an Arc 28-47-2 and a Plush 60A ESC on 4S. Just wondering what's the best C and mAh to balance batt life/weight/power?
I have some 18C 4S 2200mAh batts already, will 18C cope?
skaffen is offline Find More Posts by skaffen
Old Oct 20, 2008, 08:48 PM
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
what size prop are you planning
Old Oct 20, 2008, 08:52 PM
pcliftonjr is offline
Find More Posts by pcliftonjr
Fast Foamer
pcliftonjr's Avatar
Phoenix, AZ
Joined Jan 2006
It depends on what prop you use...I'd suggest using at least 20C 2200 packs. Mine runs around 45A WOT with a 6x4 sport prop.
Paul
pcliftonjr is offline Find More Posts by pcliftonjr
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
