Espritmodel.com Heli Air
Closed Thread
Old Oct 19, 2008, 04:41 PM
Team Mulikow
Zeta30's Avatar
Joined May 2007
I have never had problems with torque rolling with mine. Granted I don't have a real powerful set up, I'm only pulling about 400 watts but torque rolling has never even been close to a problem.
Zeta30 is offline Find More Posts by Zeta30
Old Oct 19, 2008, 08:18 PM
..it goes 100 miles per hour..
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Currently installing a 2W-20 and Turnigy 60A Plush in my FJ as I type this.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Latest blog entry: My new addiction.
Old Oct 19, 2008, 08:46 PM
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
Jason
SHould haul ass like that vid in the hay field!
Wingwrecker is offline Find More Posts by Wingwrecker
Old Oct 19, 2008, 09:10 PM
FlyA123's's Avatar
Tornado Alley, Kansas - USA
Joined Oct 2008
I am just finishing up a carbon reinforced Funjet.
Gonna run a Steve Nue 1107/2y/H/3.2 heli motor with built in fan.
Gonna turn a Aero-naut 6x5 carbon prop using 4s and 5s 30c lipos.
Can someone moto calc that for me please, may need to go up from a 60a esc to an 80?
FlyA123's is offline Find More Posts by FlyA123's
Old Oct 19, 2008, 09:11 PM
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
ive decided to go with the arc 28-47-2 hopefully it will do well..also going with a 70a esc..(better safe than sorry)will prob run on 2200 3s and 4s...
neiloneil is offline Find More Posts by neiloneil
Old Oct 19, 2008, 09:12 PM
Fast, faster & fast again
North Hollywood, CA
Joined Jul 2007
Between those three motors I'd go with the 28-47-2 or 1.5. I've played with both and on 4s for the 2Y and 5s on the 1.5Y you'll get some awesome speed and vertical.
Jim
Originally Posted by EyeFlyPlanes
Neiloneil,
Heres what u want...
$59 ARC 28-47-2 http://www.lightflightrc.com/HTML/pr...RC-28-47-2.htm
$42 Rhino 2350mAh 4S1P 25C Lipoly Pack
http://www.hobbycity.com/hobbycity/s...5C_Lipoly_Pack
$46 TURNIGY Plush 60amp Speed Controller
http://www.hobbycity.com/hobbycity/s...eed_Controller
5X5 Prop and your set.
Insane speed.
jimweda is offline Find More Posts by jimweda
Old Oct 19, 2008, 09:41 PM
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
any suggestions on prop size for the setup i mentioned
Old Oct 19, 2008, 09:54 PM
North Hollywood, CA
Joined Jul 2007
Keep an eye on your amps, but I've run those set ups on 7x6, 7x5, 6.5x6.5, 6x6 5.25x6.25. Any props around that size will be fine. Test different set ups. I have to say that I favored the 28-47-1.5Y the best and I was able to run that up on 5s as well. You can really push those ARC motors. Good for the price for sure and Dave is a great guy to deal with. I never worried much about my amp draw because I always used an 80amp Castle Creations Phoenix ESC, so, like I said, keep an eye on those amps depending on your battery and ESC. I used Thunder Power 4s and 5s - 3300 V2's.
Jim
Old Oct 19, 2008, 11:08 PM
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Agreed, a watt meter is a must for this application. I would start out with a 6x4 and see what that pulls. If you could make it to a 7x5 that would give you more thrust, but I bet the smaller prop and higher R's might give you a bit more speed.
Diggs
Diggs is offline Find More Posts by Diggs
Old Oct 19, 2008, 11:39 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Wingwrecker, That is the point. I am putting a JS-1400 in my A-4 so the 2W-20 came available and with the FJ without a motor it was a no brainer. She is gonna see some air for trimming and such tomorrow. Then she is getting packed up for SuperFly.
Jason
Old Oct 20, 2008, 01:05 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
To the guy ordering the 28-47-2. If you're getting a 70a suppo controller from lightflight as well, make sure you check. BEcause i ordered one of those at first, and it was for 4-7s only, so you wouldn't be able to run 3s. So you might want to order a different ESC.
And about the 1107-2Y. If you run a 6x5 on 4s you're looking at 114 amps, and on 5s you're looking at 151 amps. So all i have to say about that setup is lol
You might look into something like a 4.75x4.75 on 4s (maybe 5s) or a 6x5 on 3s (76 amps). or something really small on 5s, like a 4.1x4.1 or 4.5x4.1. Lightflightrc sells a 200 amp controller now, but it is HUGE and lets be real, i doubt your motor would be able to handle 80 amps, none-the-less 150. I have been wrong before though...
Thekid3418 is offline Find More Posts by Thekid3418
Old Oct 20, 2008, 01:15 AM
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
FlyA123's,
I've been out of town and will return tomorrow. Send me a PM and I will run MOTOCALC for you.
I'm not sure if the resistance values for that motor are published or not.
*** 5 days ago, I got a list which has 90+% of all NEU motor resistances in it. Odds are VERY good that if your motor is one of the ones which does not have its resistance on the web site or in the online simulator that I have you covered.
I should have an answer for you tomorrow night if you remind me.
***Please list your battery specs in a post or PM.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 20, 2008, 01:34 AM
Joined Oct 2008
Im using the exact same set-up on my FJ but Im concerned that the Eflight is only rated at 42A peak. Ive heard the Eflight doesn't like to be pushed.
How long have you been pulling 60A out of it ?
I'd like a bit more performance but I don't want to burn my motor out.
Originally Posted by pcliftonjr
Here's the most popular setup that is flying at my field:
Motor- Eflight Series 6 2700kv
ESC- 60A+
Prop- APCe 6x5.5
Pack- 3S-2200
This setup is really fast! But it pulls around 60A WOT on a 3S pack...that's a bit too much for me.
Here's my setup:
Motor- ARC 28-47-2
ESC- Align 35A
Prop- APC 6x4 sport
Pack- Zippy-R 4S-2200
Mine is fast too...it's a bit heavier due to the motor and extra cell. But it's a lot easier on the pack. It pulls around 40-45A WOT.
I can fly for 9mins with throttle management.
Paul
War Machine is offline Find More Posts by War Machine
Old Oct 20, 2008, 02:05 AM
Fast Foamer
pcliftonjr's Avatar
Phoenix, AZ
Joined Jan 2006
I'm not running the eflite setup...mine is the ARC. However, the eflite guys here are all running 3S and the combo seems to work fine.
Paul
pcliftonjr is offline Find More Posts by pcliftonjr
Old Oct 20, 2008, 02:13 AM
So Cal FPV Aviator
EyeFlyPlanes's Avatar
USA, CA, Santa Clarita
Joined Feb 2008
By the way guys..........
http://www.rcgroups.com/forums/showt...8#post10775009
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Closed Thread
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
