Old Oct 16, 2008, 11:29 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Doc:
With that motor and prop the ESC will be right at its limit or perhaps a little over, and you will need a very good quality 1800 pack 3S pack or the voltage will sag and the cells may puff. To be safe you should do a bench test with an ammeter before flying. If the ESC goes into thermal shutdown from being pushed too hard, you could lose the plane or hurt someone.
I would go with at least a 35A ESC and good quality 25C 2100 cells, especially if you fly where the ambient temps are above 80F or you intend to push it hard.
The HS-81's while strong are not the best centering servos around and if you are going to go for a fast plane or a high roll rate, digital servos or HS-255's might be a little better if you have the $.
I have a pair of HS-5125MG (metal gear) thin wing digitals in a couple of aileron planes and they are super strong and very responsive. You can really notice the difference versus analog servos. The only downside is they are $60 each but speed costs money and MORE speed costs cubic money.
You can see the specs of the different Hitec servos here.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Oct 17, 2008, 12:16 AM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
EyeFlyPlanes, My FJ used to do the same thing (one surface traveling farther than the other). I have a Futaba 6EXA fyi. All I did was adjust the EPA down for the servo that was traveling further than the other. Took a few flights but solved my issue. I started off by setting it to where it looked even then adjusted from there.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Oct 17, 2008, 12:39 AM
doctorbatman is offline
Find More Posts by doctorbatman
doctorbatman
Joined Dec 2007
FoamCrusher,
Thanks for the reply and info.
I have a 40 amp spd control I can use instead.
I've got some cellpro 2100 ma packs.
I can do a bench test with amp meter to verify before install.
Do you think HS-65 with karbonite gears (I have them already also) is a better choice than HS-81 or would I gain nothing?
Doc
doctorbatman is offline Find More Posts by doctorbatman
Old Oct 17, 2008, 12:55 AM
Lostlad is offline
Find More Posts by Lostlad
What smoke?
Lostlad's Avatar
SoCal
Joined Feb 2008
Originally Posted by doctorbatman
FoamCrusher,
Doc
I'm using HS-65MG on mine, they fit no problem and the Funjet tracks strait and smooth with them. Not saying the other digital ones wouldn't be better but at around 100mpg the 65's are holding up for me.
Lostlad is offline Find More Posts by Lostlad
Old Oct 17, 2008, 02:15 AM
xyz-2-xyz is offline
Find More Posts by xyz-2-xyz
California
Joined Mar 2008
the fj is a very use fiendly plane but when choosing gear to install make sure you get the strongest and the lightest. a light funjet is a happy funjet. remember that. thats probably why ur depron dosn't last longer i still have the first one i ever built.
xyz-2-xyz is offline Find More Posts by xyz-2-xyz
Old Oct 17, 2008, 02:39 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
EyeFlyPlanes, I would have mentioned my solution to the issue earlier but you were describing it as a torque roll.
On a side note I think you will like the Futaba 6EX radio alot once you learn all its features. I am looking to replace mine in a few monthes but only because I want to go to 2.4.
Jason
Old Oct 17, 2008, 02:59 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
That Futabe 6ch 2.4 Hz is 22% more expensive ($220 vs. $180) than the new Spektrum DX6i which has an awesome dual receiver.
I think neither has servos, so we can run our own favorite units like Hitec 81/82 MG.
I am not very familiar with that Futaba.
What are the feature differences between the two radios?
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 17, 2008, 03:15 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Not sure of the differences. But when I swap I am going for the 7ch Futaba 2.4 as apparently they have discontinued the 6ch 2.4 RX's. I was originally going to get the 2.4 version of the 6EX radio as I just really didn't want to have to learn a new radio. But it looks like I am going to have to anyhow. I choose the 7ch because I saw no point in buying a 6ch radio and having to buy 7ch RX's with an unused 7th channel.
Jason
Old Oct 17, 2008, 04:22 AM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
United States, CA, Santa Clarita
Joined Feb 2008
ok well I actually got the futaba 6ex for only $150 including shipping. Ebay look for toms rc. Amazing prices. It was between that futaba and the dx6i, but the dx6i has no digital trims! Are u kidding me? It was a clear choice.
I'm addition to that hobby city sells the assasn recieivers that are compatible with the futaba for only 25 bucks. I bought 4. Spektrum was not compatible at all, $70 receivers here we come. Ya I got a kick a$$ 2.4 ghz system for $175. I am stoked.
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Oct 17, 2008, 05:18 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Sounds like a sweet deal. Congrats.
Jason
Old Oct 17, 2008, 11:06 AM
California
Joined Mar 2008
very nice very nice you gotta take some risks if you want a reward. congrats ur braver than me.
trev-
Old Oct 17, 2008, 11:29 AM
grimgrinnin is offline
Find More Posts by grimgrinnin
I think I like vanilla...
grimgrinnin's Avatar
USA, AZ, Surprise
Joined May 2007
Is this the receiver you bought?
http://www.hobbycity.com/hobbycity/s...4GHz_Receiver_
I think you're about to be very disappointed. The assasn 2.4ghz receivers are not compatible with Futaba FASST. What they are selling are recievers that are compatible only with their own transmitter module, which can be used in SOME Futaba transmitters - unfortunately, the 6EX is not one of them.
I don't know of any aftermarket FASST receivers.
grimgrinnin is offline Find More Posts by grimgrinnin
Old Oct 17, 2008, 02:58 PM
So Cal FPV Aviator
Joined Feb 2008
Dude you have got to be kidding me. I just bought 4 of these things. I was reading on the website. And it said it would work with futaba 2.4ghz. I thought all futaba was the faast system. Son of a biotch!
Old Oct 17, 2008, 03:09 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
I think your talking about the Dx6 there. Both of my Dx6i's have digital trims
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Oct 17, 2008, 04:09 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
My DX6i has digital trims. As far as I know, none of the 2.4 GHz equipment out there is compatible with each other - all proprietary...
cjbucher is offline Find More Posts by cjbucher
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
