Old Nov 11, 2006, 09:44 PM
2Sunny is offline
Find More Posts by 2Sunny
Rural Westchester, NY
Joined Oct 2005
Down thrust.
Down thrust means the motor is pointing down at the back where your prop is, thus making the nose go downward in flight. It is the same effect as an elevator
It is my understanding that the conventional interpretation of "down thrust" means the motor is thrusting downward not the airplane i.e.
And this is where I work
Is that not the way it works in the RC world?
Thanks a bunch,
Joe
2Sunny is offline Find More Posts by 2Sunny
Old Nov 12, 2006, 06:26 AM
Psyko-lefse is offline
Find More Posts by Psyko-lefse
psykolefse.jorgis.com
Psyko-lefse's Avatar
Bergen , Norway
Joined Jul 2004
"Cause I'm a pilot, I only care about me"...
Psyko-lefse is offline Find More Posts by Psyko-lefse
Old Nov 12, 2006, 10:00 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You know, I have no problem with understanding thrust angle when the motor is up front. Now swap ends and make it a pusher and I get confused. Maybe looking at the motor angle from the front of the motor would make sense.
If the front of the motor is higher than the back of the motor then it has upthrust, and visa-versa. Would that be correct? Of course the effect it has on the plane is totally different. Up thrust on a tractor tries pull the nose up (climb), but up thrust on a pusher tries to pull the tail up (pitching the nose down).
Vantasstic is offline Find More Posts by Vantasstic
Old Nov 12, 2006, 11:56 AM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
It certainly makes a difference when something is at the back or the front.
You have an elevator at the back that goes up to give lift but if you have the elevator at the front, ie canard, then it goes down to give lift, however, if your motor at the back (pusher mode) is pointing down then the nose of the plane will get pushed down and if the motor is pointing up, the nose will get pushed up. If your motor is up front and is pointing down the same will occur, exept the nose will get pulled down rather than pushed.
Mark
MarkJayne is offline Find More Posts by MarkJayne
Old Nov 12, 2006, 02:07 PM
Piledriver is offline
Find More Posts by Piledriver
almost slackin
United States, MO, St Peters
Joined Dec 2005
Just got back from a wonderful morning of battling the wind. Flying into the wind at part throttle and pull up and throw full aileron and watch the Funjet spin on its tail while hovering, briefly.
Had the nearby gang at the soccer field entertained too.
Using extreme control throws to get it doing some awesome aerobatics, just too cool.
Tried all this with the Stryker and mono Twinjet and just not nearly as fun.
Don't mean to gush but it's the first flights in a couple days and it was great!
Piledriver is offline Find More Posts by Piledriver
Old Nov 12, 2006, 03:29 PM
xorbe is offline
Find More Posts by xorbe
so i rewired it...
xorbe's Avatar
Mountain View CA USA
Joined Jun 2006
Okay, so I can't perceive relative speed well... we radared the FJ once on the 500sh/4s/4.75x4.5 and got 101 mph!
Also, I upped the elevons to 150% movement with 60% expo... holy cow it spins like a top just like the microjet! It's hilarious...
xorbe is offline Find More Posts by xorbe
Old Nov 12, 2006, 05:53 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Sometime ago, Jurgen commented that the older Thunder Power PL cells I was was using and posted in a graph might not be up to the task of the Medusa 028-040-2500, so I ran it today with two different props on a new MaxAmps 3S1P 2100HV and used the digital in-flight recorder.
The graph left of the vertical gray line is an APC 6.5 x 2.9 prop and right of the line is the APC 6x4e.
The in-flight readings indicate the pack will put out 35+ amps in bursts and holds voltage at least enough to fly at half to 3/4 throttle, which is how I fly. While these packs are about 5 grams heavier than the TP's they do not heat up as much as the TP's - not an issue in the FJ that has excellent air flow, but is a real issue in some of my other planes.
At $50/pack vs. around $75+ for TP's, on a 3 for 2 cost basis, I am sold on them. YMMV.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Nov 13, 2006, 01:17 AM
Eric_N57105 is offline
Find More Posts by Eric_N57105
RC Bum
Eric_N57105's Avatar
Riverside, CA
Joined Apr 2006
Looks like you're working on a crossword puzzle.
Eric
www.ke6us.com
Eric_N57105 is offline Find More Posts by Eric_N57105
Old Nov 13, 2006, 02:18 AM
tIANcI is offline
Find More Posts by tIANcI
Xtreme Nut
Kuala Lumpur, Malaysia
Joined Oct 2005
Flying and doing crosswords? Hmmmm ... I think I better start taking the BUS!!!
I took the FJ out and tried to fly her slow and in a small area ... this baby can really fly in a large gym if you are good ...
tIANcI is offline Find More Posts by tIANcI
Old Nov 13, 2006, 02:53 AM
xorbe is offline
so i rewired it...
xorbe's Avatar
Joined Jun 2006
Has anyone dug the cabin's foam out to fit in a wider battery?
Old Nov 13, 2006, 03:23 AM
gt35r is offline
Find More Posts by gt35r
Perth, Western Australia
Joined Mar 2006
So it looks like we still have some contention over the motor thrust angle.
I originally thought it was about whether the motor was thrusting downwards, but the first reply indicated that it was the effect on the airframe that denoted up or down thrust. Can we please get some clarity on this?
With regards to the elevon travel, I had to use the standard throws from the instructions to avoid fouling on the vertical fins with full deflection on both channels (one up and one level). My servos are easily capable of double this amount so do I just hack away at the elevons till they clear, or will this have negative consequences that I haven't thought of?
gt35r is offline Find More Posts by gt35r
Old Nov 13, 2006, 03:26 AM
gt35r is offline
Joined Mar 2006
I just saw your post Mark, are you 100% about that?
It doesn't sound right to me
edit - unless you're calling ------/ the motor pointing up
Old Nov 13, 2006, 04:34 AM
ModelTony is offline
Find More Posts by ModelTony
ModelTony's Avatar
Irvine, Scotland
Joined Jun 2004
Rather than argue the semantics, perhaps it is better to discus the effect of the motor thrust line.
The FunJet instruction say "The new design of motor
mount is very helpful , as it enables you to adjust the
downthrust easily, and the set thrust line can simply be
read off on a scale. Start by flying at full-throttle, and trim
the model accurately, i.e. straight and level “hands-off”. If
you now switch the motor off, the FunJet should make the
transition to a steady glide. If the model climbs and slows
down, the downthrust is too great - reduce the downthrust
angle. If the model goes into a dive, the downthrust is too
low - increase the downthrust slightly and add a little uptrim
before flying again. Repeat this procedure until the
model goes into a smooth descent when you close the
throttle, and responds to an open throttle by spontaneously
flying straight and level, with a slight tendency to climb."
Start off by having the marker, attached to the motor mount, at the neutral point on the scale. If the model climbs on the reduction of power as above, reduce the downthrust by rotating the adjustment scew clockwise to move the marker back towards the prop.
I had to cut away the Elevons to clear the fins.
If that is a true photograph in flight why is the pilot not fully strapped in as the only flight crew at the controls.
Tony
ModelTony is offline Find More Posts by ModelTony
Old Nov 13, 2006, 04:58 AM
gt35r is offline
Joined Mar 2006
Tony
Ok then, you are saying ------\ = downthrust
Thanks.
On this point I think the instructions are a little confusing and the various comments here indicate that it isn't as simple as one might first think.
Perhaps it would have been clearer for them to say 'adjust trim to glide level, then apply full throttle and if model climbs too steeply add downthrust by turning adjustment screw anti-clockwise'
Old Nov 13, 2006, 05:11 AM
punkindrublik is online now
Find More Posts by punkindrublik
multirotormania.com
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
Guys, I got a really easy answer for ya...
it's the same no matter what end it's on!
Point the motor down, the plane goes down!! (front or rear mounted)
Point the motor up, the plane goes up!! (ditto)
The effect is the same no matter which end you put it on.
SO...
DOWNTHRUST = Motor pointing DOWN
UPTHRUST = Motor pointing UP
Think about it
Brian
punkindrublik is online now Find More Posts by punkindrublik
Site Sponsor
Wanted Multiplex funjet ouluckydogu Aircraft - Electric - Jets (FS/W) 7 Jul 24, 2006 04:01 PM
Sold Multiplex Funjet NIB bruff Aircraft - Electric - Airplanes (FS/W) 4 Jul 06, 2006 04:46 PM
Video Multiplex FunJet - Full video (20 MB) Jeremy Z Electric Plane Talk 0 Jun 28, 2006 01:27 AM
Video Multiplex FunJET Indoor Jurgen Heilig Electric Plane Talk 2 May 01, 2006 06:31 AM
