Old Dec 06, 2006, 08:04 PM
SD_Raptor is offline
Find More Posts by SD_Raptor
SD_Raptor
San Deigo, CA
Joined Mar 2006
Originally Posted by TommyB
Did a couple of static tests with both packs
300w and 30 A give or take.
Sound about right?
Just holding it and exercising the control surfaces, seems to be pretty nimble. with all the air being blown.
Tommy,
It all sounds good! You can reduce weight a bit by dropping back to 11x5.5 prop. The weight of the prop is something we often forget to examine. Prop weight goes up almost as the cube of the prop length. I'll have to weigh them when I get home to get the exact difference. The 11x5.5 will also give you a bit more endurance (at least for flying).
Looking forward to the report on the maiden flight. You will find that the AM is more than pretty nimble.
Randy
SD_Raptor is offline Find More Posts by SD_Raptor
Old Dec 06, 2006, 09:23 PM
TommyB is offline
Find More Posts by TommyB
Central PA
Joined Dec 2005
Thanks Ben and Randy,
Interesting not about prop selection Randy, I'll keep that in mind. At this point I am probably wanting longer flights anyhow. I was taking some weights along the way and estimated my weight would be 32 oz., but I didn't way the prop, prop adapter, they y adapter and velcro. I could probably lose most of that 2 oz. if I wanted too.
Thanks again.
Tom
TommyB is offline Find More Posts by TommyB
Old Dec 07, 2006, 04:23 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Hi guys,
Forgive my ignorance, but I'm just putting my first AcroMaster together. The instructions give no mention about how you actually join the wings. Are the dovetails meant to push together and snap in place? Mine seem way too tight to actually do that.
Mike Smart is offline Find More Posts by Mike Smart
Old Dec 07, 2006, 05:40 PM
MICKEL is offline
Find More Posts by MICKEL
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
I inserted the unglued spars into (1) completed wing (side), and installed it into the fuse. Then I guided the 2nd wing onto the spars and pushed both together until seated. They are a bit tight, and you want this.
MICKEL is offline Find More Posts by MICKEL
Old Dec 07, 2006, 05:49 PM
Mike Smart's Avatar
Joined Jan 2000
Thanks Mike,
But can you get them apart again? I have a small car (BMW Z4) and need to disassemble to get the model in.
Old Dec 07, 2006, 06:00 PM
MICKEL is offline
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
Yes. They do pull apart in case of a mishap as well.
I only wonder if this will degrade the holding power over time....
Old Dec 07, 2006, 06:50 PM
TommyB is offline
Central PA
Joined Dec 2005
Thanks for asking the question about wing joining. I was wondering that one myself.
Old Dec 07, 2006, 06:59 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Not sure about the over time issue on this plane but the wings on the Easy Glider join the same way.
kirby
kepople is offline Find More Posts by kepople
Old Dec 08, 2006, 01:14 AM
MICKEL is offline
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
My Mega powered Easy star employs the same. Everyone seems to watch in amazement when IT doesn't taco.... My AM is way overpowered as well, with no signs of hurting it's stout structure. I fire anuerysms and wicked snaps at it alot. I do leave the wings in at all times, as a crew cab can carry SOME foam.
Old Dec 08, 2006, 01:58 PM
SD_Raptor
San Deigo, CA
Joined Mar 2006
Originally Posted by Mike Smart
Hi guys,
Mike,
I trimmed off the dovetail and just press them into the fuse. Occassionally after several snaps or other high stress maneuvers, one wing is a bit loose. But it is easy to assemble and disassemble. If they begin to get too loose, I'll just drill a hole through the turtle deck and wing and use a CF stick to hold them in place.
If you don't trim it, you can press them together and apart several times outside the fuse to ease the fit.
Randy
Old Dec 08, 2006, 03:49 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Could those of you who have built the AcroMaster tell me the best glue to use? CA like the manual says, or polyurethane glue like Gorilla or Sumo brands? Also, I was going to epoxy the motor mount in, but have heard epoxy won't bond well to Elapor. What do you guys reccomend?
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Dec 08, 2006, 04:06 PM
Mike Smart's Avatar
Joined Jan 2000
I used slow CA - worked fine
Old Dec 08, 2006, 07:13 PM
MICKEL is offline
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
Originally Posted by SD_Raptor
Mike,
Randy
That probably cut a bit of weight off as well. The wings really stay in???
Old Dec 08, 2006, 11:27 PM
TexasFlyer is offline
Find More Posts by TexasFlyer
TexasFlyer's Avatar
Houston, TX
Joined Sep 2005
Hi guys,
Mike,
At first, I had difficulty getting them together until I discovered the right technique. Once you have the wings mostly in but need to get the dove-tail to fit into place, I grab the wing tips with each hand and pull them together, towards the fuse. It works really well for me.
Getting them off easily... well, I haven't figured out that technique other than to pull the leading edge of the wing, then the lagging, then leading - basically rocking it out slowly.
I like the snug fit - it really stays in place nicely.
Alan
TexasFlyer is offline Find More Posts by TexasFlyer
Old Dec 08, 2006, 11:29 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hi guys,
It is the same system as used on the EasyStar and the EasyGlider - and it works very well. You may want to put the wings together and take them apart a couple of times to loosen the lock function a bit.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
