Mike. |
Slidell, LA, USA
Joined Nov 2002
A long long time ago in this thread someone had talked about the canopy attachment method being insufficient and they recommended magnets instead. I was out in the gale-force winds flying this thing again on Sunday (why does the wind blow hard constantly ever since I finished this thing?) and I have to marvel how well done I think the stock canopy attachment really is!
If you get the little plastic receiver clips placed properly, the canopy snaps on so positively that I can not imagine the thing EVER coming loose, unintentionally. Great design!!! Simple, light, and works great! |
Malaysia
Joined Jun 2001
Central PA
Joined Dec 2005
Hey Blucor Basher,
I'm assuming you are Ben, if so, thanks for overnighting the torque to me. Got a question for you, maybe a couple of them. It appears that the motor mounting screww are not long enough. What size do I need to get? I broke one of the stock micro ez links that came with the kit. I got some dubro ones but the mounting pin is too small for the control horn on the aileron. Any suggestions? |
The Torques (and most of these outrunners) use 3mm screws for mounting. On my AM, I actually used the stock thrustline-adjusting screws for motor mounting and used some other screws for the thrustline.
The Dubro121 EZlink has a larger pin diameter than the micro ones...i'm not sure if it's correct for the AM horns or not. I can check tomorrow. If you need the screws or anything, just call me, we can get you what you need. |
San Deigo, CA
Joined Mar 2006
If you look back on page 72 (Nov 3) I posted some graphs of the current/voltage for a cuople of different props. Peak current is about 40 amps during a sustained climb. Most of the time current is between 15 and 20A, right at the best efficiency for the motor. Note: I did cook the Z3013-16. I did a very long sustained vertical - 300 feet at least, the lower air speed combined with the high power burned the insulation on several windings. Ordered a Z3013-14 to replace it. Should arrive today. This will run only on 3s packs. I will repeat the Eagle Treee logging again with some different props and report the results. Using a 3S2100 pack instead of 4S 2000 should cut an oz or two from the all-up weight. Randy |
Central PA
Joined Dec 2005
I found some motor mount screw that worked perfectly in an eflite stick mount I picked up the other day. I'm good to maiden just need a decent weather forecast. Setup Torque motor cc45 hs 65's all around Tp 15c 2100's, apex 2100's both 15c Dx6 rx 12x6 apc AUW 34 oz (don't know how I could have built it any lighter, maybe a couple of grams) Did a couple of static tests with both packs 300w and 30 A give or take. Sound about right? Just holding it and exercising the control surfaces, seems to be pretty nimble. with all the air being blown. |
Well now that my AcroMaster is on the way it's time to think about how to go about building it. One thing I've been contemplating is weather or not to sand the molding marks off. If I decide to, how would I do it and how hard is it to sand Elapor? Also, what kind of glue should I use to put the plane together?
| Thread Tools | |
| Discussion Extremeflight Extra vs Multiplex Acro Master | Magna | 3D Flying | 17 | Dec 10, 2008 01:11 AM |
| For Sale Multiplex Acro Master RTF | slopenutz | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 13, 2007 04:12 PM |
| Sold Multiplex Acro Master | termite | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 20, 2007 05:04 PM |
| Link Multiplex Acro Master $99.99 | Doubletap | Hot Online Deals | 6 | Dec 18, 2006 03:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
