Old Jun 29, 2006, 11:29 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Could you tell us what the weight is of the model without power system? This will help me decide on which power system to put in my own AcroMaster. Thanks!
Jeremy Z is offline Find More Posts by Jeremy Z
Old Jun 29, 2006, 12:24 PM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
550 gram for all EPP parts, plastic parts and control linkages/hinges and undercarriage.
So add a propellor, motor, lipo, servo's, ESC and RX and you have your AUW.
Pjotrrr is offline Find More Posts by Pjotrrr
Old Jun 29, 2006, 02:38 PM
dimebug is offline
Find More Posts by dimebug
Joined Feb 2004
Axi 282010 is exactly what i'm about to use with this nice toy :-)
dimebug is offline Find More Posts by dimebug
Old Jul 01, 2006, 07:41 PM
rycomm is offline
Find More Posts by rycomm
Flyin' Ryan
USA, MO, Lee's Summit
Joined Sep 2001
Is that 2820-10 similar to the Eflight power15? Seems close to me.
Ryan
edit: I guess I meant the power 10, it has a 1100kv vs the 15s 950
rycomm is offline Find More Posts by rycomm
Old Jul 01, 2006, 10:45 PM
TexasFlyer is offline
Find More Posts by TexasFlyer
TexasFlyer's Avatar
Houston, TX
Joined Sep 2005
Builds / Maidens?
Pjotrrr and AnnihilaT,
How did your builds go? Have you maidened yet? I can't wait to hear/see the results!
Alan
TexasFlyer is offline Find More Posts by TexasFlyer
Old Jul 02, 2006, 04:08 AM
pitch black is offline
Find More Posts by pitch black
Holy Slopes!
Joined Jul 2004
Yup im also eagerly awaiting reports. Considering to buy one after my Superzoom.
I have a NIB AXI 2814/12. Would that work? Would be using the new Flightpower evo20 3s 2150mah packs.
Thanx!
pitch black is offline Find More Posts by pitch black
Old Jul 02, 2006, 09:12 AM
Pjotrrr is offline
Me likes Depron...
Pjotrrr's Avatar
Joined Mar 2003
Axi 2814/12 will generate 1750 grams of thrust with 12x6 APC Electric on 3slipo/40A...
www.flyingmodels.org
Will do for acrobatic flight, maybe not the best pull out of a hover.
Most people over here in Europe go for the 2820/10 and over 2000 grams of thrust....
Started building today, have to wait for servo's though.
First flightreports I read on www.rcline.de are very good, very neutral flyer with a low wingloading and very slow in landings...
Old Jul 02, 2006, 04:29 PM
chichisport is online now
Find More Posts by chichisport
Tenerife,Canary Islands
Joined May 2004
With the 2814 and a light pack maybe the pullout is not that bad . Try to save weight in the details , light gauge wiring , avoid unnecesary connectors ,etc.
What pack will you use for the 2820 ,pjotorr?
Cheers.
chichisport is online now Find More Posts by chichisport
Old Jul 02, 2006, 07:00 PM
Holy Slopes!
Joined Jul 2004
Oh ok.
Thanx for the heads up guys.
My next biggest motor is the AXI 2826/10. Seems too big though.
Thanx!
Old Jul 03, 2006, 06:30 AM
Pjotrrr is offline
Me likes Depron...
Pjotrrr's Avatar
Joined Mar 2003
I already had a Polyquest 4s3100/12-16C pack and bought me another one now they are cheap at www.aircraft-world.com
On 4slipo the motor only draws 33A max or so and this 4spack is almost the same weight as the 3s Kokam 3200....
I live 10km from the beach, always windy around here so I don't mind the AUW of 1150 grams.
The AcroMaster has a VERY light wingloading, wing area is the same as the 140cm span (30 cm more!) Hyperion Yak54...
A good light (1050 grams AUW) setup is possible with the advised Himax or an Axi 2814/12 and small 3slipo 2200's or so.
The advised Himax 3516-1130 (134gr) outrunner is in between of the Axi 2814 (106gr) and 2820 (151gr) and cheap so....
http://www.modelmotors.cz/index.php?...%20-%20161%20g)
Axi motordata: www.flyingmodels.org
Old Jul 03, 2006, 02:50 PM
TexasFlyer's Avatar
Houston, TX
Joined Sep 2005
Instructions and FMS model
For those of us that don't yet have Acromasters, the instructions were just released on the Multiplex website:
http://www.multiplex-rc.de/cms/vorsc...master_5sp.pdf
They appear to be very good instructions, the kit appears to be very complete, it has some very helpful trimming tips, though it is probably a little more involved than most Multiplex products.
Per Multiplex support, they will not be creating an FMS model. That's too bad because that's one thing I've really liked about Multiplex products - being able to practice at home at night or rainy days.
Old Jul 03, 2006, 03:10 PM
Airfisch is offline
Find More Posts by Airfisch
Austria, Tirol
Joined Jul 2006
Hi friends,
...I´m new in this forum - so first of all hello to the comunity!
As you can see, I come from Tirol in Austria - so please don`t be worry if my english sounds a bit "scary". I hope it will be better by reading and writing some posts.
Now I want to post some infos to the Acromaster - maybe I can answer some of your questions:
The kit is really fantastic ("clip on" landing gear, motor mount, stability...)
My first setup was:
Axi 2814/16
APC 11x5,5 E
Jeti advance 40
Tanic 3s 2080
4x HS 81 Servos and schultze 8.40 receiver
With this setup the weight was 1,010 gr.
The performance was very good. Starting on gras (with the beautiful "wheelcaps" ) was no problem - not more than 5or 6 meters. It flies absolutely easy! You can fly it very slow - if you can handle a Twinstar or something else with ailerons - you will have no problems and much fun!
Aerobatics are very exact - especially snaprolls and "kniveflight"( ) looks great. Perfect for aerobatic training! I tried also some Stall figures (3d) so far I can do it ( ) - it works. With my setup you can park the AM in the air.
Flighttime was appr. 6 minutes (max. 31A).
But I think there will be a better setup: the Axi 2820/12 with 12x6 Prop will have a better performance. The more of weight is really no problem, but it will bring more power for real crazy manouvres (the AM can do - you too ? )
Flighttime is from 8 to 12 min., also not more than 30A during flight - but a bigger Prop (a user in germany tested this setup and he was very satisfied - he sells hyperion planes in germany an his flight performance is much more better than mine )
So I can`t wait for the next flights - relaxed aerobatic training - no fear about the costs!.....ähhh....maybe I will need new lipo packs in the next weeks...
Good flight
Walter
Airfisch is offline Find More Posts by Airfisch
Old Jul 04, 2006, 04:58 AM
MalteS is offline
Find More Posts by MalteS
Germany
Joined Sep 2005
Dear all,
My AM is also finished. The Kit is very nice and complete. Easy to build. Mine is equpped with:
Kontonik Kora 10-16
APC-E 12x6
Kontonik Swing 4100 Lipo
Hitec HS81 and HS50
Tanic 2480 3s
Wight is 1040g. I've installed a nightflight equipment with LEDs monted inside the plane. Yesterdays flight at 10:30pm was nice. Visibility is very good.
The setup develops plenty of power. I've recorded 45A static current consumption and 33A max during flight.
Finish is also a bit different, I will post pictures when it is finalized
Malte
MalteS is offline Find More Posts by MalteS
Old Jul 05, 2006, 10:32 PM
rycomm is offline
Flyin' Ryan
Joined Sep 2001
I'm thinking of using a geared inrunner on my AcroMaster. I looked over the manuals on Mpx's web site, and it looks easy enough. What does everyone think of a Mega 16-15-3 (or 4) geared 3:1 on 3S spinning a 11 or 12 x 6 prop or so. I'm guessing around 25A, so 15C 2100s should be about right. I'm hoping to keep it pretty light, and fly more pattern than 3D.
Ryan
Old Jul 06, 2006, 03:47 PM
Joined May 2004
Might be good . I have a big depron (1.4mt, 1200gr) with a 2 turn mega in a 6.1 box turning a 14x7 and has a very good pull and a good speed for pattern , but it ask for 50amps from a 3s pq3700.
I think 300 watts is the minimum for good acro (master).Look for 30+amps.
Cheers.
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
