http://www.rcgroups.com/forums/showp...&postcount=591 Martin basically made a "shockflyer-style" landing gear, i.e. Carbon rod front and aft, Depron in the middle and wrapped it with Oracover CF-look. Jürgen
Sehr zu empfehlen ist die Verwendung von Klappluftschrauben (auch in Motormodellen). Falls es nicht möglich ist, muss der Motor auf einem sehr stabilen Spant montiert werden. As there has never been an F5A World Championship, how can there be an F5A world champion? F5A allows hand lauching and belly landing, which makes a folding prop a good idea. Fact is, that all F3A World Championship pilots using electric motors used standard (non-folding) props. Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
Jürgen
![]() Brian |
I have some questions about gear for the AcroMaster. First off, I am planning on getting a 3S 3000mah battery from Maxamps.com. It weighs 224g. Is that an okay weight for the battery? Secondly, I am going with the reccomended Hacker motor, which is rated for 35A. Should I buy the Pheonix 45 ESC, or will I be fine with the 35?
Thanks, Rocketman1092 |
San Deigo, CA
Joined Mar 2006
Batts, gear, ESC
that batt is a bit heavy - you may find it hard to get the correct CG unless you move the tail servos back. The gear will handle the weight IF you land smoothly on a fairly smooth surface. If your landings are a bit rough or the surface not so wonderful, then you may have a bit of problem with the gear. a 3s2000 or 3s2500 batt with reduce the total weight a bit. For any batt combo I would go with the Phoenix 45 - this gives you some room to try other motor/batts/prop combos without buying a new ESC. The Phoenix 45 is very reliable. I have somewhere between 200 and 300 flights on the one in my Magister - running a Axi 2826/12, 13x6.5 prop and 4s pack - hitting 45 amps at times with no problems at all. Already wore out one 4s2p pack. Have fun! Randy |
Joined Jul 2005
First flight today.
man this thing flys nice... best plane I have ever piloted! Handles like a dream! Everything went well except when I tryed to torque roll or vertical flight. The engine would cut out after 2 or 3 seconds.... I would bring the throttle down, and then motor would start right back up. The BEC is cutting out on me. I have the factory recommened setup. with himax, phx 45 I did use hitec servos 85's and 65's. I am also using 2 new thunder power 3 cell 2200 extremes, which should be able to handle the load. My question is About setting the phx 45. I am using LiPo AUTO DETECT setting as well as all other default settings on the phx 45. Is their somthing I can change to make it torque roll / vertical flight without cutting out the engine? |
Jürgen
Joined Jul 2005
thanks Jurgen,
BEC is working as I have control, but thought maybe it was cutting out the motor to keep enough voltage for servo operation. I'll try changing the Cutoff votage from LIPO AUTODetect to the next lowest setting of 4.0 V and see if that helps any. |
Kranj
Joined Jun 2006
Jernej |
Airdrie, AB Canada
Joined Sep 2004
These have finally made it up to the Frozen North. Unfortunately I'm not sure mine will see flight this year unless we see great weather.
I'm amazed at how few motors have been tried on this plane in this thread. It is a pretty standard weight (32oz ish) yet many seem to be going for the Himaxx option. Strange. That doesn't happen much on non multiplex planes. The video posted with Martin flying inside was on a 3516. I'm assuming he tried the 2808/24 and maybe a lighter pack and was unimpressed. Is that right Jurgen? Looks like it will be a great plane can't wait to get it in the air. Probably go with HS65's. TP Extreme 2200's. Would sure like to get to around 450w without a weight penalty. We'll see. Hopefully more of these will start popping up in North America. Mike |
| Thread Tools | |
| Discussion Extremeflight Extra vs Multiplex Acro Master | Magna | 3D Flying | 17 | Dec 10, 2008 01:11 AM |
| For Sale Multiplex Acro Master RTF | slopenutz | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 13, 2007 04:12 PM |
| Sold Multiplex Acro Master | termite | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 20, 2007 05:04 PM |
| Link Multiplex Acro Master $99.99 | Doubletap | Hot Online Deals | 6 | Dec 18, 2006 03:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
