Tiny-S = Hitec HS-81 The HS-65 is a perfect replacement for the HS-55. Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
Jürgen
Hacker motors have a (well earned) reputation for handling more power than the published specs, but I expect Multiplex would prefer the extra safety margin provided by the heavier motor with the slightly higher current rating - if someone is abusive with the throttle, the Hacker will probably cook to death sooner than the Himax. As Mike Mayberry (and others ??) has/have already shown, in the real world the Hacker does a fine job of flying the Acromaster. I'm curious why Multiplex didn't recommend their own BL-480-4G geared 4.4:1 (with a 13x8 APC E on 3S lipo), which I think is a slightly better choice for the Acromaster than the recommended Himax - provided you don't hate a bit of gearbox noise. Perhaps it is because the Multiplex motor costs more than the Himax, or perhaps those Multiplex motors are now out of production? I still see them for sale at several vendors in the USA. -Flieslikeabeagle |
While inrunners usually have a slight edge on efficiency, the advantage is often gone once you take the gearbox losses into account. Jürgen
I see a weight advantage of more than 1oz for the outrunner. Jürgen
Please note, that Multiplex claims a maximum efficiency of 83% for the motor, and Maxon (the manufacturer of the gearbox) claims a maximum efficiency of 84% for their planetary 22mm gearbox. Combined, you only get 70% under ideal conditions. http://www.maxonmotor.com/ch/en/gear.asp Jürgen
1. The Himax weighs less than the BL-480-4G. 2. The Himax has a 5mm shaft, which is much stronger than a 4mm shaft. 3. In case of a mishap, you can easily change the shaft of an outrunner. 4. The Maxon gearbox was never designed to take the gyroscopic loads of a fixed prop doing 3D aerobatics. 4. The Himax is more efficient, runs cooler, and a lot quieter. 5. A direct drive is more dynamic than a geared drive (it has a much wider speed range). 6. The MPX list price of the Himax is less than half of the BL-480-4G. Jürgen
Tdab (post #715) listed some impressive numbers for the Hacker A30-16M: nearly 400 watts power from a (very good, low resistance) 3S lipo pack with the 11x5.5 APC E prop. That really should be plenty of power for a 1kg plane, for all but the most hardcore power junkies. ![]() As far as I can see, only the largest of the Hacker 30 series motors, the A30-12XL, has a Kv low enough to be run on a 4S lipo pack with a reasonably large prop. This motor will handle a 13" prop on a 3S lipo pack (some people abuse it with a 14x7), and probably a 11" or 12" prop on a 4S lipo pack. However, this is a considerably heavier motor (about 45 grams heavier, I estimate). The Multiplex BL-480-4G (with the 4.4:1 gearbox) also has a low enough Kv to be run on a 4S lipo pack. -Flieslikeabeagle |
Have a look at the homepage of the gearbox manufacturer: Recommended input rpm is <8000 rpm. Have you ever used a planetary gearbox on a high power motor? While it is Ok do run such a unit in a glider for short bursts of a couple of seconds, it heats up rapidly, when used in a sports/aerobatic model. The Acro-Lift from Simprop is a typical example of such a model, and the motor needs additional heat sinks. Jürgen
Jürgen
| Thread Tools | |
| Discussion Extremeflight Extra vs Multiplex Acro Master | Magna | 3D Flying | 17 | Dec 10, 2008 01:11 AM |
| For Sale Multiplex Acro Master RTF | slopenutz | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 13, 2007 04:12 PM |
| Sold Multiplex Acro Master | termite | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 20, 2007 05:04 PM |
| Link Multiplex Acro Master $99.99 | Doubletap | Hot Online Deals | 6 | Dec 18, 2006 03:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
