Old Aug 05, 2012, 03:21 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
all that could be done but why not one of the aftermarket alum ones?
chas650r is offline Find More Posts by chas650r
Old Aug 05, 2012, 04:00 PM
4446 is offline
Find More Posts by 4446
taso
4446's Avatar
Greece
Joined Jul 2010
Hi, it is rather simple to make in 20min (hopefully) and have the plane up and running than wait for 3weeks to get the aftermarket.
Got some wood, aluminum and carbon laying around and could be of good use.
The previous owner had a plywood kinda firewall epoxied on the ship and it was working like a charm until I changed the prop to a larger one....snap and there the prop flyes away...
4446 is offline Find More Posts by 4446
Old Aug 05, 2012, 08:15 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
so are u planning to use the stock mounting points?
Old Aug 06, 2012, 06:51 AM
4446 is offline
taso
4446's Avatar
Greece
Joined Jul 2010
Yes.
I've also installed a wooden supporting "beam" between the two mottor mounts.
The firewall that I had installed (one gone now) was covering the whole hole area of the front with a big hole under the motor for cooling. This worked pretty well as it was supported by the two stock motor mounts and the elapor at the whole perimeter, as one assembly with epoxy.
I think I'm going this way again.
In photo no1 you can see the remaining balsa outlined.
(Got a second one, this is my war machine with the accident for your reference)
Old Sep 03, 2012, 09:22 PM
Waverunner is offline
Find More Posts by Waverunner
Joined Aug 2009
I still want this plane. Do you think multiplex is going to make any changes.
Waverunner
Waverunner is offline Find More Posts by Waverunner
Old Sep 04, 2012, 03:37 AM
4446 is offline
taso
4446's Avatar
Greece
Joined Jul 2010
setup motor-prop
Hi guys,
there seem to be plenty of info but here it goes...another motor/prop question...
I picked up the acromaster new and is all setup with
motor A30 10xl v2 (177grams)
ESC TGY plush 40amp
batteries 2200mah 3S turnigys 30-45C
AUW is 1100grams
(the motor was the only decent thing at LHS)
I've tried several props but the run times are really unrealistic/silly (too little). the motor can handle pretty much every large size prop. The only thing I can come up with to keep this setup is to run x2 in parallel of the above bats with a 12x6 APC slowfly to keep the times a bit above 10mins (according to propCalc).
However the AUW will be 1300grams. Is this plenty heavy for the AM or is it still acceptable performance wise..? the thrust/weight ratio is still pretty good but what is a good value?
Any suggestions?
I've also thought of using the 4S 5000mah from my buggy which will bring the AUW at 1400grams increase run times even with a 13x6.5 and give more than 600watts and t/w ratio of more than 2.3
I'm still a noob in acro, but give me some height and I can do pretty much everything.
HEAVY HEAVY HEAVY....
Old Sep 04, 2012, 04:53 AM
Nick9000 is offline
Find More Posts by Nick9000
Hacienda Heights, Ca., USA
Joined Sep 2009
I don't know anything about your motor, but I can tell you that a lighter AM is prefered. I'm using an Eflite power 15, 40amp esc, 2200mah 3s, &13x6.5 apc prop. My flight times average about 5-6 minutes. I could probably push 8-10 minutes if I fly slowly, but it's to hard to resist carving up the sky!
Nick9000 is offline Find More Posts by Nick9000
Old Sep 04, 2012, 07:23 AM
4446 is offline
taso
4446's Avatar
Greece
Joined Jul 2010
Hi,
Thanx for the info.
The Hacker is one of the better ones, but unfortunately not fit for the flight times I want to see (10min).
Stupid question maybe but what is going to be the effect of a heavier plane? I mean the endless power and the times will be there with the 4s brick (2.3/1 ratio), but how is it going to behave?
Do you have enough with 5-6min? Have you tried a 12x6 or even a 12x4.7?
Old Sep 04, 2012, 01:51 PM
4446 is offline
taso
4446's Avatar
Greece
Joined Jul 2010
Got me 2 tgys 2836-1200.
These would make a better fit, but I'd still appreciate feedback on the above.
Anyone?
Old Sep 04, 2012, 03:07 PM
Nick9000 is offline
Joined Sep 2009
I'm happy with my setup. Once you get your plane together fly the heavier battery, then compare it to the lighter setup, you'll see the difference. If you want a plane with long flight times you should look elsewhere. The AM is a small lite 3d plane. I had a Parkzone T-28 and with a larger battery I was able to get long flight times and evan though it was heavy, the plane performed very well.
Old Sep 04, 2012, 04:15 PM
RCDestroyer is offline
Find More Posts by RCDestroyer
The Crash King
RCDestroyer's Avatar
United States, OH, Richfield
Joined Mar 2010
I absolutely love my AcroMaster! Does anyone else count the flights on their planes? I'm up to 34 in 2 months!
RCDestroyer is offline Find More Posts by RCDestroyer
Old Sep 04, 2012, 10:01 PM
jhurault is offline
Find More Posts by jhurault
United States, CA, Thousand Oaks
Joined Jan 2001
Landing gear for AM
Originally Posted by Waverunner View Post
has anyone had any issues with the landing gear. I had a minimag and it was tough.
Waverunner
I found the stock landing gear too springy. Solved the problem by 1. Using JB Weld to affix a couple of TINY washers onto each leg of the landing gear 2. Putting two rubber bands between the struts. Really helps the flexing problem.
jhurault is offline Find More Posts by jhurault
Old Sep 05, 2012, 12:11 AM
4446 is offline
taso
4446's Avatar
Greece
Joined Jul 2010
Hi, I'll do so. the plane has already more than 10 flights, I'm just not satisfied with the duration.
In regards with the flight times my previous setup
Tgy 2836-1000
35amp hk esc
2200mah bats
Swinging a 10*3.8sf apc
Mild 3d I got over 10minutes in the air.performance was very good with a light plane..I'm just looking for a way to use that hacker motor!
Trial and error I guess then.
Old Sep 05, 2012, 03:11 AM
Daddymonkey is offline
Find More Posts by Daddymonkey
Derby, UK
Joined Nov 2004
5-6mins is my typical flight time using a Scorpion motor and 2200mAh 3S Turnigy/Fligtmax battery. 10 mins sounds exceptionally long for an acrobatic electric model. Interestingly, going to 2650mAh doesn't increase time more than maybe 30 seconds, it gives it more punch but it flies slightly heavier/faster.
I tried an 1800 3S Flightmax, on the edge of the batt power really, notably shorter time and notably lighter and slower. I thought my model was reasonably light (sorry haven't weighed it recently) but then flew my father's brand new AM and there's a world of difference! Mine has ply in the nose and several repairs.
I think you can try any of the options you've suggested, they all look workable. Maybe even put the old motor back in if the performance is ok.
Good luck.
PS - be careful using a SF prop with this much power - they are not designed to exceed 5000rpm iirc.
Daddymonkey is offline Find More Posts by Daddymonkey
Old Sep 05, 2012, 11:37 PM
morrigan is offline
Find More Posts by morrigan
morrigan's Avatar
Deutschland, BW, Ebersbach an der Fils
Joined May 2011
Hi,
i have a Acromaster with following Setup:
Turngiky SK3 3542- 1250 KV
APC Style Prop 12x6
2200 mah 3S1p
50 A HK ESC
SBec
HK MG Servos all arround.
The Prop is a bit big, but plenty of Power. I didnīt like the 11 x 5.5 so i changed.
My TX is set to 7 Min. Flight Time. 25 - 30 % Batterie left normaly
I find 10 Minutes is a bit long for an Acromaster. The lighter the better.
My AUW is 1170g.
I think i have more than 50 flights in the last 2 months.
Like the AM.
Bernd
morrigan is offline Find More Posts by morrigan
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
