When you pull the nose off a parkzone T28, P47, F4F, Extra300, you have a sturdy little motor mount attached to a huge firewall. IMO on this plane it appears both the firewall (yup there is none) and the motor mount depend in that small slice of foam across the top and bottom of the nose to provide rigidity (not gonna happen)..............peace
Zero vibrations and, yes, it stays together quite nicely even after a couple nasty landings. Keep in mind, you still have to balance those props ;-) Use 20 minute epoxy for the wood assembly and thick CA for attachment to the fuse. And test fit, test fit and test fit before gluing anything. Eric |
If you happen upon other Multiplex threads you will hear a very common theme of nose/airframe vibration due to the poor motor mounting system. My MPX FunCub is one of them even with an after market aluminum motor mount.
Blu |
Latest blog entry: 2013 Blog extra
I have had good luck using the new "white" gorilla glue (or Sumo glue) on elapor, especially for the motor mounts. It doesn't foam too much, just enough to fill any gaps there might be and it's not as brittle as CA. Make sure you sand the contact areas and wipe down with denatured alcohol to get rid of any mold release (and that "greasy" feel) which will give you a better bond no matter what glue you use. Do the same to the plywood if you go the "crutch" route. I've flown the snot out of my AM, with the stock mount, and have never had the MOOOO...ymmv.
United States, OR, Sherwood
Joined Oct 2007
Motor mount vibrations
I've read on the various threads about the 'hard to cure' motor mount noise and built in several of the mods as well as using the after market Aluminum mount. One thing I have found that I think is a prime cause is the mount screws not being well tightened. I've flown my Acromaster a good few times and was pleasantly suprised how QUIET it was....until this morning. I did check the mount screws before and after the (very short) flight and judged they were fine, however when I got back home ready to tear into the problem I picked up a 'real' screwdriver...not one of those dinky electronic/modeling ones and surprise-surprise...the two screws that mount the aluminum mount to the plastic bulkhead took at least two turns to snug them up. The dinky electronic size screwdriver was not up to the task....but one with a real grip showed right away that 'tight' has a couple of different versions, apparently.
Running up to full throttle was as quiet as ever, though 1/2 to 3/4 was as far as I could get before snugging up the bulkhead screws. The nose on this model has plenty of carbon cloth/pultrusions and tape CA'ed into it and seems quite solid.....the cause in this instance was definately failure to check the fastenings. Hope this helps someone.....It's been great reading all the contributions here. |
I just finished my AcroMaster today!
Heres my powersystem: FirePower 15 motor Exceed RC 60A ESC Exceed RC 3A BEC Hitec HS-82MG for Elevator Hitec HS-81 for Rudder Emax ES08MA for Ailerons Gens Ace 2500MAh 3s 25C DX8 w/AR6210 I have a couple concerns. THe HS-82MG servos is always buzzing. Is that normal for that servos. To stop it from buzzing, i just move the elevator alittle bit. Also, im having trouble getting the correct CG. It is suposed to be 110mm from the leading edge. I can only get mine 100mm. Here is the paint scheme! Let me know what you think! |
Joined Apr 2002
Yet Anothet Turnigy Motor Question....
Hi Guys,
I was so impressed with the quality and fly-ability of my MPX Fun Cub that I have decided to build an AM. I have a spare TR 3635-1100 that I'd like to use with the scads of 2200 - 2650 3S batteries I have on hand. I do not intend to use the AM for 3D, but mostly as an aerobatic trainer (pattern type flying) , if you will. The motor weight 101 grams. So, two quick questions: Do you think this will perform OK for my needs turning something like a 12x6 prop, and any issues with the CG given the relatively low weight of the motor. TIA for any thoughts. :harry |
| Thread Tools | |
| Discussion Extremeflight Extra vs Multiplex Acro Master | Magna | 3D Flying | 17 | Dec 10, 2008 01:11 AM |
| For Sale Multiplex Acro Master RTF | slopenutz | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 13, 2007 04:12 PM |
| Sold Multiplex Acro Master | termite | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 20, 2007 05:04 PM |
| Link Multiplex Acro Master $99.99 | Doubletap | Hot Online Deals | 6 | Dec 18, 2006 03:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
