Old May 09, 2012, 05:57 PM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
I'm looking at the Acromaster as my second 3D plane. I have a few 40C 2200mah batteries from my Stryker, so I'm hoping to use those. Can someone take a look at my components here and let me know if anything is off? Thanks!
Batteries: SkyLipo 2000mah 3S 40C
Motor: FirePower 15 from HeadsUpRC - 135g (55oz thrust on 11x5.5E prop, 69oz on 12x6E)
ESC: EFlite 40A Pro
Tail servos: EMAX ES08MA x2
Aileron Servos: TP MG90 14g
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
Old May 09, 2012, 10:27 PM
cynjon is offline
Find More Posts by cynjon
Retired USAF
cynjon's Avatar
USA, SD, Piedmont
Joined Jul 2005
ESC: EFlite 40A Pro
Specs on everything look to be very good--IMO it will work great on the AM! Not familiar with the servos but the specs compare well to the servos that I would choose (HS-82/85 for the R/E, HS-65 for the ailerons).
cynjon is offline Find More Posts by cynjon
Old May 16, 2012, 06:14 AM
windrnone is offline
Find More Posts by windrnone
lownslow
windrnone's Avatar
United States, FL, Cape Canaveral
Joined Nov 2011
ESC: EFlite 40A Pro
I have the e-flite power 15, Castle 50A, and HS 85 MG's X 4. All is good, plenty of power, I am pulling 35AMPS with 12x6 prop. Almost went HS65's in aile's but 3D buddys said they were too small........my stryker is pulling 49AMPS WOT with the eflite 40A ESC, no problem so far
windrnone is offline Find More Posts by windrnone
Old May 16, 2012, 06:33 AM
brianvc is offline
Find More Posts by brianvc
brianvc's Avatar
United Kingdom, England, Dorset
Joined Sep 2011
yak 54
just been out with my yak 54 by Gene Bond, this really is a gr8 plane. nice and stable and capable of reasonably slow flight into a headwind, but ramp up the throttle and she hums. capable of all 3D manouvres she's just brilliant. only mod i made was to change the fuze from single profile to "X" style profile for more rigidity. of course i braced the wings on leading edge and across their middle span and also added some braces to the fuze sides. i'd recommend this model to anybody with a little experience, quite easy to fly if you're not too adventurous but also fast enough for the experienced flyer. i take my hat off to Gene Bond, gr8 design.
BVC
brianvc is offline Find More Posts by brianvc
Old May 16, 2012, 10:47 AM
Joined Apr 2011
Good to know. Maybe I'll go with the heavier duty servos in the tail as well, I just don't want to mess up the CoG.
Old May 16, 2012, 06:22 PM
THX-181 is offline
Find More Posts by THX-181
Air Cooled VW mechanic
THX-181's Avatar
USA, CO, Longmont
Joined Jul 2008
The tail servos are NOT in the tail on this ship.
Rather they are on the sides of the fuse under the wing and only an inch or so behind the CoG.
I hope that helps,
Eric
THX-181 is offline Find More Posts by THX-181
Old May 26, 2012, 11:52 PM
morrigan is offline
Find More Posts by morrigan
morrigan's Avatar
Deutschland, BW, Ebersbach an der Fils
Joined May 2011
Hi,
bought me a Acromaster a few days ago. It will be my birthday present for july from my wife.
But i bought it now to have enough time to build it like i want without the "pressure" of "want to fly the next day"
Nice Kit. Very good packaging. Good fit of the Foam.
I sanded down the hole thing. Was the first plane from elapor i did this. I think it was worth the work. the color stick very good.
I will use a Turnigy SK 3 3542- 1250 KV motor, 11 x 5,5 prop, a turnigy trust 55A ESC and HK Servos.
Description:
Description:
Description:
Description:
Description:
Description:
I am looking froward to get this bird in the air....
morrigan is offline Find More Posts by morrigan
Old May 27, 2012, 12:49 AM
Nick9000 is offline
Find More Posts by Nick9000
Hacienda Heights, Ca., USA
Joined Sep 2009
It looks nice! Time well spent. Nick.
Nick9000 is offline Find More Posts by Nick9000
Old May 27, 2012, 10:19 AM
morrigan is offline
morrigan's Avatar
Joined May 2011
Had a bit time today.... went out of checkered stickers... must make some more on tuestay...
Will go on the wings as well (white area)
the more i built it, the more i like it
Orentiation should be good with this design.
Description:
Description:
Description:
Description:
Description:
Bernd
Old May 29, 2012, 10:58 AM
jm11 is offline
Find More Posts by jm11
United States, OH, Toledo
Joined Mar 2008
Looks spectacular! Nice Job. Right now Im sanding all the little bumps off the canopy before painting. Not sure if its really worth the time. I might use some of those "temporary tattoos" for graphics. Works on fiberglass, not sure about the foam.
jm11 is offline Find More Posts by jm11
Old May 29, 2012, 12:07 PM
morrigan is offline
morrigan's Avatar
Joined May 2011
Hi, i Sand down the hole plane. It is better With the small nips. But You still can still See Them. even after painting. But it is much better With stickers.
I Made New checkered stickers Today and sticked them on the plane.
Description:
Description:
Old Jun 02, 2012, 06:35 PM
RCDestroyer is offline
Find More Posts by RCDestroyer
The Crash King
RCDestroyer's Avatar
United States, OH, Richfield
Joined Mar 2010
I just bought this plane today and i noticed that people have been having problems with vibrations when flying. Is this a consistant issue among all the Acromasters? Also, what causes their vibration and how do you fix it?
THanks!
Travis
RCDestroyer is offline Find More Posts by RCDestroyer
Old Jun 02, 2012, 08:03 PM
THX-181 is offline
THX-181's Avatar
USA, CO, Longmont
Joined Jul 2008
The vibration issue seems to stem from two areas...
1) Prop/motor balance
2) Weak nose structure/motor mount
Check out page 134 post 2000 of this thread for the fix I used.
Also,
Some folks are using metal motor mounts alone with good results.
Here's a link... http://www.headsuprc.com/servlet/the...ltiplex/Detail
Enjoy
Eric
Old Jun 02, 2012, 08:39 PM
The Crash King
Joined Mar 2010
Also, does the precut servo slots in the plain call for Hitec HS-81 size servos or T-Pro SG-90 size servos?
Old Jun 02, 2012, 09:12 PM
cynjon is offline
Retired USAF
cynjon's Avatar
USA, SD, Piedmont
Joined Jul 2005
The MPX-recommended servos (and how the molded servo pockets are sized) is for HS-81 or HS-85 in the fuse for R/E, and HS-55 for the ailerons. However, I personally believe that the HS-55 is marginal at best with the huge ailerons. I would recommend a HS-65 or HS-65MG for those. HS-81 is adequate for the fuselage, but they're notorious for poor centering--unless you want to be chasing a changing pitch trim setting, I'd recommend the HS-85 or HS-85MG. Just my $.02--I've been very happy with my HS-65HB/HS-85 servos.
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
