Espritmodel.com Heli Air
Old Nov 04, 2009, 04:28 PM
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Originally Posted by KiltedRanger View Post
Steve,
I'm using the DX6i so positive expo makes it "mushy" center stick.
I am a heli pilot, and I grew to not like expo very much. I find that the mushy center stick feeling, gives way to the faster speeds as the sticks are moved further out in their travels.
At least, that's my experience. I was able to control the AM with full travel and no expo, with no issues... even in the wind. I just found that it was very twitchy... so I cut back on the travel some. However, due to the twitchy feel, I will definitely add some expo to soften it a bit. At least until I get some time on it.
Are most people putting their packs in the cavernous hole in the nose? Or are you all setting the pack on the flat spot between the wings?
I can't seem to get static balance either way... it's really picky.
Thanks everyone...
Darren
Darren,
I suggested 'some' expo and it sounds like that's most likely causing the twitchyness. I had the same experience with 0% on my helis (Compy FP and MX400). My first plane 'experience' was quite scary with 0% expo Try 20-30% just for a start and use 'small' corrections in calm conditions on your next attempt.....at least to you get a feel for the way it handles
OH...and another 'caution' ! If you ever cartwheel, remove elevator/rudder arms and check that the wire slips FREELY in the 'snakes' ! Don't ask how I know
Flightmax 3S 2650 is on the flat area above wing.
Lonelasso is offline Find More Posts by Lonelasso
Old Nov 04, 2009, 04:43 PM
Parkflyer
KiltedRanger's Avatar
St. Pete, FL
Joined Feb 2008
Awesome Dave... thanks!
I'm headed out for St. Thomas tomorrow... but hopefully the wind will be calmer next week. I really can't wait to ring the snot out of this bird.. I like what I see so far!!!
~ Darren
KiltedRanger is offline Find More Posts by KiltedRanger
Old Nov 04, 2009, 04:53 PM
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
I have the pack in the large hole in front. My 3200 mAh battery is too big to fit on top above the wing.
I was wondering if 120% throw with 0% EXPO was going to cause you difficulty on your maiden. I assumed you had a couple rates to choose from and would be fine through by just hitting the rates switch. I am glad that you were able to bring it down safely.
I agree with the 20-30% EXPO recommendation that seems to take just enough edge off to make my movements smooth but not so much that I feel disconnected from the plane.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Nov 04, 2009, 06:48 PM
Parkflyer
St. Pete, FL
Joined Feb 2008
I added 30%+ expo and put the servo travel at 120%. This brings maximum deflection on the control surfaces, without putting the servos at any bind. I had to use some sub trim a bit, to zero out the incidence in the surfaces, but other than that, they move beautifully.
I am not used to flying a plane with control surfaces this large... but, I will get used to it quickly. Static testing on the ground made center stick adjustments more controllable.
Thanks for the tip guys... Now to just get the static CG nailed down, and get some wind free (or close to it) days so I can get some air time.
I think the Power 10 will be fine with the 12x6e APC whilst I learn her manners in the air.
Even all jacked up, I was able to land it safely, without cracking it up. That made me feel good...
It's not a good idea to fly on the skid pad in November I think. Same thing almost happened to my Corsair the other day... got video of that one.
Cheers!
Darren
Old Nov 04, 2009, 07:30 PM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Cheers!
Darren
I'd like to see the video. Post a link if you have one.
Old Nov 04, 2009, 07:37 PM
Joined Mar 2009
my battery is in the hole and it works fine for me. I have no expo on my Futaba and I do not think i will like it neither (I am still young and do not have shake hands, well, most of the time) but at the moment I am flying on 35% on servos (thats O.k for me at the moment), great weather here at the moment, no winds 26/28 deg still, very good for flying, but not to be sat in a office looking out the window and thinking .. reather be flying...............
speedymojacar is offline Find More Posts by speedymojacar
Old Nov 04, 2009, 09:17 PM
Parkflyer
St. Pete, FL
Joined Feb 2008
Here ya go Mate...
This was not too long ago, futzing around on the skid pad. The winds were very gusty, since we are right on the ocean. It's ALWAYS breezy here, and I thought things would be ok.
Little did I know, my left landing gear was loose, and caused some issues on landing. I normally hand launch / belly land this bird, but I wanted to try some ROG take off's and landings.
At the end, I was trying to do a nice three point landing, missed my touch down spot and was gonna go around. At the moment I started to pull up and add throttle, the Corsair was caught by a nice cross wind / downdraft, and I almost winged it into the ground.
I fly with my control surfaces / servos where they have max travel, and I don't have any expo on the Corsair. I fly this plane all the time, so the AcroMaster will take a bit of adjustment.
Here's the video...
http://www.rcgroups.com/forums/showp...&postcount=184
Cheers!
Darren
Old Nov 04, 2009, 09:25 PM
Lonelasso's Avatar
Joined Dec 2006
Here's a pic of where my pack sits
Old Nov 05, 2009, 06:25 AM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Here ya go Mate...
Here's the video...
Cheers!
Darren
Nice video. It is tough to video tape flying airplanes and get the focus right. I think your friend did a pretty good job. The auto focus has a really tough time the these tiny dots in the distance. Some folks recomend turning off auto focus and focusing on "infinity" to keep it in focus in the sky. When I tried that I had to switch back to auto focus when the plane gets close for landings for fly bys because then it gets out of focus because it is too close.
It looks like you stalled on the first 2 landings. I used to land like that in the wind. I would recommend landing with a higher air speed. Then if a gust dies down you still have enough air speed to be flying on the wing and come down gently. With my Acromaster and my Precision Aerobatics Extra 260, I try to put them on the ground at around 20 mph or even 25. That takes the wind out of the equation. So, on my neighborhood street where I fly, I drop down to about chest height and fly with speed down to 1/2 of the wing span (where you get extra lift because of the ground effect) and cut the throttle with a little flair. So from the point I get to waist height until I am on the ground takes about 75 - 100 yards. I have not really had wind issues since I have been landing like that.
Well, except when I was stupid enough to fly in 25 - 35 MPH winds. But that is another story....
-Mike
Old Nov 05, 2009, 06:31 AM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Wow, I can see your battery pack doesn't fit their either! Did you cut back the supports inside the canopy to make room for it so that the canopy can close? Does it fly better there than in the big hole up front?
I have had flaky coupling issues when I fly with light batteries (2200 mAh) in the hole behind the motor. My AM gets very pitchy in KE fliht with the light battery.
So I was wondering if move the 2200 mAh battery over the wing if that would solve the coupling issue.
-Mike
Old Nov 05, 2009, 04:43 PM
Lonelasso's Avatar
Joined Dec 2006
-Mike
Mike,
I flew it with the pack in the hole, but it was fairly nose heavy. I'm using a 103G Omega motor and the current lipo location is neutral to slightly tail heavy CG. I'll post up some vid I took earlier today Weather was damn near perfect today ! Sunny, 74 and no WIND
Inverted Practice with Acromaster @ TT 11/5/09 (4 min 48 sec)
Old Nov 05, 2009, 10:10 PM View Post
nicolezhu85
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Nov 05, 2009, 10:24 PM View Post
nicolezhu85
Old Nov 06, 2009, 11:19 PM
Parkflyer
St. Pete, FL
Joined Feb 2008
Mike,
You are absolutely correct... I did stall it, well... pretty close. The Corsair does not like to slow down all that much, even heading into the wind. It startes rocking it's wings if it gets too slow. What was freaking me out was the cones, trying to keep enough speed to not fall out of the sky, and still miss the cones.
Then I figured out that the left landing gear was not locking into the plastic keepers... causing it to get all squirrely.
I am having fun, getting experience... and now that I am back from St. Thomas, I hope this weekend lends me some fairly calm flying time. I can't wait to really fly the AM.
Dave... nice flying man... that last landing looks exactly how I scuffed my wing on my AM... only I had a butt load of wind gusts to deal with. I won't be flying on the skid pad anymore at lunch... unless it's very calm.
Thanks for the pic of the battery location. I'm gonna futz around with mine tomorrow.
Cheers Guys!!!
Darren
Old Nov 09, 2009, 07:40 PM
Have had the Acro flying for a few weeks, about 6 days of going out flying, would like some input from others on landing characteristics in 10k plus winds. I know it is a light foam plane and it is amazing at speed but the landings are trick and the near touch down always up to the wind gods. Any hints out there? No major damage but no flattering landings in the wind when coming in on grass.
lmstech is offline Find More Posts by lmstech
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 01:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 04:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 05:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 03:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 01:48 AM
