I use 2 skewers poked through from under the canopy, through the wing, into the fuse on the bottom. Similarly, mine were plenty tight in the beginning, but several flights (and crashes) later, one or both wings would wiggle out 1/4-1/2" during flight. Never lost one, but got concerned... no problems since doing the skewer thing.
I did the skewer thing like Gene but with some spar CF rods and have had great luck with it. After you've push the skewer through the foam, I'd suggest stiffining up the foam holes with some thin CA, much like people do with servo screw holes in balsa. Otherwise, these foam holes will begin to enlarge. The CA hardened them and this setup works great and is easy to install/deinstall.
Alan |
I was standing next to a bucket of dry wall screws and thought.... hmm... this will get me in the air faster. I should probably go back and replace the screws with the CF rod
Joined Apr 2007
Anybody else using the Thrust 40 from Precision Aerobatics?
Must say the motor is extraordinary! Very long flight times (3S 2200mAh) doing F3A aerobatics, no 3D. Cool, efficient - no, I am not a rep for PA .... just happens to like the motor! Before I had a Torque 2812/900 but it didnt had enough power (for me). Take a look here: http://www.precisionaerobatics.com/category.php?cid=9 and here: http://www.thrustmotors.com/ /tritan |
-Mike |
I currently run my AM on a Torque 2818 900kv and APC 13x6.5 setup and with all of the newer packs, it has a ton of power. I run a Thrust 40 in my AMR and I think it would be overpowering the AM. But then again, sometimes that can be fun. But I agree with Sony, you will have to do something to reinforce the nose if you plan on running 400+ watts through this airframe.
Joined Apr 2007
I have of course the fiberglass nose - the reason to put the Thrust 40 in the AM was to have to have that surplus power available now and then. The motor is so smooth and powerful that I very seldom use full power. But its nice to have that ballistic force sometimes.......
I would say that it has about 2:1 thust. I have also changed to the new Hyperion G3 CX25 3S 2200mAh - very nice batteries. Precision Aerobatics now have some wooden props called VOX they recommend for their motors - will try a couple of these soon. Note: I highly recommend to balance your props even if its a new APC. I always use a magnetic balancer beacuse no prop so far has had a perfect balance. Maybe thats why I never had any issues with my AM? EDIT: no issues except that stupid landing gear with those tiny wheels which are unusable on normal grass .... Acromaster Thust 40 APC 13X6,5e Hyperion G3 CX25 3S 2200mAh 4x HS-5065MG AR 6100e JR DSX9 |
Chichester Sussex
Joined Aug 2007
Except for the perceptions of a small percentage of readers. I really don't think any of my comments will discredit PA. I happen to really like my PA product. Rubbish is a very strong word to describe PA. In comparison to the Acromaster which needed a couple of modifications to fix design flaws, my PA Extra didn't need any modifications and actually does fly better than the Acromaster in a couple of scenarios. Less coupling in KE etc, easier / more vertical elevator drops. The Acromaster flies really good as well. If flies better than the Art Tech, ParkZone, Hobbico and Great Planes U-Can-Do 3D FlightFlex EP ARF 33.5" planes that I either destroyed or leave sitting on a shelf because I can't stand flying them. It is also incredibly durable. I have smacked trees / the ground VERY hard on 2 occations and had no significant damage to the plane. This would have destroyed my PA 260 or any balsa plane for that matter. Every day after work I go out and get at least one flight in with both planes. I will probably be just as likely to mention 3D Hobby Shop after my new 57" 3DHS Extra 330 SC arrives in a couple of weeks. Additionally, I plan to buy an Extreme Flight Extra 300 next year. So, I may very well start mentioning Extreme Flight as well if I feel the comments are relevant. For instance, I posted in other Threads that the Acromaster is a great plane to buy and use based on the poster's original question because the situation and context seemed to warrant a mention of the Multiplex Acromaster. I thought this was a forum to talk to fellow pilots and share information openly and honestly. I didn't realize that I had to be careful of "religious" tensions and that I had to restrict my comments exclusively to positive comments about the manufacturer that the thread is about. Even when the question that comes up IS about another manufacturer's product. I will keep that in mind going forward. |
Chichester Sussex
Joined Aug 2007
Not being funny but along with this comment as well you're in a Multiplex thread favouring other manaufacturers products over theirs on more than one occasion - I don't think it's unreasonable to question the motivation behind it. Now if you want to start a totally new thread PA Extra 260 Vs Mulitiplex Acromaster as a discussion or if you have a problem with the Acromaster and wish to discuss that in here thats another story but personally I wouldn't "appear" to be promoting another manufactuers products on more than one occasion in a specific thread. Just my 2 C's worth. |
Does anyone fly the Acromaster with Himax 3516-1130 and a 12x6 prop? If so, how long can you do that before you burn the motor out?
The manual says that the 12x6 on 3S will put too much current through the motor pretty quickly. But it just flies so much better with the 12x6 than an 11x5.5. I fly it at about half throttle peaking at about 2/3 throttle. I don't have a current meter to see how much it pulls at that level. I was just wondering if someone else has experience. |
New Jersey
Joined Sep 2008
Nashville, TN
Joined Feb 2005
Does anyone fly an Acromaster with ONLY multiplex equipment?
Multiplex Acromaster multiplex transmitter multiplex servos multiplex amp meter multiplex screwdrivers multiplex esc multiplex battery multiplex prop multiplex shirt multiplex cap multiplex jacket Do they make socks?? lol I personally feel ANY comparisons are helpful and welcome. $0.02 Chris |
Latest blog entry: Basic R/C Connector Soldering
| Thread Tools | |
| Discussion Extremeflight Extra vs Multiplex Acro Master | Magna | 3D Flying | 17 | Dec 10, 2008 01:11 AM |
| For Sale Multiplex Acro Master RTF | slopenutz | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 13, 2007 04:12 PM |
| Sold Multiplex Acro Master | termite | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 20, 2007 05:04 PM |
| Link Multiplex Acro Master $99.99 | Doubletap | Hot Online Deals | 6 | Dec 18, 2006 03:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
