I flew my AM again today, this time with the re-indexed prop adapter that eliminated the vibration I was getting. Wow...it was fun to fly before, but to fly it whisper quiet was even better. Without a doubt, the AcroMaster is now my favorite sport flying plane. Time to sell my e-powered BalsaNova and Aerophibian. I'd highly recommend the AM to anyone with a little stick time. What suprises me is I'm still the only one at our field flying one. The other fliers just don't know what they're missing.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
Himax Motor Vibration
I just put together my Acro Master's replacement fuselage, and tested the motor to see if it was rotating in the right direction. I had not recently tested the motor without a prop on it, and noticed a little vibration. The shaft is dead straight, so what else on the motor could be causing it?
Unloaded vibs could have lots of sources. A loose/missing magnet, unbalanced can, motor mount not sitting firm and square. Not knowing how much vibration you are talking about, I'd stick on a prop and see what it does. As long as the prop is balanced you may be able to eliminate some vibrations by reindexing the prop/collet/motor shaft with each other until things run smooth.
Olympia, WA
Joined May 2005
Landing Gear Height
I am going to put Al landing gear on my Acro. I know the height of the stock gear is about 4" from the axle to the mounting plate. If I use landing gear with a height of 3" will there be enough room on take-off for prop clearance using a 12X6 prop?
Thanks Danny |
12x6 Prop clearance = 3" |
Olympia, WA
Joined May 2005
Danny |
I recently bought an AM after having previously owned multiple Easystars, a Twinstar, and a Minimag. I'm a big fan of Multiplex's airplanes. Thanks to this thread, I'm confident I'll have a great flying Acromaster! Mine's going to be lightweight. I went with the Torque motor, Berg 7 RX, CC Thunderbird 36 and didn't choose the MG version of the recommended servos.
I also saved 14 grams by substituting 10mm carbon tube for the included wing spars! |
I weighed, but have since forgot my AUW. For the AM, I personally think saving a few grams/ounces here or there will not make any appreciable difference. i built mine stock, used HS-81s all around, added stiffeners to my landing gear wire...all adding weight...and my AM flies like it's full of helium. It just 'feels' so light and responsive in flight that I can't imagine being lighter would make a difference. Don't worry about building it stock and just having fun...the AM is a wonderful plane!!!
Tenerife,Canary Islands
Joined May 2004
I can imagine it lighter for 3D but for Imac style is very good at this weight , even it ballons a little too much for precise landing in cross wind , I think I´m too used to foamies and very large planes ,the last fly all good but I have to ask my friends for some minutes of pleasure .
Juan. |
I just took it off the scale.
826 grams without battery! I'm pretty happy. Besides swapping in a lighter set of carbon spars and using the light componets mentioned above, I also used a lighter collet adapter, 3mm carbon tubes instead of the outer pushrod snakes, CA hinges which were 1/2 the weight of the stock hinges, light gauge servo extensions and as little glue and paint as possible. You don't save weight on an airplane in one place, you need to save weight everywhere for it all to add up. I'll weight my friend's AM tomorrow, he built his with no regard to weight savings. It'll be interesting to see the difference. Can't wait to fly this thing! |
| Thread Tools | |
| Discussion Extremeflight Extra vs Multiplex Acro Master | Magna | 3D Flying | 17 | Dec 10, 2008 01:11 AM |
| For Sale Multiplex Acro Master RTF | slopenutz | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 13, 2007 04:12 PM |
| Sold Multiplex Acro Master | termite | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 20, 2007 05:04 PM |
| Link Multiplex Acro Master $99.99 | Doubletap | Hot Online Deals | 6 | Dec 18, 2006 03:37 PM |
| New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 | Joe Pierson | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 06, 2001 01:48 AM |
