Old Jul 23, 2006, 09:29 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Avoid the cheap E-Flite brushless ESCs...
I finished the AM yesterday.
I was setting up the controls, and everything was going fine. Slowly, but fine.
I had just finished reversing the channel to get the rudder moving the right way, and I accidentally bumped the throttle stick. (the prop was on) I was smart enough to stay clear of the prop, but not smart enough to remove it. (I had just balanced the plane, so it was still on)
The prop made a half-turn and jammed against the carpet. I cut the throttle right away. Naturally, the throttle didn't work after that. I thought: "No problem, I'll just reset the input power and I'll be good to go..." No such luck. I tried it again after 30 seconds, thinking I would let the caps bleed down. No luck. I sniffed the rudder servo, as it was buzzing. No problem there. I sniffed inside the fuselage and smelled burnt semiconductors. (I know this smell from work) I knew what it had to be, and after I removed the battery, my worst fears were confirmed.
The heatshrink on the ESC was split open, and four of the surface-mount chips were blown.
Silly me for leaving the prop on during programming, and silly me for bumping the throttle stick. But shouldn't all ESCs have electronic overcurrent protection built in? Has anyone else had this happen with another type of ESC? I have a Castle Creations Thunderbird 18 that gets locked up once in a while on my EasyGlider because it "forgets" where the throttle off position is once in a while, but the motor stays locked for a couple seconds, and the ESC shuts down. If I reset the input power, it works again.
It hurts to be out $55 of the cheap ESC (E-Flite 40 A brushless) but I want to make sure the next one I buy will not have this problem.
Jeremy Z is offline Find More Posts by Jeremy Z
Old Jul 23, 2006, 09:30 AM
Jeremy Z is offline
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
I wonder if an overloaded BEC contributed? 2 HS-81s and 2 HS-55s was probably pushing it. Are you all using BECs with 3S? What controllers are you using with your 350-375W motors? (I didn't want to pay the $90 or whatever for the Phoenix...)
Old Jul 23, 2006, 09:32 AM
Jeremy Z is offline
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Pjtorr, the buzzing sound I mentioned from this plane is because everything is mounted so solidly to the fuselage. This is going to rattle screws loose over time, so watch out for this people! (yes, I balanced my prop)
Old Jul 23, 2006, 10:58 AM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
Hi Jeremy,
The Kontronik Jazz controllers have a "switching" BEC, even at 5slipo this BEC delivers a steady 3A...
the new line from YGE, another German brand has got this too now, but the Chinese have made some cheap ones too, for about $50 you can buy them at www.himodel.com
Here in Holland www.rctechnics.nl sells the Himodel ESC's
I'm thinking of trying one of these too...
Peter
Pjotrrr is offline Find More Posts by Pjotrrr
Old Jul 23, 2006, 01:13 PM
Pjotrrr is offline
Me likes Depron...
Pjotrrr's Avatar
Joined Mar 2003
Another nice vid:
http://airtoimedia.nl/web/upload/vdV...croMaster2.wmv
48Mb, but worth the wait...
Same setup as last video, but this time only 960 grams with Hyperion 3s1800
After this flight there was still juice left in these tiny lipo's for a minute or so...
Old Jul 23, 2006, 01:39 PM
charlatan is offline
Find More Posts by charlatan
charlatan's Avatar
Liverpool, UK
Joined Jun 2002
Maidened mine today. Well impressed, oodles of power. Unfortunately didn't get any video, it was blowing a hoolie on our field.
I am less impressed tho with the undercarriage. It gave me no end of problems, what with wheel collets coming loose and the wheels coming off. Other than that well happy, my Magister, Funjet and Acromaster all returned from the field in the same condition they left the house in
charlatan is offline Find More Posts by charlatan
Old Jul 23, 2006, 05:13 PM
kraaijer is offline
Find More Posts by kraaijer
Belgium
Joined Apr 2006
Great Video Peter
I'm amazed what one can draw out of a 1800 battery.
kraaijer is offline Find More Posts by kraaijer
Old Jul 23, 2006, 06:01 PM
zippo is offline
Find More Posts by zippo
Oxfordshire - UK
Joined Jan 2003
Found my USB lead - here is the UC mod I spoke about earlier
zippo is offline Find More Posts by zippo
Old Jul 23, 2006, 10:03 PM
TexasFlyer is offline
Find More Posts by TexasFlyer
TexasFlyer's Avatar
Houston, TX
Joined Sep 2005
Zippo,
Thanks! A picture says a thousand words.
Alan
TexasFlyer is offline Find More Posts by TexasFlyer
Old Jul 23, 2006, 11:01 PM
rycomm is offline
Find More Posts by rycomm
Flyin' Ryan
USA, MO, Lee's Summit
Joined Sep 2001
Good to hear all of these AMs being readied for flight. I am still waiting for the motor (Eflight power10) and ESC (CC Phx45). They should be at the LHS early this week. My landing gear appears solid, but I haven't flown it yet. The Elapor wheels look like they are good for one touch and go, but I like the wheel pants. I have 2 polyquest 20c 1800s and 2 dualsky 2250 packs. I was planning on going 3s2p. I figured I would be pulling 30-35A, and don't trust most 20C ratings. How warm are those packs coming out of the AM?
I really like this planes size. It just seems like it ought to fly great.
I used the HS81's on rudder and elevator, and HS65's on aileron. I noticed (too late) the manual said the other way around, but they fit better the way I mounted them. The EZG uses the 81's on on R&E, 55's on ailerons (much smaller ailerons though), There is only a few oz diff in torque of the 81's and 65s. Will I be OK?
Ryan
rycomm is offline Find More Posts by rycomm
Old Jul 23, 2006, 11:05 PM
rycomm is offline
Flyin' Ryan
Joined Sep 2001
Jeremy, you may want to check out the ESCs from 2dogrc. They have a couple of inexpensive 40A+ models. They program with a Jeti card, so should be easy to setup. I haven't had any experience with them, but it might be worth a search.
Ryan
Old Jul 23, 2006, 11:44 PM
Jeremy Z is offline
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Originally Posted by Pjotrrr
Hi Jeremy,
Peter
Peter, thanks for that link. If the balancing series ESCs work as advertised, that might be the way to go. It looks like they have a tap for the Hyperion type balancing tap too....
I checked out the Kontronik Jazz 40A ESC:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGCW2&P=7
Son of a B TCH are they ever proud of their product! $170 for an ESC? I don't care HOW good it is, it can't contain more than $20 worth of parts. I'll try the Chinese one when I get the $$ together again.
In switch-mode power supplies, "switch-mode" nearly always implies that the device has automatic overcurrent protection. Is it safe to make that assumption here?
Old Jul 24, 2006, 04:35 AM
Pjotrrr is offline
Me likes Depron...
Pjotrrr's Avatar
Joined Mar 2003
I don't really understand whay you mean, the switch mode BEC always keeps 5V/3A to the receiver, no matter how many lipo's are used in series (2 to 5slipo)
I wouldnot care for that balancing feature, I never have problems with my lipo's getting out of balance, charge and use them the right way and they last for long...
If you want to be sure with a pricy pack a balancer between pack and charger one in the ten times you charge them is safe enough...
The Hyperion 3s1800 was not hot at all after the seven (!) minute flight of the video...
So it's only 15A on average during the flight, this won't hurt these 20C packs at all...
My choice would be two of these packs instead of one 3s3200....
Old Jul 24, 2006, 05:25 AM
ModelTony is offline
Find More Posts by ModelTony
ModelTony's Avatar
Irvine, Scotland
Joined Jun 2004
The purpose of tapping each of the cells is not for balancing, but so that the ESC will enter into cut-off mode when the first cell goes below the cut-off voltage.
Tony
ModelTony is offline Find More Posts by ModelTony
Old Jul 24, 2006, 07:54 AM
LaMuse is offline
Find More Posts by LaMuse
LaMuse's Avatar
Austria - Vienna
Joined Jul 2005
Configuration
Hi all,
I am going to get my own Acromaster too very soon but I am still searching for the best configuration...
After having read lot of forums (and of course this thread), it seems that the Himax c3516-1130 with 45A ESC and 11x5,5 is very good.
I have read also of AXI 2820/10 or 12 (can't tell the difference!).
Anyway, my point is that my retailer, who i consider competent, is proposing following configuration:
- Brushless Pulsar BL25
- ESC Multicont BL27 (Multiplex)
- APC 10 x5
See the details
Well i must say that i am not convinced about it. What do you think ?
Does anyone have any experience of Pulsar motor ? Seems too weak to me compared with the Himax or Axi.
What about the ESC ? Isn't it too light (27A /35A max) ?
Thanks for your support!
LaMuse is offline Find More Posts by LaMuse
Discussion Extremeflight Extra vs Multiplex Acro Master Magna 3D Flying 17 Dec 10, 2008 02:11 AM
For Sale Multiplex Acro Master RTF slopenutz Aircraft - Electric - Airplanes (FS/W) 6 Jul 13, 2007 05:12 PM
Sold Multiplex Acro Master termite Aircraft - Electric - Airplanes (FS/W) 8 Mar 20, 2007 06:04 PM
Link Multiplex Acro Master $99.99 Doubletap Hot Online Deals 6 Dec 18, 2006 04:37 PM
New Multiplex 4 Engine Cargo with speed control !!!! Looks like a B-17 Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2001 02:48 AM
